Not sure. Probably the memory is not released and after some time it is not able to allocate new memory.
Hi DaneLLL,
How to implement the logic for multiple camera streams. I suppose the solution is for single camera streams. For instance, if there are two camera streams with same input resolution then what changes might need to be done to the code above? From my understanding, the following change will suffice. Please correct if I am wrong.
surface->surfaceList[0] ----> surface->surfaceList[1]
Here is an example of running two rtsp sources.
For two sources, batch-size has to be set to two and surfaceList[0] is source0, surfaceList[1] is source1.
Hi DaneLLL,
I tried your suggestion. I also referred the documentation for providing appropriate parameters. I could understand that I need to pass -1 for computation of all buffers. However, I am still unable to get the output for second stream. I get null pointer for “dst_surface->surfaceList[1].mappedAddr.addr[0]” using these parameters. Please find my code below:
* Buffer probe function after tracker.
static GstPadProbeReturn
tracking_done_buf_prob (GstPad * pad, GstPadProbeInfo * info, gpointer u_data)
NvDsInstanceBin *bin = (NvDsInstanceBin *) u_data;
guint index = bin->index;
AppCtx *appCtx = bin->appCtx;
GstBuffer *buf = (GstBuffer *) info->data;
std::vector<std::string> frame_data;
GstClockTime timestamp = buf->pts;
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
if (!batch_meta) {
NVGSTDS_WARN_MSG_V ("Batch meta not found for buffer %p", buf);
return GST_PAD_PROBE_OK;
curr_timepoint = std::chrono::high_resolution_clock::now();
std::chrono::duration<double> time_span =
std::chrono::duration_cast<std::chrono::duration<double>>
(curr_timepoint - prev_timepoint);
if(time_span.count() > time_interval_secs)
#if 1
GstMapInfo in_map_info;
NvBufSurface *surface = NULL;
memset (&in_map_info, 0, sizeof (in_map_info));
if (!gst_buffer_map (buf, &in_map_info, GST_MAP_READ)) {
g_print ("Error: Failed to map gst buffer\n");
gst_buffer_unmap (buf, &in_map_info);
cudaError_t cuda_err;
NvBufSurfTransformRect src_rect, dst_rect;
surface = (NvBufSurface *) in_map_info.data;
int batch_size= surface->batchSize;
printf("\nBatch Size : %d, resolution : %dx%d \n",batch_size,
surface->surfaceList[0].width, surface->surfaceList[0].height);
src_rect.top = 0;
src_rect.left = 0;
src_rect.width = (guint) surface->surfaceList[0].width;
src_rect.height= (guint) surface->surfaceList[0].height;
dst_rect.top = 0;
dst_rect.left = 0;
dst_rect.width = (guint) surface->surfaceList[0].width;
dst_rect.height= (guint) surface->surfaceList[0].height;
NvBufSurfTransformParams nvbufsurface_params;
nvbufsurface_params.src_rect = &src_rect;
nvbufsurface_params.dst_rect = &dst_rect;
nvbufsurface_params.transform_flag = NVBUFSURF_TRANSFORM_CROP_SRC |
NVBUFSURF_TRANSFORM_CROP_DST;
nvbufsurface_params.transform_filter = NvBufSurfTransformInter_Default;
NvBufSurface *dst_surface = NULL;
NvBufSurfaceCreateParams nvbufsurface_create_params;
/* An intermediate buffer for NV12/RGBA to BGR conversion will be
* required. Can be skipped if custom algorithm can work directly on NV12/RGBA. */
nvbufsurface_create_params.gpuId = surface->gpuId;
nvbufsurface_create_params.width = (gint) surface->surfaceList[0].width;
nvbufsurface_create_params.height = (gint) surface->surfaceList[0].height;
nvbufsurface_create_params.size = 0;
nvbufsurface_create_params.colorFormat = NVBUF_COLOR_FORMAT_RGBA;
nvbufsurface_create_params.layout = NVBUF_LAYOUT_PITCH;
nvbufsurface_create_params.memType = NVBUF_MEM_DEFAULT;
cuda_err = cudaSetDevice (surface->gpuId);
cudaStream_t cuda_stream;
cuda_err=cudaStreamCreate (&cuda_stream);
int create_result = NvBufSurfaceCreate(&dst_surface,batch_size,
&nvbufsurface_create_params);
NvBufSurfTransformConfigParams transform_config_params;
NvBufSurfTransform_Error err;
transform_config_params.compute_mode = NvBufSurfTransformCompute_Default;
transform_config_params.gpu_id = surface->gpuId;
transform_config_params.cuda_stream = cuda_stream;
err = NvBufSurfTransformSetSessionParams (&transform_config_params);
//NvBufSurfaceMemSet (dst_surface, 0, 0, 0);
NvBufSurfaceMemSet (dst_surface, -1, -1, 0);
err = NvBufSurfTransform (surface, dst_surface, &nvbufsurface_params);
