I’m using Jetson nano.
I want to connect bluetooth module hc-06.
After Bluetooth pairing, I tried to bind rfcomm for connection.
But I see “rfcomm tty support is not available” error message.
I can i solve it???
Hi kim19707,
So the bluetooth module hc-06 was connected on Nano? Which Bluetooth client you paired? Have you ever tried it on other device?
I can’t help to provide suggestions due to issue seems not specific to Nano, you may google it to find the answer.
No, not connected. Nano has another bluetooth module. hc-06 is connected on Arduino.
Hi, Kim19707
Kindly refer the followed link. For your case it should be helpful.
