I wish to verify how to correctly create and reload my own kernel config file each time I wish to reconfigure and build the kernel.
so far:
make ARCH=arm64 O=$WORKSPACE_PATH/Out tegra_defconfig
make ARCH=arm64 O=$WORKSPACE_PATH/Out menuconfig
modifying configuration and save as new_config.
the file is being saved as $WORKSPACE_PATH/Out/new_config
now, next time I wish to reconfigure the kernel before build with my new_config, what do I do?
skip (1) and use (2) with new_config as argument?
in addition, how do i make sure my new_config file will be used and not some old .config file wile rebuilding the kernel?
I think you just run Step 3 next time you want to re-build the kernel.
I’m not sure what you get confused with.
Thank you for your answer. I’ll try to elaborate:
On step 2, the graphical menuconfig app is opened with some default configuration.
I wish to open the menuconfig app again, “continue where i left” and not start again from the defaults values before i made my changes.
I don’t feel like that’s supported in Linux kernel.
Contents of menuconfig is determined by /arch/$(CPU architecture being used)/Kconfig, so it’d always show the same thing each time you run it.
But when I execute the following command:
it somehow load some default configuration each time I’ll open menuconfig.
So my logic says I need to create and update my own version of tegra_defconfig?
that way I’ll execute
make ARCH=arm64 O=$WORKSPACE_PATH/Out tegra_defconfig_latest
and my recent values will be restored
Oh Yes, I think you are right here.
Populate you own tegra_defconfig then run these:
bsp_dev
October 24, 2023, 11:06am
8
thanks.
I used make savedefconfig
system
Closed
November 20, 2023, 2:18am
10
