Release notes for Bright 9.2-10
== General ==
=New Features=
- Added CUDA toolkit packages for ARM64
=Improvements=
- Updated python2-pyasn1 to 0.4.2-3.2.1
- Updated cm-nvhpc to 23.1
=Fixed Issues=
- Decreased the size of the rescue environment ramdisk, to allow some Dell hardware to boot in UEFI mode (e.g., Dell PowerEdge R650)
- An issue with cm-chroot-sw-img unable to execute a shell in the software image when the user has defined a $SHELL environment variable for a shell that is not present in the software image
== CMDaemon ==
=Improvements=
- On Ubuntu base distribution, inet=manual is now added to the configuration files for network interfaces without an IP, so that they can be brought up by the operating system
- Allow the option to specify inet=manual for network interfaces on Ubuntu base distribution (set revision inet=manual)
- Process the custom /cm/conf/{category,node} files also after an imageupdate of a running node so that the customizations are preserved
=Fixed Issues=
- CMDaemon crash on Rocky 9.1 / RHEL 9.1 base distribution when a regular user logs in to the user portal or Bright View
- An issue where overriding the kernel module parameter at the node-level does not take effect and the kernel module parameters are rather inherited from the software image
- An issue where automatic FSExport are not added for nodes in a type3 network setup
- An issue with monitoring data plots consisting of consolidated and raw data sources
- Delay the start of the slurmd service until after the MIG configuration is updated when the compute node is booted
- An issue where the Etcd health check script may fail for nodes with tagged VLAN interfaces
- An issue where MIG operations may not be able to complete, which can prevent future MIG operations
- An issue where MIG apply may timeout when CMDaemon is starting because the timeout is too short
- An issue with the automatic switch of the monitoring node when the passive head node goes down for a prolonged period of time
- In some cases, CMDaemon crash in the sysinfo implementation when the CMDaemon service is stopping
- A CMDaemon memory leak when the Slurm placeholders maxnodes value is less than nodes in the queue
- An issue where the bond primary=name directive is not written for the underlying physical network interface on Ubuntu
== Bright View ==
=Fixed Issues=
- An issue with the reinstall and sync Bright View actions for software images
- An issue with assigning the slurmclient role directly to a compute node in order to override the slurmclient role at the overlay or the category level
- An issue where Bright View may show “No response from the server yet because client quit” upon logout
== Cluster Tools ==
=Improvements=
- Automatically detect environmental proxies in cm-diagnose
=Fixed Issues=
- An issue where the cm-restore-db-password script may not reset the database user password in mysql for Slurm
== Machine Learning ==
=Fixed Issues=
- Updated cm-tensorflow2-* to 2.11.0
- An issue where importing the tensorflow python module with tensorflow2-py39-cuda11.2-gcc9 yields a RequestsDependencyWarning message
== cm-kubernetes-setup ==
=New Features=
- Added Network Operator to the cm-kubernetes-setup script
=Improvements=
- Wait explicitly for the Ingress Controller to be up & running to avoid potential issues later when deploying other operators
=Fixed Issues=
- Clean up the nginxreverseproxy and nginx.conf configurations when Kubernetes is uninstalled
== cm-scale ==
=Fixed Issues=
- An issue where cm-scale tries to match the Kubernetes pods or jobs labels to the node’s labels. This is now disabled by default
== cmburn ==
=Improvements=
- Added cm-gpu-burn package for Rocky9/RHEL9 base distributions
== licensing ==
=Fixed Issues=
- Remove the license expiration warning on the secondary head node after installing a new license
== openpbs20 ==
=Fixed Issues=
- An issue with updating the pbspro/openpbs hooks when a new pbspro/openpbs package is installed
== openpbs22.05 ==
=Fixed Issues=
== pbspro2021 ==
=Fixed Issues=
== pbspro2022 ==
=Fixed Issues=
== slurm ==
=New Features=
- Rebuild Slurm with CUDA 11.8
== slurm22.05 ==
=Improvements=
- Updated Slurm to 22.05.8
