Description
There are several issues when processing ONNX files and compiling TRT models, when launching the program on the GPU RTX 3070 with driver 460.32.03
(On other CUDA GPUs, younger RTX3070, with drivers 410/440/450 we work successfully)
Working on: model-batch4-fp16-112x112.onnx
Number of network layers: 223
Saving @ tensorrt/model-batch4-fp16-112x112.trt
STDERR: [TensorRT] WARNING: Calling isShapeTensor before the entire network is constructed may result in an inaccurate result.
[TensorRT] WARNING: Half2 support requested on hardware without native FP16 support, performance will be negatively affected.
[TensorRT] INTERNAL ERROR: Assertion failed: Unsupported SM.
../rtSafe/cuda/caskUtils.cpp:80
Aborting...
[TensorRT] ERROR: ../rtSafe/cuda/caskUtils.cpp (80) - Assertion Error in trtSmToCask: 0 (Unsupported SM.)
Working on: model-fp16-960x544.onnx
Number of network layers: 248
STDERR: [TensorRT] WARNING: onnx2trt_utils.cpp:198: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
Aborting...
Saving @ tensorrt/model-fp16-960x544.trt
nvidia-smi
| NVIDIA-SMI 460.32.03 Driver Version: 460.32.03 CUDA Version: 11.2 |
| | | MIG M. |
| 0 GeForce RTX 3070 Off | 00000000:01:00.0 On | N/A |
| 0% 57C P2 57W / 240W | 617MiB / 7979MiB | 1% Default |
| | | N/A |
Is it possible this GPU RTX3070 does not support FP16?
Environment
TensorRT Version: 7.0.0.11
GPU Type: RTX3070
Nvidia Driver Version: 460.32.03
CUDA Version: cuda10.0
CUDNN Version: 7.6.5.32
Operating System + Version: Ubuntu 18.04.5
Python Version (if applicable): 3.6.9
Numpy: 1.19.0