if (err != NvBufSurfTransformError_Success) {
g_print ("NvBufSurfTransform failed with error %d while converting buffer\n", err);
//NvBufSurfaceMap (dst_surface, 0, 0, NVBUF_MAP_READ);
NvBufSurfaceMap (dst_surface, -1, -1, NVBUF_MAP_READ);
//NvBufSurfaceSyncForCpu (dst_surface, 0, 0);
NvBufSurfaceSyncForCpu (dst_surface, -1, -1);
cv::Mat bgr_frame = cv::Mat (cv::Size(nvbufsurface_create_params.width,
nvbufsurface_create_params.height), CV_8UC3);
for(int cam_id = 0 ; cam_id < batch_size ; ++cam_id)
cv::Mat in_mat =
cv::Mat (nvbufsurface_create_params.height,
CV_8UC4, dst_surface->surfaceList[cam_id].mappedAddr.addr[0],
dst_surface->surfaceList[cam_id].pitch);
cv::cvtColor (in_mat, bgr_frame, CV_RGBA2BGR);
std::vector<uchar> encode_buffer;
cv::imencode(".jpg",bgr_frame,encode_buffer);
std::string encoded_jpeg;
auto base64_jpeg = reinterpret_cast<const unsigned char*>
(encode_buffer.data());
encoded_jpeg = base64_encode(base64_jpeg, encode_buffer.size());
frame_data.push_back(encoded_jpeg);
NvBufSurfaceUnMap (dst_surface, 0, 0);
NvBufSurfaceDestroy (dst_surface);
cudaStreamDestroy (cuda_stream);
#endif
* Output KITTI labels with tracking ID if configured to do so.
write_kitti_track_output(appCtx, batch_meta);
if (appCtx->primary_bbox_generated_cb)
appCtx->primary_bbox_generated_cb (appCtx, buf, batch_meta, index);
Kindly help me out.
Hi DaneLLL,
When I use the code below, I get the following error:
if (!batch_meta) {
#if 1
src_rect.top = 0;
src_rect.left = 0;
dst_rect.top = 0;
dst_rect.left = 0;
NvBufSurfaceMemSet (dst_surface, 1, 0, 0);
NvBufSurfaceMap (dst_surface, 1, 0, NVBUF_MAP_READ);
NvBufSurfaceSyncForCpu (dst_surface, 1, 0);
cv::Mat in_mat =
#endif
Error:
NvxBaseWorkerFunction[2575] comp OMX.Nvidia.std.iv_renderer.overlay.yuv420 Error -2147479552
Kindly help me out.
For two sources and setting batch-size=2, You should see surface->surfaceList[0] and surface->surfaceList[1]. You have to create two destination surfaces like dst_surface and dst_surface1, copy surface->surfaceList[0] to dst_surface and surface->surfaceList[1] to dst_surface1.
Hi DaneLLL,
When I access surface->surfaceList[1] I get null pointer. Also the width and height are 0. Following is the code:
if (!batch_meta) {
#if 1
NvBufSurfTransformRect src_rect1, dst_rect1;
surface->surfaceList[1].width, surface->surfaceList[1].height);
src_rect.top = 0;
src_rect.left = 0;
dst_rect.top = 0;
dst_rect.left = 0;
src_rect1.top = 0;
src_rect1.left = 0;
src_rect1.width = (guint) surface->surfaceList[1].width;
src_rect1.height= (guint) surface->surfaceList[1].height;
dst_rect1.top = 0;
dst_rect1.left = 0;
dst_rect1.width = (guint) surface->surfaceList[1].width;
dst_rect1.height= (guint) surface->surfaceList[1].height;
NvBufSurfTransformParams nvbufsurface_params1;
nvbufsurface_params1.src_rect = &src_rect1;
nvbufsurface_params1.dst_rect = &dst_rect1;
nvbufsurface_params1.transform_flag = NVBUFSURF_TRANSFORM_CROP_SRC |
nvbufsurface_params1.transform_filter = NvBufSurfTransformInter_Default;
NvBufSurface *dst_surface1 = NULL;
NvBufSurfaceCreateParams nvbufsurface_create_params1;
nvbufsurface_create_params1.gpuId = surface->gpuId;
nvbufsurface_create_params1.width = (gint) surface->surfaceList[1].width;
nvbufsurface_create_params1.height = (gint) surface->surfaceList[1].height;
nvbufsurface_create_params1.size = 0;
nvbufsurface_create_params1.colorFormat = NVBUF_COLOR_FORMAT_RGBA;
nvbufsurface_create_params1.layout = NVBUF_LAYOUT_PITCH;
nvbufsurface_create_params1.memType = NVBUF_MEM_DEFAULT;
create_result = NvBufSurfaceCreate(&dst_surface1,batch_size,
&nvbufsurface_create_params1);
NvBufSurfaceMemSet (dst_surface1, 0, 0, 0);
err = NvBufSurfTransform (surface, dst_surface1, &nvbufsurface_params1);
NvBufSurfaceMap (dst_surface1, 1, 0, NVBUF_MAP_READ);
NvBufSurfaceSyncForCpu (dst_surface1, 1, 0);
for(int cam_id=0; cam_id < batch_size;++cam_id)
cv::Mat in_mat;
if(cam_id==0)
in_mat =
else if(cam_id==1)
in_mat =
CV_8UC4, dst_surface1->surfaceList[cam_id].mappedAddr.addr[0],
dst_surface1->surfaceList[cam_id].pitch);
NvBufSurfaceUnMap (dst_surface1, 1, 0);
#endif
//write_kitti_track_output(appCtx, batch_meta);
//write_db_kitti_track_output(appCtx, batch_meta, frame_data, timestamp);
I get the following error since buffer is null.
