Good Day…! The tensorflow library is not detecting the gpus.
Im using Nvidia geforce rtx 4090 gpu. Here is tensorflow and cuda details.
(base) sri@sri:~$ nvidia-smi
Fri Apr 5 21:50:14 2024
| NVIDIA-SMI 550.73.01 Driver Version: 552.12 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 4090 … On | 00000000:01:00.0 Off | N/A |
| N/A 45C P8 6W / 60W | 478MiB / 16376MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
(base) sri@sri:~$ pip show tensorflow
Version: 2.16.1
Summary: TensorFlow is an open source machine learning framework for everyone.
Home-page: https://www.tensorflow.org/
Author: Google Inc.
Author-email: packages@tensorflow.org
License: Apache 2.0
Location: /home/sri/miniconda3/lib/python3.11/site-packages
Requires: absl-py, astunparse, flatbuffers, gast, google-pasta, grpcio, h5py, keras, libclang, ml-dtypes, numpy, opt-einsum, packaging, protobuf, requests, setuptools, six, tensorboard, tensorflow-io-gcs-filesystem, termcolor, typing-extensions, wrapt
Required-by:
When I try to run this python3 -c “import tensorflow as tf; print(tf.config.list_physical_devices(‘GPU’))”
Im getting the below output
2024-04-05 21:55:29.786047: I tensorflow/core/util/port.cc:113] oneDNN custom operations are on. You may see slightly different numerical results due to floating-point round-off errors from different computation orders. To turn them off, set the environment variable TF_ENABLE_ONEDNN_OPTS=0.
2024-04-05 21:55:29.835334: I tensorflow/core/platform/cpu_feature_guard.cc:210] This TensorFlow binary is optimized to use available CPU instructions in performance-critical operations.
To enable the following instructions: AVX2 AVX512F AVX512_VNNI AVX512_BF16 FMA, in other operations, rebuild TensorFlow with the appropriate compiler flags.
2024-04-05 21:55:30.706071: W tensorflow/compiler/tf2tensorrt/utils/py_utils.cc:38] TF-TRT Warning: Could not find TensorRT
2024-04-05 21:55:31.661712: I external/local_xla/xla/stream_executor/cuda/cuda_executor.cc:984] could not open file to read NUMA node: /sys/bus/pci/devices/0000:01:00.0/numa_node
Your kernel may have been built without NUMA support.
2024-04-05 21:55:31.669885: W tensorflow/core/common_runtime/gpu/gpu_device.cc:2251] Cannot dlopen some GPU libraries. Please make sure the missing libraries mentioned above are installed properly if you would like to use GPU. Follow the guide at GPU 支援 | TensorFlow for how to download and setup the required libraries for your platform.
Skipping registering GPU devices…
Can you please let me know what is missing here?
