Hello all, this is constant no matter what driver, or monitor configuration. My RTX 3090 on both windows and Kde Plasma Wayland idle at 40-50w, this seems excessively high when coming from a 1080 that idled at 10-17w. Additionally, any slight movement of the mouse and the power draw jumps to 120-160w. Tried one monitor, same result. Tried 60hz, same result. Not sure if this is a bug, tried many different drivers including the latest and it simply won’t idle lower than 40-45w. Core clock is 210mhz, memory is 405mhz.
Related topics
| Phantom RTX 5090 High Idle Power Consumption – Any Fixes? | 0 | 1875 | March 14, 2025 | |
| Second RTX 3090 remains in high idle power | 7 | 547 | May 31, 2025 | |
| GeForce RTX 5090 Idle Power Consumption | 2 | 1203 | December 25, 2025 | |
| [BUG Report] Idle Power Draw is ASTRONOMICAL with RTX 3090 | 92 | 25319 | March 30, 2026 | |
| RTX 3050 idle power too high | 4 | 2183 | October 19, 2024 | |
| High idle consumption - multiple screen setup | 1 | 509 | August 10, 2024 | |
| Idle power usage stuck at 10-20watts after running an app | 8 | 8269 | October 17, 2022 | |
| RTX 3090 throttles down underload temps looks fine | 3 | 1133 | January 10, 2022 | |
| RTX 3090 fan 30% limit acts incorrect (too high and hence fan is too loud) | 15 | 2272 | April 28, 2025 | |
| Idle power usage problem (P8) after debian driver distupgrade 470->525 [RTX 3090] | 5 | 4230 | September 12, 2023 |
