Orin NX UART0 测试 RS232 失败
你好,
Orin NX UART1->/dev/ttyTHS0 ,UART0是多少?我们在系统中看到还有/dev/ttyTHS3, /dev/ttyTHS4,UART0是对应其中的一个吗?我们进行了这两个节点的测试,依然测试不通RS-232.
Hi 814294789,
What UART cable are you using?
We’re using TX/RX cable, connect usb cable from host to Jetson J14 pin header (TX/RX/GND).
Then we can use /dev/ttyUSB* to enable UART.
你好,
我们是将TX RX短接,CTS RTS短接,采用自发自收的方式进行测试的。目前不清楚UART0映射的是/dev/ttyTHS3还是/dev/ttyTHS4?如果UART0映射的是上面两个节点中的一个,我们进行测试的结果是都失败。
Please refer to the device tree file here.
hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-uart.dtsi
You can use the Orin NX design guide to find out the mapping.
For example, pin #99,101,103,150 is UART0 on module. But the SOC signal is UART2, thus, you need to refer to uart b in the device tree dtsi.
Could you paste link about the Orin NX design guide at here?
You can search it on the download center.
I resolved it. In Jetpack5.1_R35.2.1 for Jetson Orin nx, enable serial@3110000 , then /dev/ttyTHS1 created, RS232 worked.
你好,
很抱歉现在才回复,我们还没有解决,请将你打开@3110000的位置发出来参考一下!谢谢
非常感谢!