NvBufSurfTransform failed with error -3 while converting buffer
Please help me out.
Please check #23 to configure [tiled-display],[source*],[streammux], and [primary-gie]. You probably miss certain configs.
Hi DaneLLL,
I tried the configuration. Still does not work. I still get width and height of surface->surfaceList[1] 0.
Please guide me.
We have verified either rtsp sources and video sources. Both work well. A bit strange you cannot run it. Please also try video sources by modifying uri in [source0] and [source1]:
uri=file://../../streams/sample_1080p_h264.mp4
#uri=rtsp://127.0.0.1:8554/test
Hi DaneLLL,
I can understand how to copy the entire NvBufSurface containing both the buffers (surfaceList[0] and surfaceList[1] ) to a destination surface (dst_surface). How to individually copy surfaceList[0] and surfaceList[1] to separate destination surfaces. Could you please help me out?
Hi. I’m trying to save the image from 8 different cameras. I have written a function to which I pass in_map_info and the stream id. I’m able to save the frames as jpg images however the source id and the frames saved don’t seem to match. For example, when I try to access surfaceList[3], I get a frame from some other source.
cv::Mat
Mercury::getRGBFrame(GstMapInfo in_map_info, gint idx) {
// To access the frame
NvBufSurface surface_idx;
surface_idx = *surface;
surface_idx.surfaceList = &(surface->surfaceList[idx]);
surface_idx.numFilled = surface_idx.batchSize = 1;
int batch_size = surface_idx.batchSize;
src_rect.top = 0;
src_rect.left = 0;
src_rect.width = (guint) surface->surfaceList[idx].width;
src_rect.height= (guint) surface->surfaceList[idx].height;
dst_rect.top = 0;
dst_rect.left = 0;
dst_rect.width = (guint) surface->surfaceList[idx].width;
dst_rect.height= (guint) surface->surfaceList[idx].height;
nvbufsurface_params.transform_flag = NVBUFSURF_TRANSFORM_CROP_SRC | NVBUFSURF_TRANSFORM_CROP_DST;
nvbufsurface_create_params.width = (guint) surface->surfaceList[idx].width;
nvbufsurface_create_params.height = (guint) surface->surfaceList[idx].height;
// nvbufsurface_create_params.isContiguous = true;
// THE memType PARAM IS SET TO CUDA UNIFIED IN dGPU DEVICES COMMENT IT out
// AND USE THE IMMEDIATE NEXT LINE TO SET THE memType PARAM FOR JETSON DEVICES
#ifdef PLATFORM_TEGRA
#else
nvbufsurface_create_params.memType = NVBUF_MEM_CUDA_UNIFIED;
#endif
cudaError_t cuda_err = cudaSetDevice (surface->gpuId);
cuda_err = cudaStreamCreate(&cuda_stream);
int create_result = NvBufSurfaceCreate(&dst_surface, batch_size, &nvbufsurface_create_params);
err = NvBufSurfTransform (&surface_idx, dst_surface, &nvbufsurface_params);
cv::Mat bgr_frame = cv::Mat (cv::Size(nvbufsurface_create_params.width, nvbufsurface_create_params.height), CV_8UC3);
cv::Mat in_mat = cv::Mat (nvbufsurface_create_params.height, nvbufsurface_create_params.width, CV_8UC4, dst_surface->surfaceList[0].mappedAddr.addr[0], dst_surface->surfaceList[0].pitch);
#if (CV_VERSION_MAJOR >= 4)
cv::cvtColor (in_mat, bgr_frame, COLOR_RGBA2BGR);
#else
#endif
NvBufSurfaceUnMap(dst_surface, 0 , 0);
NvBufSurfaceDestroy(dst_surface);
return bgr_frame;
frame_meta->source_id - id of stream
frame_meta->batch_id - id surface of this stream in surfaceList
Hello, where should I register this callback function? At present, I can’t tell which video stream it is after I register. When there are two video streams, surfacelist[1] will crash
Please help to open a new topic with more details. Thanks
