Hello there, i am currently trying to get collision avoidance working using resnet18, the problem is, after a while, the blocked value updates way too slowly (initially it works, after loading the model), when i run a command to see cpu and gpu usage , the cpu and gpu also work in that initial state (they get to almost 100%) and the blocked value updates and then after a while it doesnt update as often and the usages drop to almost 10% on the cpu and 0% on gpu
I do get a warning: system throttled due to over-current
what i have tried: optimising the model as much as i can for lower inference time, changing termal paste, hooking up the jetson nano to a lab bench and running it at 5v+2.5A (to get 10W), running the jetson_clocks script
I am using a jetson nano 4gb devkit with a 100mb sd card
I should also mention the DC drivers are controlled using a arduino uno via serial
this is the code i am running:
import torch
import torchvision
import torchvision.transforms as transforms
import torch.nn.functional as F
import cv2
import PIL.Image
import numpy as np
import traitlets
from IPython.display import display
import ipywidgets.widgets as widgets
import threading
from torch2trt import TRTModule
# Import Robot class and other required modules
from Robot import robot_serial
from jetcam.utils import bgr8_to_jpeg
from jetcam.csi_camera import CSICamera
import time
# Initialize the camera
camera = CSICamera(width=224, height=224, capture_width=224, capture_height=224, capture_fps=5) # Set capture_fps to 10
# Initialize the robot
robot = robot_serial()
device = torch.device('cuda')
# Initialize the model
model_trt = TRTModule()
model_trt.load_state_dict(torch.load('best_model_trt.pth'))
mean = torch.Tensor([0.485, 0.456, 0.406]).cuda().half()
std = torch.Tensor([0.229, 0.224, 0.225]).cuda().half()
normalize = transforms.Normalize(mean, std)
# Create widgets for display
image_w = widgets.Image(format='jpeg')
blocked_slider = widgets.FloatSlider(description='blocked', min=0.0, max=1.0, orientation='vertical')
speed_slider = widgets.FloatSlider(description='speed', min=0.0, max=1.0, value=0.0, step=0.01, orientation='horizontal')
# Display widgets
display(widgets.VBox([widgets.HBox([image_w, blocked_slider]), speed_slider]))
# Create a threading Event for synchronization
camera_event = threading.Event()
# Introduce frame skipping mechanism
frame_skip = 1 # Skip every 5th frame
frame_count = 0
def clamp(n, min, max):
if n < min:
return min
elif n > max:
return max
else:
return n
# Initialize cam_data and a lock for synchronization
cam_data = None
cam_data_lock = threading.Lock()
# Define the camera thread
def camera_thread():
global cam_data, frame_count
while True:
new_cam_data = camera.read()
with cam_data_lock:
cam_data = new_cam_data
image_w.value = bgr8_to_jpeg(new_cam_data)
frame_count += 1
# Signal camera update every frame_skip frames
if frame_count % frame_skip == 0:
camera_event.set()
# Start the camera thread
camera_thread = threading.Thread(target=camera_thread)
camera_thread.daemon = True
camera_thread.start()
def preprocess(image):
# Ensure the image has a correct shape (HWC) and data type (uint8)
if len(image.shape) == 4 and image.shape[0] == 1:
image = image[0]
image = PIL.Image.fromarray(image.astype('uint8'))
image = transforms.functional.to_tensor(image).to(device).half()
image.sub_(mean[:, None, None]).div_(std[:, None, None])
return image[None, ...]
# Define the main loop
def main_loop():
while True:
camera_event.wait() # Wait for camera update
start_time = time.time()
with cam_data_lock:
x = np.array([cam_data], dtype=np.uint8)
x = preprocess(x)
with torch.no_grad():
y = model_trt(x)
y = F.softmax(y, dim=1)
end_time = time.time()
inference_time = end_time - start_time
#print("Inference Time:", inference_time)
prob_blocked = float(y[0, 0])
blocked_slider.value = prob_blocked
if prob_blocked < 0.5:
robot.forward(0, clamp(int((speed_slider.value * 100) - 20), 0, 100))
else:
robot.turnLeft(0, clamp(int(speed_slider.value * 100), 0, 100), clamp(int((speed_slider.value * 100) - 10), 0, 100))
time.sleep(0.03)
# Clear the event for the next update and free up memory by deleting variables that are no longer needed.
del x, y, start_time, end_time, inference_time
torch.cuda.empty_cache()
camera_event.clear()
# Start the main loop in a separate thread
main_thread = threading.Thread(target=main_loop)
main_thread.daemon = True
main_thread.start()
sorry if what i said is confusing, english is not my main language, i will clear things up if asked
thank you!
