ResNet 10 model details used in Nvidia Deepstream
• Hardware Platform (Jetson / GPU): Jetson
• DeepStream Version : Any
• JetPack Version (valid for Jetson only): Any
• TensorRT Version : Any
• NVIDIA GPU Driver Version (valid for GPU only): Any
• Issue Type( questions, new requirements, bugs): Any
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing): Not a bug, so no need to reproduce
• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description): NA
I saw that Nvidia Deepstream uses ResNet 10 as an “object detection model”. I am trying to reproduce the results using a custom pipeline but with YOLO.
I would like to know, more details about ResNet 10 that is being used in deepstream. Details like,
  • Model Architecture
  • Number of parameters
  • Output tensor dimension
  • Etc
Is there any document or webpage that describes all these? I tried searching, but didn’t get any information.
Thanks & Regards,
Aravind
You can search that from the ngc.
Thanks you for the reply @yuweiw
But I didn’t find ResNet 10 details, but it contains details for ResNet 18.
AI Models - Computer Vision, Conversational AI, and More | NVIDIA NGC
Regards,
Aravind
The Deepstream caffe model is trained using detectnet_v2 with Resnet10 network and internal data. But the training was not performed using TLT/TAO because TLT/TAO is designed later.
Refer to Dataset used for training sample models.
