It seems that with the release of Kernel 4.18.0-553.62.1.el8_10.x86_64 it started breaking 3rd party applications that relies on DOCA. Such as the BeeGFS Client. The same issue can be replicated with the latest 3.0.0 DOCA and the latest 2.9.3 LTS DOCA releases. When trying to compile BeeGFS Client Module with this combination: DOCA (2.9.3 or 3.0.0) and Kernel 4.18.0-553.62.1.el8_10.x86_64 and up, this happens:
/etc/init.d/beegfs-client rebuild
- BeeGFS module autobuild
$OFED_INCLUDE_PATH =
$OFED_INCLUDE_PATH = [/usr/src/ofa_kernel/default/include]
Building beegfs client module
feature detection gives: -DKERNEL_HAS_INODE_ATIME -DKERNEL_HAS_DENTRY_SUBDIRS -DKERNEL_HAS_SCHED_SIG_H -DKERNEL_HAS_STATX -DKERNEL_HAS_KREF_READ -DKERNEL_HAS_FILE_DENTRY -DKERNEL_HAS_SUPER_SETUP_BDI_NAME -DKERNEL_HAS_KERNEL_READ -DKERNEL_HAS_SKWQ_HAS_SLEEPER -DKERNEL_HAS_CURRENT_TIME_SPEC64 -DKERNEL_WAKE_UP_SYNC_KEY_HAS_3_ARGUMENTS -DKERNEL_HAS_GET_FS -DKERNEL_HAS_IOV_ITER_KVEC_NO_TYPE_FLAG_IN_DIRECTION -DKERNEL_HAS_PRINT_STACK_TRACE -DKERNEL_HAS_SOCKPTR_T -DKERNEL_HAS_TIME64 -DKERNEL_HAS_KTIME_GET_TS64 -DKERNEL_HAS_KTIME_GET_REAL_TS64 -DKERNEL_HAS_KTIME_GET_COARSE_REAL_TS64 -DKERNEL_HAS_GENERIC_FILE_SPLICE_READ -DKERNEL_HAS_GENERIC_PERMISSION_2 -DKERNEL_HAS_SETATTR_PREPARE -DKERNEL_HAS_GET_ACL -DKERNEL_HAS_SET_ACL -DKERNEL_HAS_FOPS_ITERATE -DKERNEL_HAS_XATTR_HANDLERS_INODE_ARG
In file included from ./include/linux/mmzone.h:10,
from ./include/linux/gfp.h:6,
from /usr/src/ofa_kernel/default/include/linux/gfp.h:6,
from ./include/linux/slab.h:15,
from /usr/src/ofa_kernel/default/include/linux/slab.h:6,
from ./include/linux/crypto.h:24,
from ./include/crypto/hash.h:16,
from ./include/linux/uio.h:16,
from ./include/linux/socket.h:8,
from ./include/uapi/linux/if.h:25,
from /usr/src/ofa_kernel/default/include/linux/compat-2.6.h:11,
./include/linux/spinlock.h:524:45: error: expected ‘)’ before ‘(’ token
DEFINE_LOCK_GUARD_1_COND(raw_spinlock, _try, raw_spin_trylock(_T->lock))
In file included from ./include/linux/irqflags.h:16,
from ./arch/x86/include/asm/processor.h:35,
from ./arch/x86/include/asm/cpufeature.h:5,
from ./arch/x86/include/asm/thread_info.h:53,
from ./include/linux/thread_info.h:39,
from ./include/linux/uio.h:15,
/usr/src/ofa_kernel/default/include/linux/cleanup.h:148:3: warning: data definition has no type or storage class
} class_##_name##_t; \
/usr/src/ofa_kernel/default/include/linux/cleanup.h:174:1: note: in expansion of macro ‘__DEFINE_UNLOCK_GUARD’
__DEFINE_UNLOCK_GUARD(_name, _type, _unlock, _VA_ARGS_) \
./include/linux/spinlock.h:526:1: note: in expansion of macro ‘DEFINE_LOCK_GUARD_1’
DEFINE_LOCK_GUARD_1(raw_spinlock_nested, raw_spinlock_t,
/usr/src/ofa_kernel/default/include/linux/cleanup.h:148:3: error: type defaults to ‘int’ in declaration of ‘class_raw_spinlock_nested_t’ [-Werror=implicit-int]
/opt/beegfs/src/client/client_module_7/build/../source/common/nodes/NodeTree.h:56:11: note: in expansion of macro ‘rb_entry’
return rb_entry(this->value, Node, \_nodeTree.rbTreeElement);
cc1: some warnings being treated as errors
make[3]: *** [scripts/Makefile.build:318: /opt/beegfs/src/client/client_module_7/build/../source/net/filesystem/FhgfsOpsCommKit.o] Error 1
make[3]: *** [scripts/Makefile.build:318: /opt/beegfs/src/client/client_module_7/build/../source/net/filesystem/FhgfsOpsRemoting.o] Error 1
make[2]: *** [Makefile:1619: _module_/opt/beegfs/src/client/client_module_7/build/../source] Error 2
make[1]: *** [Makefile:200: module] Error 2
make: *** [AutoRebuild.mk:34: auto_rebuild] Error 2
That seems to be a complex issue that involves Red Hat and NVIDIA. But if we remove DOCA from the equation everything works, so it nails down to DOCA.
