RS-232 Communication Issue on Jetson (JetPack 5.1.2) – No Signal on TX Pin
Dear NVIDIA Support,
I’m currently testing RS-232 communication on a custom Jetson carrier board running JetPack 5.1.2. However, I am not observing any voltage change on the TX line (SODIMM Pin 99) when sending data. Below are the details of my environment and what I’ve tried so far:
■ Environment
  • JetPack version: 5.1.2
  • Board: Custom carrier board with Jetson module
  • Pin in use: SODIMM Pin 99 (UART0_TXD)
■ What I’ve done
  1. Added user to dialout group:
    sudo adduser $USER dialout
  2. Disabled nvgetty:
    sudo systemctl disable nvgetty.service
  3. Verified active UARTs with:
    sudo dmesg | grep -i tty
    → Confirmed ttyTHS0 is listed and corresponds to UART0
  4. Sent test string to UART0 TX:
    echo "hello" > /dev/ttyTHS0
  5. Confirmed that GPIO level on Pin 99 can be toggled using gpioset (so the pin is physically responsive)
■ Pinmux Configuration
The pinmux settings for UART0_TXD and UART0_RXD are default (UB3_TXD, UB3_RXD), as shown in the attached screenshot and pinmux.dtsi. The UART0 function appears to be correctly assigned.
■ Problem
Despite all the above steps, there is no signal change or voltage output observed on SODIMM Pin 99 when sending data via /dev/ttyTHS0.
■ Question
Is there any additional step required in JetPack 5.1.2 or pinmux configuration to fully enable UART0 for RS-232 level communication?
Do I need to check anything else in the device tree or kernel configuration?
Thank you very much for your support.
Orin-nabel-pinmux.txt (65.8 KB)
Hi SS.nb,
It seems you are using serial interface from M.2 Key E port.
Have you verified UART loopback test for this interface?
As my understanding, SODIMM Pin 99 (UART0_TXD) should be uart-b, which maps to 3110000.serial.
Please enable this node(serial@3110000) in device tree.
Thank you for your response.
Sorry for the confusion — I’m not trying to use the serial interface from the M.2 Key E port.
My goal is to use the UART for external RS-232 communication with another device, not for internal debugging or M.2.
Instead of a loopback test, I am observing the TX pin (SODIMM Pin 99) with an oscilloscope to confirm whether there is any voltage change during transmission.
I have configured the pinmux settings using the official spreadsheet tool as previously shown (UB3_TXD / UB3_RXD), but I’m wondering if this alone is not sufficient.
Should I also enable a specific serial node (e.g. serial@3100000 or serial@3110000) in the device tree explicitly for this to work?
Any advice would be appreciated.
Thank you for your previous responses.
I was able to get the UART TX pin working by explicitly modifying the Device Tree as follows:
Environment
  • JetPack Version: 5.1.2
  • Board: Custom carrier board for Jetson Orin
1. Device Tree modification
File location:
/Linux_for_Tegra/source/public/hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-uart.dtsi
I changed the serial@3110000 node (UARTB, /dev/ttyTHS1) to:
serial@3110000 {
    status = "okay";
Then I rebuilt and flashed the kernel. After this change, the TX pin output started working as expected.
However, I couldn’t find this requirement explicitly documented in the Jetson Linux Developer Guide or official pinmux/DT overlay workflows.
  • Is there any official documentation or reference that describes this step?
  • Or is there a more standard/clean way to enable UARTB for external RS-232 communication?
Any guidance or clarification would be greatly appreciated.
The serial interface and the mapping may differ due to the releases.
You can refer to 9.7 Universal Asynchronous Receiver/Transmitter(UART) in official Technical Reference Manual document for details, Or https://elinux.org/Jetson/L4T/peripheral/#Mapping_3 for the mappings.
We would suggest also checking the dmesg and device tree for the current status.
