Sorry, just I wanted to keep here clean.
I should mention that here the code is for LU decomposition, and each pages contain a partiton of columns.
template<int TX, int NPAGES>
__global__ void
sgetf2_native_kernel( int m, int n,
magmaFloat_ptr dA, int ldda,
volatile magma_int_t *ipiv, int gbstep,
volatile int* update_flag,
volatile magma_int_t *info)
#ifdef MAGMA_HAVE_CUDA
const int tx = threadIdx.x;
const int bx = blockIdx.x;
float rA[NPAGES] = {MAGMA_S_ZERO};
float rx, rx_max;
magmaFloat_ptr da = dA;
int rx_id, max_id, flag = 0, linfo;
float rx_abs = 0.0, rx_abs_max = 0.0;
const int m_ = m-(NPAGES-1)*TX;
if( bx >= n ) return;
// read the info (if it is set to non-zero a previous panel, then we don't set it again)
linfo = (int)(*info);
__shared__ float sx[ TX ];
__shared__ float sabs[ TX ];
__shared__ int smax_id[ TX ];
__shared__ float sreg;
// read
dA += bx * ldda + tx;
#pragma unroll
for(int i = 0; i < NPAGES-1; i++){
rA[i] = dA[ i * TX ];
if( tx < m_){
rA[NPAGES-1] = dA[ (NPAGES-1) * TX ];
// main loop
#pragma unroll
for(int i = 0; i < n; i++){
// isamax and write pivot for the ith thread block
if(bx == i){
rx_max = rx = (tx < i) ? MAGMA_S_ZERO : rA[0];
rx_abs_max = rx_abs = fabs(MAGMA_S_REAL(rx)) + fabs(MAGMA_S_IMAG(rx));
max_id = rx_id = tx;
#pragma unroll
for(int j = 1; j < NPAGES; j++){
rx = rA[j];
if ( rx_abs > rx_abs_max ){
rx_max = rx;
rx_abs_max = rx_abs;
max_id = j * TX + tx;
sx[ tx ] = rx_max;
sabs[ tx ] = rx_abs_max;
smax_id[ tx ] = max_id;
__syncthreads();
// let the first warp do the final reduction step
if(tx < 32){
#pragma unroll
for(int j = 0; j < TX; j+= 32){
rx = sx[ j + tx ];
rx_abs = sabs[ j + tx ];
rx_id = smax_id[ j + tx ];
rx_max = rx;
max_id = rx_id;
magmablas_syncwarp();
sx[ tx ] = rx_max;
#pragma unroll
for(int j = 0; j < 32; j++){
rx = sx[j];
rx_abs = sabs[j];
rx_id = smax_id[j];
rx_max = rx;
max_id = rx_id;
if(tx == 0){
sx[ 0 ] = rx_max;
sabs[ 0 ] = rx_abs_max;
smax_id[ 0 ] = (rx_abs_max == MAGMA_D_ZERO) ? i : max_id;
__syncthreads();
rx_max = sx[ 0 ];
rx_abs_max = sabs[ 0 ];
max_id = smax_id[ 0 ];
__syncthreads();
// now every thread in the i^th block has the maximum
linfo = (rx_abs_max == MAGMA_D_ZERO && linfo == 0) ? (max_id+gbstep+1) : linfo;
if( tx == 0){
//printf("[%2d]: bx = %d, max_id, = %d, rx_abs_max = %f, linfo = %d\n", i, bx, max_id, rx_abs_max, linfo);
magmablas_iatomic_exchange((magma_int_t*)info, (magma_int_t)(linfo) );
magmablas_iatomic_exchange((magma_int_t*)&ipiv[i], (magma_int_t)(max_id+1) ); // fortran indexing
__syncthreads();
//if( rx_abs_max == MAGMA_D_ZERO )return;
else{ // other thread blocks are waiting
if(tx == 0){
max_id = 0;
while( max_id == 0 ){
max_id = ipiv[i];
smax_id[ 0 ] = max_id;
__syncthreads();
max_id -= 1; // revert fortran indexing
linfo = (*info);
__syncthreads();
//if( (*info) != 0 ) return;
// swap
// swap always happens between page 0 and page x
// to avoid spilling rA to local memory, we use shared memory
if( max_id != i){
// all blocks swap in registers
// for bx < i, the column is already written in memory,
// but we have a copy in reg., so continue to swap in reg.,
// and do one final write to memory
#pragma unroll
for(int j = 0; j < NPAGES; j++){
if( j == (max_id/TX) ){
sx[ tx ] = rA[j];
__syncthreads();
if( tx == i ){
float tmp = sx[ max_id%TX ];
sx[ max_id%TX ] = rA[0];
rA[0] = tmp;
__syncthreads();
if( tx == max_id%TX ){
rA[j] = sx[ tx ];
__syncthreads();
//__syncthreads();
// the ith block does scal
if(bx == i){
float reg = (rx_max == MAGMA_S_ZERO) ? MAGMA_S_ONE : MAGMA_S_DIV(MAGMA_S_ONE, rx_max );
// scal
if( tx > i ){
rA[0] *= reg;
#pragma unroll
rA[j] *= reg;
// write column i to global memory
#pragma unroll
for(int j = 0; j < NPAGES-1; j++){
dA[ j * TX ] = rA[j];
if( tx < m_){
dA[ (NPAGES-1) * TX ] = rA[NPAGES-1];
__threadfence(); __syncthreads(); // after cuda 9.0, both are needed, not sure why
if(tx == 0) magmablas_iatomic_exchange( (int *)&update_flag[ i ], 1);
// thread blocks with ID larger than i perform ger
if(bx > i){
if( tx == i ){
sreg = rA[0];
// wait for scal
if( tx == 0){
flag = 0;
while( flag == 0 ){
flag = update_flag[ i ];
__syncthreads();
float reg = sreg;
if( NPAGES == 1){
if(tx > i && tx < m_){
rA[0] -= da[ i * ldda + tx ] * reg;
}else{
if(tx > i){
#pragma unroll
for(int j = 1; j < NPAGES-1; j++){
rA[j] -= da[ i * ldda + j * TX + tx ] * reg;
if( NPAGES > 1){
if( tx < m_ ){
