Has anybody test or use any remote harness for coding ?
I don’t mean Hermes or OpenClaw. Something that perhaps can communicate or sync with Deepseek harness on the road. I saw a couple of them on github but just wondering if anybody tested or use some of these ?
Like opencode serve and connect you own UI/app?
Practically you can have your harness calling any harness, which is how people this days uses $20 claude thru CLI for their systems.
I built a MITM API with Opencode server and gave it a frontend with voice input (plus lots of other features). Can leave the TUI and keep working on any session from mobile now. Really convenient.
For terminal-based harnesses I simply use tailscale and then ssh in, also works quite well via the termux app on Android.
If the harness is web-based then tailscale is also what I would personally use on the road.
Another alternative is cloudflare binding to the port (if it is web-based) but then you naturally have to otherwise protect the address (also possible via clouflare). This has also worked well for me.
