As the topic says, I have got a cheaper NVIDIA card that I would like to use for Xorg and an expensive NVIDIA card that I would like to use exclusively for CUDA computation. Thus far, whatever I tried, I was not able to prevent the expensive card to be used by Xorg as well, for example:
fuser -v /dev/nvidia[0-1]
shows Xorg, x11 and akonadi on both cards which is confirmed by nvidia-smi showing a small amount of memory (2MB) without doing anything on the expensive card.
Is there a way to achieve this?
EDIT: just noting that I do not care much about the 2MB but from some reason, the expensive card gets “stuck” at Xorg from time to time (showing near 100% utilization and fan running at 100% endlessly)
Many thanks for your reply, unfortunately, that did not help. I have been actually using “AutoAddGPU” “false” already and the second option did not change anything - there are still 2MB used by x11 and related processes on the CUDA card, fuser still reports kwin_x11, plasmashell etc. These are the relevant sections of my config:
Oh, fine then, many thanks. I thought that fuser showing kwin_x11 etc on both nvidia0 and nvidia1 means that both cards are used by it… but I can see a difference of mmaped mode and I am not sure whether this was the case the last time my X was frozen by the 1080 misbehaving (which I want to prevent). So for the moment I’ll just see whether it’s indeed stable now and look at your suggestion of nvidia-persistenced.
If anyone with the same problem reads this, it turns out that none of the suggestions thus far solved the problem. It’s still not completely dedicated - Xorg is still somehow connected to both cards and if an issue happens, it’s still impossible to reset the CUDA card without Xorg restart.
I have opened a new thread about it (thus far without a solution but if anything is discovered, I’ll write it there):