rA[ NPAGES-1 ] -= da[ i * ldda + (NPAGES-1)*TX + tx ] * reg;
// all blocks write their columns again except the last one
if( bx < n-1 ){
#pragma unroll
dA[ i * TX ] = rA[i];
if( tx < m_){
#endif // MAGMA_HAVE_CUDA
extern "C" magma_int_t
magma_sgetf2_native_fused(
magma_int_t m, magma_int_t n,
magmaFloat_ptr dA, magma_int_t ldda,
magma_int_t *ipiv, magma_int_t gbstep,
magma_int_t *flags,
magma_int_t *info, magma_queue_t queue )
magma_int_t arginfo = 0;
const magma_int_t ntx = SGETF2_FUSED_NTH;
if( m < n || m > SGETF2_FUSED_MAX_M ){
arginfo = -1;
else if( n > magma_getdevice_multiprocessor_count() ){
arginfo = -2;
else if( ldda < max(1, m) ){
arginfo = -4;
if (arginfo != 0) {
magma_xerbla( __func__, -(arginfo) );
return arginfo;
magma_int_t arch = magma_getdevice_arch();
dim3 grid(n, 1, 1);
dim3 threads(ntx, 1, 1);
const magma_int_t npages = magma_ceildiv(m, ntx);
// the kernel uses communication among thread blocks
// as a safeguard, force one thread block per multiprocessor
// by allocating more than half the shared memory
magma_int_t shmem = magma_getdevice_shmem_block();
shmem = (shmem / 2);
int *update_flag = (int*) flags; // update_flag is an int, not magma_int_t
size_t max_n_npages = max(n,npages);
sgetf2_native_init_kernel<<< 1, max_n_npages, 0, queue->cuda_stream() >>>( n, npages, ipiv, update_flag);
// The case statement should cover up to ( xGETF2_CHAIN_MAX_M / ntx )
switch(npages){
case 1: sgetf2_native_kernel< ntx, 1><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 2: sgetf2_native_kernel< ntx, 2><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 3: sgetf2_native_kernel< ntx, 3><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 4: sgetf2_native_kernel< ntx, 4><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 5: sgetf2_native_kernel< ntx, 5><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 6: sgetf2_native_kernel< ntx, 6><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 7: sgetf2_native_kernel< ntx, 7><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 8: sgetf2_native_kernel< ntx, 8><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 9: sgetf2_native_kernel< ntx, 9><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 10: sgetf2_native_kernel< ntx, 10><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 11: sgetf2_native_kernel< ntx, 11><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 12: sgetf2_native_kernel< ntx, 12><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 13: sgetf2_native_kernel< ntx, 13><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 14: sgetf2_native_kernel< ntx, 14><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 15: sgetf2_native_kernel< ntx, 15><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 16: sgetf2_native_kernel< ntx, 16><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 17: sgetf2_native_kernel< ntx, 17><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 18: sgetf2_native_kernel< ntx, 18><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 19: sgetf2_native_kernel< ntx, 19><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 20: sgetf2_native_kernel< ntx, 20><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
#if defined(PRECISION_s) || defined(PRECISION_d)
case 21: sgetf2_native_kernel< ntx, 21><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 22: sgetf2_native_kernel< ntx, 22><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 23: sgetf2_native_kernel< ntx, 23><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 24: sgetf2_native_kernel< ntx, 24><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 25: sgetf2_native_kernel< ntx, 25><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 26: sgetf2_native_kernel< ntx, 26><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 27: sgetf2_native_kernel< ntx, 27><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 28: sgetf2_native_kernel< ntx, 28><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 29: sgetf2_native_kernel< ntx, 29><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 30: sgetf2_native_kernel< ntx, 30><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 31: sgetf2_native_kernel< ntx, 31><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 32: sgetf2_native_kernel< ntx, 32><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 33: sgetf2_native_kernel< ntx, 33><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 