nvidia-bug-report.log.gz (247.4 KB)
PC Freezes Randomly
Especially when running games.
Entry: GPU Has fallen off the Bus.
Mär 28 13:30:51 seb kernel: NVRM: GPU at PCI:0000:01:00: GPU-17becba7-9540-63e6-c6a2-6f931a9958e3
Mär 28 13:30:51 seb kernel: NVRM: Xid (PCI:0000:01:00): 79, pid=0, GPU has fallen off the bus.
Mär 28 13:30:51 seb kernel: NVRM: GPU 0000:01:00.0: GPU has fallen off the bus.
Mär 28 13:30:51 seb kernel: NVRM: GPU 0000:01:00.0: GPU serial number is .
Mär 28 13:30:51 seb kernel: NVRM: A GPU crash dump has been created. If possible, please run
NVRM: nvidia-bug-report.sh as root to collect this data before
NVRM: the NVIDIA kernel module is unloaded.
Most common causes on desktop systems are overheating and lack of power.
Your gpu is quite hot (62°C) while idle, please check fans and airflow, monitor temperatures.
To rule out power issues on boost, you can try limiting clocks using nvidia-smi -lgc
I tested it with nvidia-smi and the normal Temperature is:
28% Fan → 48°C
But Ingame, i tested it with Yooka-Laylee
The Nvidia increased between
52% Fan → 79-81°C
I check if I can dust off some dirt and then put it in place again,
something feels off.
