Dear All,
I am newbies to CUDA but I have read and test a lot of Example provide in the SDK which are really valuable source of information.
But I still have some question which regarding the design of my application.
The first issue is that I would like to know if it is possible to call windows function (API) to rendere image directly in the cuda device?
The second issue is that I have three for loop.
Serial version
for each Frame
For earch Beam
Rectify Scan data in Beam
for each data
make compute each data
Approach Parallel version in CUDA
map Frame to Grid
map Beam to Block
Rectify Scan data
map data to sample
used thread Idx to compute each data
dear “cuda guru” is this approach good with cuda architecture ?
if yes how can I implemented this in CUDA (pseudo code) I mean how can I get the index of thread.
Beam and Scan data size are variable and all loop are really independent.
Thanks a lot for your reply.
