Hardware - GPU (T4)
Hardware - CPU
Operating System: Amazon Linux 2 (AWS ECS Optimized GPU Image)
Riva Version: 1.10.0b0
I’m trying to build a model using riva-build
and riva-deploy
commands following the instructions from the official documentation.
I am able to build models successfully, however, during deployment when I try to perform inference, I get the following error:
E0328 15:41:25.798205 645 grpc_riva_asr.cc:771] Triton client received error: in ensemble '<model-name>-streaming', unexpected shape for input 'audio_signal' for model 'riva-trt-<model-name>-streaming-am-streaming'. Expected [-1,80,460], got [1,80,461]
E0328 15:41:25.798382 236 grpc_riva_asr.cc:1116] ASRService.StreamingRecognize returning failure
This seems to occur for some configurations but not for others (Ex. chunk size, padding size).
Any idea why the input shape might be off by 1?
I was able to find certain configurations where Riva either returns no text back or the error above.
Everything else is default, or what was provided in the official docs:
Config Set 1:
- chunk_size: 0.6
- left_padding_size: 3.0
- right_padding_size: 1.6, 2.4 (So either one of these basically)
- vad_start_history: 300
- vad_start_th: 0.2
- vad_stop_history: 1600
- vad_stop_th: 0.98
Config Set 2:
- chunk_size: 0.7
- right_padding_size: 2.4
- vad_start_th: 0.2
- vad_stop_history: 1600, 2000
- vad_stop_th: 0.98
Config Set 3:
- chunk_size: 0.8
- right_padding_size: 0.7, 0.8
- vad_start_th: 0.2
- vad_stop_th: 0.98
Configs that do work however:
Config Set 1:
- chunk_size: 0.5, 0.8
- vad_start_th: 0.2
- vad_stop_th: 0.98
What is the reason for this?
Hi @pineapple9011 ,
Thanks for your interest in Riva,
I will check regarding this issue/error with the team and will provide an update soon,
