Request for information regarding Deepstream
• DeepStream Version
• TensorRT Version
Actually I just want the tutorials to run the samples of the deepstream
I am using:
Jeston Orin Nano with Jetpack 6.x
with Deepstream 7.1
NVIDIA DeepStream SDK Documentation
Sample Apps
Running DeepStream Samples
For DeepStream 7.x, the samples are located in:
/opt/nvidia/deepstream/deepstream-7.0/samples/
To run a sample app like deepstream-test1, just do:
deepstream-test1-app /opt/nvidia/deepstream/deepstream-7.0/samples/configs/deepstream-app/source1_usb_dec_infer_resnet_int8.txt
Each sample (test1, test2, etc.) demonstrates a different pipeline feature. Their configs are under:
Take test1 as an example, Other samples are similar, and there is a README in the corresponding directory.
cd /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-test1/
make CUDA_VER=12.6
./deepstream-test1-app /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264
Actually While building the test scripts I am getting errors while executing with the sample videos
Please refer to README/ to check the Jetpack version. If you have other questions, please provide detailed logs for forum support.
jetson@jetson-desktop:/opt/nvidia/deepstream/deepstream-7.1/sources/apps/sample_apps/deepstream-opencv-test$ ./deepstream-opencv-test -t inferserver file:///opt/nvidia/deepstream/deepstream-7.1/samples/streams/video1.mp4
Using nvinferserver as the inference plugin
One element could not be created. Exiting.
This are the logs and I am trying to run the Deepstream-OpenCV-test sample
nvinfer is recommended.
If you need to use nvinferserver, please install triton first and build the engine file.
/opt/nvidia/deepstream/deepstream/samples/triton_backend_setup.sh
/opt/nvidia/deepstream/deepstream/samples/prepare_ds_triton_model_repo.sh
In addition, because triton depends on boost, but the boost download link is no longer valid, please refer to the FAQ below to modify the triton installation script
Can you give me the details of entire process or some source to refer for the process?
Please refer to this documentation locate at
/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app-triton/README
Use docker image is another option.
docker run -it --rm --network=host --runtime nvidia  -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-7.1 -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/deepstream-l4t:7.1-triton-multiarch
For those unfamiliar with DeepStream, start with nvinfer. Deploying nvinferserver is more complex.
jetson@jetson-desktop:/opt/nvidia/deepstream/deepstream-7.1/samples$ sudo patch triton_backend_setup.sh < setup.patch
patching file triton_backend_setup.sh
Hunk #1 FAILED at 31.
1 out of 1 hunk FAILED – saving rejects to file triton_backend_setup.sh.rej
This is the error I am facing during patching the triton_backend_setup.sh script file with the new setup patch
Alternatively, you can open triton_backend_setup.sh with vim or vscode and edit it as shown below:
-wget -O ${TRITON_DOWNLOADS}/boost.tar.gz https://boostorg.jfrog.io/artifactory/main/release/1.80.0/source/boost_1_80_0.tar.gz
+wget -O ${TRITON_DOWNLOADS}/boost.tar.gz https://archives.boost.io/release/1.80.0/source/boost_1_80_0.tar.gz
Even after changing the backend script.sh I am getting the same error
jetson@jetson-desktop:~$ cd /opt/nvidia/deepstream/deepstream-7.1/samples/
jetson@jetson-desktop:/opt/nvidia/deepstream/deepstream-7.1/samples$ vim triton_backend_setup.sh
[sudo] password for jetson:
