I’m working on AGX Orin Devkit with L4T R35.5.0.
After Reset setting on UEFI, AGX Orin cannot boot.
I reset setting with following steps.
- Enter UEFI Menu.
- Select
Device Manager
→ NVIDIA Configuration
→ Reset Setting
- Go back top menu and press
Reset
to Exit.
- Disconnect AC power.
- Reconnect power and press power SW.
AGX Orin cannot boot with following error.
err.log (31.5 KB)
ASSERT [FvbNorFlashStandaloneMm] /dvs/git/dirty/git-master_linux/out/nvidia/optee.t234-uefi/StandaloneMmOptee_RELEASE/edk2-nvidia/Silicon/NVIDIA/Drivers/FvbNorFlashDxe/FvbNorFlashStandaloneMm.c(868): ((BOOLEAN)(0==1))
I tried many times and it reproduces every time.
So, I think there is a problem with Reset Setting
Is there any fix for this problem?
Hi S.Harumoto,
Is there any use case for you to use “Reset Setting”?
Please let me verify this locally and update the result to you.
No, there is not. But our customers may use it.
Therefore, if the problem cannot be fixed, I will hide “Reset Setting”.
Thanks. I will wait.
How fix this issue? How to reflash to get ride of this error?
Hi Levi_Pereira,
It is a known issue which has been resolved internally.
You will get the fix with the next Jetpack release.
Currently, please just re-flash the board to recover the state.
You can either use SDKM or flash script to re-flash your board.
system
Closed
11
