Request to enable Public API Endpoints – 404 Function Not Found for account
Body:
Hi NVIDIA team,
I'm getting a 404 error when calling the NIM chat completions endpoint, even though the models endpoint works.
Error response:
{"status":404,"title":"Not Found","detail":"Function '23bd454d-b225-49a3-8118-582a62fc51b8': Not found for account 'NVX-leN7i4EBjcm7beyi96ez_PUyd8OuMgzHSixMV5I'"}
Details:
- Model: 01-ai/yi-large
- Endpoint: https://integrate.api.nvidia.com/v1/chat/completions
- Function ID: 23bd454d-b225-49a3-8118-582a62fc51b8
- Account hash: NVX-leN7i4EBjcm7beyi96ez_PUyd8OuMgzHSixMV5I (from error above)
- API key: Personal key from build.nvidia.com
- Use case: Personal development / evaluation
Request: Please enable "Public API Endpoints" for my account so I can call the chat completions endpoint.
Thank you!
This situation happens fairly often on NIM. It’s not your problem, and it may not be the account’s problem either. You can simply change, block, or deprecate your old key, then apply for a new “long-lived” key and try again—the issue may be resolved. But if it isn’t… then the cause is unclear, and you may need to keep using another model_id for a while.
Anyway, do not let AI help you write posts, or at least first see clearly how this content needs to be manually edited; your text is too AI-style.
and HOLD ON——I just noticed, which model did you call? Although ‘Not found for account’ is a fairly common error on NIM, what you’re encountering is a completely different situation——you called a model that has long been deprecated! Oh my god, please use other available models like mistralai/mistral-large-4-1t-a52b, minimaxai/minimax-m3.1-flash, stepfun-ai/step-5-preview, z-ai/glm-5.3-flash, the model you called can no longer respond to you!
Hi NVIDIA Support Team,
I am encountering a persistent 404 "Function Not Found for account" error when trying to call the NIM API (e.g., POST /v1/chat/completions), even though the models endpoint (GET /v1/models) works perfectly.
Based on community discussions, I understand this error indicates that my personal account is missing the "Public API Endpoints" permission.
Here are the details of my account and the error:
- Account Hash: NVX-leN7i4EBjcm7beyi96ez_PUyd8OuMgzHSixMV5I
- Error Message: {"status":404,"title":"Not Found","detail":"Function '84bf12ff-edbd-4435-baea-0fa6a7453d2e': Not found for account 'NVX-leN7i4EBjcm7beyi96ez_PUyd8OuMgzHSixMV5I'"}
- Use Case: Personal development and testing.
Could you please enable the "Public API Endpoints" permission for my account/organization so I can successfully call the chat completions API?
Thank you for your time and assistance!
OK,I solve the problem, thank you. I can use codex now.
