Hi I just followed the tutorial for Deploy Riva at Scale on AWS with EKS.
And when it reaches installing riva-api on helm by “helm install riva-api riva-api …” and then the triton0 pod will just failed to init, showing Error: Invalid apikey
The log is as follow:
I’ve set all the keys and credential, not sure if it’s the same issue as this
Does someone know why this happens and how to fix it, or any alternatives? Thanks in advance. (I really wan to test and use Riva!!)
