Request for Adjustable System Requirements – VRAM Scalability
Dear Support Team,
I greatly appreciate the ability to run AI models locally with ChatRTX. However, I am experiencing issues due to the minimum requirement of 8 GB VRAM. My laptop has a powerful CPU (e.g., AMD Ryzen 7 7435HS) and an NVIDIA RTX 4050 with 6 GB VRAM. Despite having strong processing power, I am unable to use ChatRTX due to this VRAM limitation.
I would like to suggest making the system requirements more flexible in future updates, allowing powerful CPUs to compensate for lower GPU VRAM—even at the cost of reduced speed. Many modern laptops have similar hardware configurations and could benefit from better scalability.
Thank you for your time and consideration. I hope this adjustment is possible and look forward to your response.
Thank you for your attention. In eager anticipation,
Farodin
Hi @lucaszech.lz you can make developer requests for Chat RTX through the GitHub. Please take a look at this forum post. Thanks! SUPPORT for ChatRTX Users
