Reset dedicated GPU after it gets stuck
I have a setup with a dedicated NVIDIA for CUDA computing and another NVIDIA for display. From time to time, the CUDA dedicated NVIDIA gets stuck - the fan keeps running at 100% and nothing can be really done with it anymore. I can “solve” it by rebooting but I’d much prefer to solve it by resetting the CUDA dedicated card.
Here is the nvidia-smi output when the issue happens (the CUDA card is #0 but #1 is set as primary):
| NVIDIA-SMI 510.47.03 Driver Version: 510.47.03 CUDA Version: 11.6 |
| | | MIG M. |
| 0 NVIDIA GeForce … Off | 00000000:41:00.0 Off | N/A |
|ERR! 41C P2 ERR! / 250W | 2MiB / 11264MiB | 0% Default |
| | | N/A |
| 1 NVIDIA GeForce … Off | 00000000:42:00.0 On | N/A |
| 40% 47C P8 10W / 75W | 479MiB / 4096MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 1 N/A N/A 4517 G /usr/libexec/Xorg 199MiB |
| 1 N/A N/A 4861 G /usr/bin/kwin_x11 1MiB |
| 1 N/A N/A 5515 G …akonadi_archivemail_agent 1MiB |
| 1 N/A N/A 5523 G …/akonadi_mailfilter_agent 17MiB |
| 1 N/A N/A 5526 G …n/akonadi_sendlater_agent 1MiB |
| 1 N/A N/A 5527 G …nadi_unifiedmailbox_agent 1MiB |
| 1 N/A N/A 1923084 G /usr/bin/plasmashell 71MiB |
| 1 N/A N/A 3052928 G …449555690282580582,131072 123MiB |
Thus, no processes are reported as running on the CUDA card. Yet, trying to reset the card returns:
vidia-smi --gpu-reset -i 0
GPU 00000000:41:00.0 is currently in use by another process.
1 device is currently being used by one or more other processes (e.g., Fabric Manager, CUDA application, graphics application such as an X server, or a monitoring application such as another instance of nvidia-smi). Please first kill all processes using this device and all compute applications running in the system.
nvidia-persistenced is not running (so that is not the blocking process)
Is there a way to reset the card without reboot?
I have found that I can reset the card after killing Xorg (actually I used 'systemctl isolate multi-user.target). So, obviously, somehow Xorg still interferes with the dedicated card despite no processes are listed as running on the GPU.
After the Xorg stop and card reset, I am able to use the card as usual. However, I am still hoping there is a solution that would not require Xorg restart - that’s why I have the setup with CUDA dedicated GPU in the first place…
Please check if this helps:
Check whether
sudo cat /sys/module/nvidia_drm/parameters/modeset
Returns ‘Y’, if so, run
run
grep nvidia /etc/modprobe.d/* /lib/modprobe.d/*
to find a file containing
options nvidia-drm modeset=1
and change 1 to 0
then run
sudo update-initramfs -u
and reboot.
should return ‘N’ if done right.
Furthermore, you should monitor gpu temperatures and correctly set up nvidia-persistenced in order to prevent running into the error state.
cat: /sys/module/nvidia_drm/parameters/modeset: No such file or directory
ls /sys/module/ | grep nvidia
nvidia
nvidia_modeset
nvidia_uvm
lsmod | grep nvidia
nvidia_uvm 1191936 0
nvidia_modeset 1163264 23
nvidia 39108608 1215 nvidia_uvm,nvidia_modeset
drm 630784 1 nvidia
find /sys -iname drm
/sys/kernel/btf/drm
/sys/kernel/tracing/events/drm
/sys/kernel/debug/tracing/events/drm
/sys/class/drm
/sys/module/drm
So I guess nvidia-drm is not the culprit.
I did not know that nvidia-persistenced could prevent running into the error state though, I thought the gain was just performance-wise. I have started it, lets see whether it helps indeed.
The issue still happens also if nvidia-persistenced is running. So still no way to either prevent the issue nor to sort it out without Xorg restart.
I have managed to remove all processes but Xorg from accessing the GPU:
  • lsof /dev/nvidia* returns nothing
  • fuser -v /dev/nvidia* returns just Xorg on /dev/nvidia0, /dev/nvidia1, /dev/nvidiactl, /dev/nvidia-modeset
  • nvidia-smi only shows a single process - Xorg running on card 1
Yet, reset it still not possible. So, the problem seems to be that despite nvidia-smi does not show Xorg running on card 0, it is still somehow connected to it.
Is there really no way to properly dedicate an NVIDIA card for CUDA computing? Would I have to stop using at least one NVIDIA card to achieve that? The current setup with two NVIDIA cards is almost unusable as I have to restart almost every day due to this issue.
I ahve a similar issue with an Ubuntu Linux 22.04 tower workstation, with 2 Quadro P1000 cards connected via an Akitio Duo GPU and 2 NVIDIA T1000 GPUs directly plugged on the PCIE slots.
Whenever I kicked off a CUDA program, the external GPUs would disappear from the nvidia-smi list. I applied the change suggested by @generix, and it worked without any issues for about 5-10 minutes, then 2 of the 4 GPUs disappeared, and when trying to continue executing the tasks, I got this error:
File "/home/user/miniconda3/envs/RF2/lib/python3.10/site-packages/torch/_utils.py", line 81, in _cuda
    untyped_storage = torch.UntypedStorage(
RuntimeError: CUDA error: invalid device ordinal
CUDA kernel errors might be asynchronously reported at some other API call, so the stacktrace below might be incorrect.
For debugging consider passing CUDA_LAUNCH_BLOCKING=1.
Compile with `TORCH_USE_CUDA_DSA` to enable device-side assertions.
