I am trying to use Efficientdet-d5 pretrained model from Retail Object Detection Retail Object Detection | NVIDIA NGC.
But there is an issue when trying to load the file. TAO is not recognising the encryption key ‘nvidia_tlt’
With the following training spec:
File "<frozen cv.efficientdet.model.efficientdet_module>", line 58, in __init__
File "<frozen cv.efficientdet.model.efficientdet_module>", line 117, in _load_pretrained_weights
File "<frozen cv.efficientdet.utils.helper>", line 74, in decode_eff
File "<frozen eff.core.file>", line 268, in get_handle
File "<frozen eff.core.file>", line 209, in decrypt
File "<frozen eff.core.file>", line -1, in check_decryption
PermissionError: The provided passphrase is invalid
I have tried the trainable model from v1.0 and it can load it correctly with the same encryption key.
Is there anything wrong on how the weights were encrypted?
Can you confirm that you are using TAO5.5 docker to run training?
If yes, the training spec file is not needed to contain “encryption_key”. Because since TAO 5.0 version, the encryption is deprecated.
Sorry for the delay, just getting back to this training.
Yes I can confirm I am using 5.5
docker run --rm --gpus all -v /mnt/rod_efs/:/workspace/tao-experiments nvcr.io/nvidia/tao/tao-toolkit:5.5.0-tf2 efficientdet_tf2 train -e /workspace/tao-experiments/tao/specs/train42.yaml results_dir=/workspace/tao-experiments/tao/results/training42/ num_gpus=4
=== TAO Toolkit TF2 ===
NVIDIA Release 5.5.0-TF2 (build 87841059)
TAO Toolkit Version 5.5.0
Various files include modifications (c) NVIDIA CORPORATION & AFFILIATES. All rights reserved.
Any idea?
I have also tried with the pre-trained weights from trainable_binary_v1.0/efficientdet-d5_038.tlt but I am getting a graph execution error. See the logs attached. efficentdet_d5_training_log.txt (232.0 KB)
I have changed the encryption key to nvidia-tao and the training could start.
For that particular pre-trained model it seems like you still need to specify it. Is it related to how the model was saved and or the TAO version?
I could start the training but I am getting the same execution error that I’ve posted above using pre-trained from trainable_binary_v1.0. I am attaching the logs to my reply.
Any ideas?
Thanks efficentdet_d5_training_log2.txt (245.6 KB)
