Reset from UEFI makes board unbootable
When the system was reset to default from UEFI menu, it failed to boot and stuck in optee with assertion,
Hi arulpandiyan.vadivel,
Your topic is in Jetson Nano category but it seems there’s not UEFI for Jetson Nano.
Are you using Orin Nano rather than Jetson Nano?
Are you using the devkit or custom board?
It seems you hit the similar issue as Cannot boot after Reset Settings on UEFI, which should be fixed in the latest Jetpack release.
