Hardware - GPU (V100 [16gb])
Hardware - CPU (XENON E5-2686 V4)
Operating System -
Riva Version (1.8.0b0)
How to reproduce the issue? (This is for errors. Please share the command and the detailed log here)
Context;
Our problem occurs on the front-end while we are trying to stream microphone input via Python FAST API.
- Riva (1.8.0b0) backend (available, working)
- Using a Websocket wrapper to stream microphone input to the Riva backend
- Example
transcribe_mic.pyis working well. However, when we use MediaRecorder on the frontend we receiveUNIMPLEMENTEDerror.
35073 ERROR api:websocket_endpoint:119 - Inference error: <_MultiThreadedRendezvous of RPC that terminated with:
status = StatusCode.UNIMPLEMENTED
details = “”
debug_error_string = “{”created”:“@1641310613.864265000”,“description”:“Error received from peer ipv4:3.145.17.11:8001”,“file”:“src/core/lib/surface/call.cc”,“file_line”:1075,“grpc_message”:“”,“grpc_status”:12}”
- We examined the data both incoming from
Python PyAudio dataandMediaRecorderdata, and;
x00\x00\xfc\xff\xf8\xff\xf7\xff\xf9\xff\xfa\xff\xf8\xff\xf7\xff\xfa\xff\xfd\xff\xfe\xff\xfe\xff\xfd → PyData
\x00\x00\x00\x1cftypiso5\x00\x00\x00\x01isomiso5hlsf\x00\x00\x02Hmoov\x00\x00\x00lmvhd\x00\x00\x00\x00\xdd\xf8\xff{\xdd\xf8\xff → MediaRecorder
The way we handle the incoming data,
@app.websocket(“/ws”)
async def websocket_endpoint(websocket: WebSocket):
await websocket.accept()
while True:
data = await websocket.receive_bytes()
## send data to Riva backend (StreamingRecognize)
<!DOCTYPE html>
<html lang=“en”>
<head>
<meta charset=“UTF-8">
<title>Title</title>
</head>
<body>
<h1>helloworld</h1>
<script>
var ws = new WebSocket(“ws://localhost:8000/ws”, ‘echo-protocol’);
navigator.mediaDevices.getUserMedia({ audio: true })
.then(stream => {
const mediaRecorder = new MediaRecorder(stream);
mediaRecorder.start(5000);
mediaRecorder.addEventListener(“dataavailable”, event => {
console.log(“sending audio”);
const audioBlob = new Blob([event.data], {type: ‘audio/mp3’});
ws.send(audioBlob);
console.log(“sent audio”);
</script>
</body>
</html>
Any recommendations for a work-around?
Thanks in advance!
