I’ve recently started using version 14.6 (updated from 13.7) of the PGI compiler and am attempting to make use of the routine directive included in OpenACC 2.0. However, although running pgfortran -V confirms that I am indeed using version 14.6, it claims that function and procedure calls are not supported:
[esauer2@gauss ~]$ pgfortran -Minfo -ta=nvidia,cuda5.5 example.f95
foo:
1, Generating acc routine vector
7, !$acc loop ! threadidx%x
1, Generating Tesla code
PGF90-S-0155-Accelerator region ignored; see -Minfo messages (example.f95: 24)
test:
24, Accelerator region ignored
25, Accelerator restriction: function/procedure calls are not supported
26, Accelerator restriction: unsupported call to 'foo'
0 inform, 0 warnings, 1 severes, 0 fatal for test
The example code I’m trying is the following:
subroutine foo(v, i, n)
!$ACC ROUTINE VECTOR
real, dimension(1:100, 1:100) :: v
integer :: i, n, j
!$ACC LOOP VECTOR
do j=1,n
v(i,j) = 1.0/(i*j)
write(*,*)v(i,j)
enddo
end subroutine
program test
integer :: i, j, n
n=100
do i=1,n
do j=1,n
v(i,j) = 2
enddo
enddo
!$ACC PARALLEL LOOP
do i=1,n
call foo(v,i,n)
enddo
!$ACC END PARALLEL LOOP
end program
This is very similar to the code described here:
http://devblogs.nvidia.com/parallelforall/7-powerful-new-features-openacc-2-0/
I’m still learning, so sorry if I’ve made some obvious mistake.
Best,
Ethan
