TensorFlow GPU Detection Issue Troubleshooting Summary
Hello. I am seeking assistance with an issue where TensorFlow is unable to detect the GPU on my system, which has an NVIDIA GeForce RTX 4060. I have attempted various troubleshooting steps, but the problem persists.
1. System and Software Environment:
- GPU: NVIDIA GeForce RTX 4060
- Operating System: Windows 11
- Python Version: 3.11.9
- NVIDIA Driver Version: 566.36 (Lowest compatible driver version for Windows 11)
- CUDA Toolkit Version: 12.3.2 (January 2024)
- cuDNN Version: 8.9.7 (for CUDA 12.x)
- TensorFlow Version: 2.19.0 (initial attempt), 2.12.0 (intermediate attempt), 2.16.1 (final attempt)
- Currently, I have attempted with TensorFlow 2.19.0 (officially supporting CUDA 12.3, cuDNN 8.9.7) and 2.16.1 (compatible with CUDA 12.x, cuDNN 8.9.x).
- Visual C++ Redistributable Packages: 2015-2022 (x64) repaired.
2. Problem Symptoms:
tf.config.list_physical_devices('GPU')consistently returns an empty list.- TensorFlow outputs the message “GPU not detected. Using CPU.” and operates solely on the CPU.
- Even with
TF_CPP_MIN_LOG_LEVELset to0, no GPU-related loading failure messages are displayed.
3. Troubleshooting Steps Attempted and Results:
- NVIDIA Driver Clean Reinstallation (using DDU):
- Used DDU to completely remove existing drivers, then reinstalled the latest driver (576.88) from the NVIDIA official website using the “Perform a clean installation” option.
- Result: Driver installed, but
nvidia-smireportedCUDA Version: 12.9, suggesting a version mismatch with TensorFlow 2.19.0 (CUDA 12.3). - Subsequently, performed another DDU clean reinstallation with 566.36 , the lowest driver version available for Windows 11.
- Result:
nvidia-smicorrectly reportedCUDA Version: 12.7. (Theoretically compatible with CUDA 12.3).
- CUDA Toolkit and cuDNN Version Matching:
- Installed CUDA Toolkit 12.3.2 and cuDNN 8.9.7, precisely matching TensorFlow 2.19.0’s official requirements, and correctly copied cuDNN files to the CUDA Toolkit path.
- An intermediate attempt involved downgrading to TensorFlow 2.12.0 with CUDA Toolkit 11.8 and cuDNN 8.6.0, but GPU detection still failed. (Later reverted to 12.3.2/8.9.7).
- Environment Variable
PathSetting:- The following four paths were placed at the very top of the system
Pathvariable:C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.3\binC:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.3\libnvvpC:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.3\includeC:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.3\lib\x64
- Virtual Environment Usage:
- All TensorFlow installations and tests were performed within clean virtual environments created with
python -m venv. (Using an elevated/administrator CMD).
TF_FORCE_GPU_ALLOW_GROWTHEnvironment Variable Setting:- Set the system environment variable
TF_FORCE_GPU_ALLOW_GROWTHtotrueand rebooted the system.
- NVIDIA Driver and CUDA Toolkit Self-Diagnosis:
nvidia-smioutput (after installing driver 566.36):
Fri Jul 4 14:24:57 2025
| NVIDIA-SMI 566.36 Driver Version: 566.36 CUDA Version: 12.7 |
| GPU Name Driver-Model | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 4060 WDDM | 00000000:0B:00.0 On | N/A |
| 0% 49C P5 N/A / 115W | 1188MiB / 8188MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 2252 C+G ...CBS_cw5n1h2txyewy\TextInputHost.exe N/A |
| ... (truncated) ...
* **Result:** Driver version is 566.36, and `CUDA Version` is correctly reported as 12.7.
deviceQuery.exeoutput (after installing CUDA Toolkit 12.3.2):
deviceQuery.exe Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "NVIDIA GeForce RTX 4060"
CUDA Driver Version / Runtime Version 12.7 / 12.3
CUDA Capability Major/Minor version number: 8.9
Total amount of global memory: 8188 MBytes (8585216000 bytes)
MapSMtoCores for SM 8.9 is undefined. Default to use 128 Cores/SM
(24) Multiprocessors, (128) CUDA Cores/MP: 3072 CUDA Cores
GPU Max Clock rate: 2505 MHz (2.50 GHz)
Memory Clock rate: 8501 Mhz
Memory Bus Width: 128-bit
L2 Cache Size: 25165824 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: zu bytes
Total amount of shared memory per block: zu bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 1536
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: zu bytes
Texture alignment: zu bytes
Concurrent copy and kernel execution: Yes with 1 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
CUDA Device Driver Mode (TCC or WDDM): WDDM (Windows Display Driver Model)
Device supports Unified Addressing (UVA): Yes
Device supports Compute Preemption: Yes
Supports Cooperative Kernel Launch: Yes
Supports MultiDevice Co-op Kernel Launch: No
Device PCI Domain ID / Bus ID / location ID: 0 / 11 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 12.7, CUDA Runtime Version = 12.3, NumDevs = 1, Device0 = NVIDIA GeForce RTX 4060
Result = PASS
* **Result:** Confirmed that the GPU communicates perfectly with the CUDA driver (12.7) and runtime (12.3), indicating normal operation at the system level.
4. Conclusion and Request for Assistance:
Both nvidia-smi and deviceQuery clearly show that the GPU and CUDA environment are functioning correctly at the system level. All version compatibilities (driver, CUDA Toolkit, cuDNN, TensorFlow) also align with official requirements. Despite this, TensorFlow fails to detect the GPU, which is highly unusual.
I would appreciate any insights into potential overlooked issues or known problems specific to this environment (Windows 11, RTX 4060, Python 3.11.9). Any additional methods for diagnosing why TensorFlow might be failing to load GPU-related DLLs would be greatly helpful.
Currently, I am unable to proceed with GPU-accelerated deep learning training due to this issue. Your assistance would be greatly appreciated.
