Hello, I want to replace the second LOGO on the Orin devkit in JP5.0.2 when starting up. Previously, when using xavier, I could use the tool “Linux_for_Tega/tools/bmp splash” to generate blob files, but orin did not find the tool directory. What can I do? thank you!
I used the tool of xavier. When generating, I passed in the parameter t234 and used flash.sh to burn. An error occurred.
sudo ./flash.sh -r -k BMP --image ./bootloader/bmp.blob jetson-agx-orin-devkit mmcblk0p1
Please refer to the rel-35.1 developer guide. There is method mentioned.
Right here? thank you,Or could you elaborate?
https://docs.nvidia.com/jetson/archives/r35.1/DeveloperGuide/text/SD/Bootloader/UEFI.html#customized-logo
Yes, you need to rebuild the UEFI binary.
The logo will be displayed twice during startup. Are they all in uefi?
No, the second one is just a file in rootfs.
Where did you modify it? Secondary
see if there is file over here - /usr/share/backgrounds.
NVIDIA_ Login_ Logo. png
is this one?
Yes