34: sgetf2_native_kernel< ntx, 34><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 35: sgetf2_native_kernel< ntx, 35><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 36: sgetf2_native_kernel< ntx, 36><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 37: sgetf2_native_kernel< ntx, 37><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 38: sgetf2_native_kernel< ntx, 38><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 39: sgetf2_native_kernel< ntx, 39><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 40: sgetf2_native_kernel< ntx, 40><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 41: sgetf2_native_kernel< ntx, 41><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 42: sgetf2_native_kernel< ntx, 42><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 43: sgetf2_native_kernel< ntx, 43><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 44: sgetf2_native_kernel< ntx, 44><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 45: sgetf2_native_kernel< ntx, 45><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 46: sgetf2_native_kernel< ntx, 46><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
#endif // defined(PRECISION_s) || defined(PRECISION_d)
case 47: sgetf2_native_kernel< ntx, 47><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 48: sgetf2_native_kernel< ntx, 48><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 49: sgetf2_native_kernel< ntx, 49><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 50: sgetf2_native_kernel< ntx, 50><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 51: sgetf2_native_kernel< ntx, 51><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 52: sgetf2_native_kernel< ntx, 52><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 53: sgetf2_native_kernel< ntx, 53><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 54: sgetf2_native_kernel< ntx, 54><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 55: sgetf2_native_kernel< ntx, 55><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 56: sgetf2_native_kernel< ntx, 56><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 57: sgetf2_native_kernel< ntx, 57><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 58: sgetf2_native_kernel< ntx, 58><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 59: sgetf2_native_kernel< ntx, 59><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 60: sgetf2_native_kernel< ntx, 60><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 61: sgetf2_native_kernel< ntx, 61><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 62: sgetf2_native_kernel< ntx, 62><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 63: sgetf2_native_kernel< ntx, 63><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 64: sgetf2_native_kernel< ntx, 64><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 65: sgetf2_native_kernel< ntx, 65><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 66: sgetf2_native_kernel< ntx, 66><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 67: sgetf2_native_kernel< ntx, 67><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 68: sgetf2_native_kernel< ntx, 68><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 69: sgetf2_native_kernel< ntx, 69><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 70: sgetf2_native_kernel< ntx, 70><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 71: sgetf2_native_kernel< ntx, 71><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 72: sgetf2_native_kernel< ntx, 72><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 73: sgetf2_native_kernel< ntx, 73><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 74: sgetf2_native_kernel< ntx, 74><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 75: sgetf2_native_kernel< ntx, 75><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 76: sgetf2_native_kernel< ntx, 76><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 77: sgetf2_native_kernel< ntx, 77><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 78: sgetf2_native_kernel< ntx, 78><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 79: sgetf2_native_kernel< ntx, 79><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
case 80: sgetf2_native_kernel< ntx, 80><<<grid, threads, shmem, queue->cuda_stream() >>>( m, n, dA, ldda, ipiv, gbstep, update_flag, info); break;
default: printf("size not supported \n");
return 0;
