Summary
Training a large language model (Nemotron-3-Nano-30B-A3B) across two Blackwell GPUs (RTX 5090 + RTX 5070 Ti) causes unrecoverable CUDA driver crashes during the backward pass. Two distinct failure modes depending on configuration:
With
gradient_checkpointing=True: “expected device meta but got cuda:0” error during gradient computation -
Without gradient checkpointing: CUDA driver crashes entirely with “device not ready” errors, requiring full system reboot
Single-GPU inference on the same hardware works perfectly. The issue is specific to multi-GPU training with backward pass computation across both devices.
Hardware
| Component | Details |
| GPU 0 | PNY GeForce RTX 5090 EPIC-X ARGB OC — 32GB GDDR7 |
| GPU 1 | MSI GeForce RTX 5070 Ti Ventus 3X OC — 16GB GDDR7 |
| Combined VRAM | 48GB |
| CPU | AMD Ryzen 9 9950X3D |
| RAM | 64GB DDR5-6000 |
| Motherboard | MSI MEG X870E Godlike |
| PSU | 1250W |
| PCIe Layout | 5090 in top x16 slot (full bandwidth), 5070 Ti in second slot (x4 chipset) |
Thermal Validation
Both GPUs were stress-tested with OCCT 3D Adaptive Steady, Heavy load, 15 minutes prior to any ML work:
5090: 69°C core / 72°C memory junction @ 338W
5070 Ti: 63°C core / 62°C memory junction @ 191W
Combined draw: ~530W
Zero PCIe lane errors, zero WHEA errors
Hardware is stable under sustained compute load. This is not a thermal or power issue.
Software Environment
| Component | Version |
| OS | Windows — WSL2 with Docker |
| Docker Image | nvidia/cuda:13.0.0-devel-ubuntu24.04 (custom) |
| NVIDIA Driver | Latest as of March 2026 (supports sm_120) |
| CUDA Toolkit (container) | 13.0 |
| PyTorch | 2.9.0a0+git0fabc3b (compiled from source with sm_120 support) |
| mamba-ssm | 2.3.1 (compiled from source against CUDA 13.0) |
| causal-conv1d | 1.6.1 (compiled from source) |
| transformers | Latest |
| PEFT | Latest |
| bitsandbytes | Latest |
| Python | 3.12 |
Model
Nemotron-3-Nano-30B-A3B (NVIDIA’s hybrid Mamba-Transformer architecture)
Using the FP8 weights (
nvidia/NVIDIA-Nemotron-3-Nano-30B-A3B-FP8) -
Loaded with
device_map="auto"andmax_memory={0: "28GiB", 1: "10GiB"}to split across both GPUs -
LoRA fine-tuning via PEFT (r=8, target_modules=[“q_proj”, “v_proj”])
Reproduction Steps
Configuration that triggers the crash:
python
from transformers import AutoModelForCausalLM, AutoTokenizer
from peft import LoraConfig, get_peft_model, TaskType
from transformers import Trainer, TrainingArguments, DataCollatorForLanguageModeling
from datasets import load_dataset
import torch
tokenizer = AutoTokenizer.from_pretrained(
"/models/nemotron-fp8", trust_remote_code=True
tokenizer.pad_token = tokenizer.eos_token
model = AutoModelForCausalLM.from_pretrained(
device_map="auto",
max_memory={0: "28GiB", 1: "10GiB"},
trust_remote_code=True,
torch_dtype=torch.bfloat16,
model.enable_input_require_grads()
lora_config = LoraConfig(
r=8, lora_alpha=16,
target_modules=["q_proj", "v_proj"],
lora_dropout=0.05, bias="none",
task_type=TaskType.CAUSAL_LM,
model = get_peft_model(model, lora_config)
# ... load and tokenize dataset ...
training_args = TrainingArguments(
output_dir="/models/sable-lora-v1",
num_train_epochs=1,
per_device_train_batch_size=1,
gradient_accumulation_steps=8,
learning_rate=2e-5,
bf16=True,
gradient_checkpointing=True, # Toggle this for different failure modes
optim="adamw_torch",
trainer = Trainer(
model=model, args=training_args,
train_dataset=tokenized, data_collator=data_collator,
trainer.train() # Crashes here
Failure Mode 1: gradient_checkpointing=True
Error: expected device meta but got cuda:0
This occurs during the backward pass when gradient checkpointing attempts to recompute activations across the device boundary. The model layers are split across cuda:0 (5090) and cuda:1 (5070 Ti) via device_map="auto". During recomputation, the checkpoint mechanism appears to lose track of which device the tensors should be on.
Failure Mode 2: gradient_checkpointing=False
Error: Unrecoverable CUDA driver crash — “device not ready”
Without gradient checkpointing, the full activation tensors must be held in memory. The backward pass begins but the CUDA driver crashes entirely within seconds. The Docker container becomes unresponsive. nvidia-smi returns “device not ready” for both GPUs. A full system reboot is required to recover. The driver does not recover on its own and the GPUs do not reset.
This is the more concerning failure mode — the driver should handle an out-of-memory condition gracefully rather than crashing.
Additional Context
What works on this exact hardware:
Single-GPU inference: Nemotron runs at 95+ tokens/sec on the 5090 alone via llama.cpp. Rock solid, no issues.
OCCT stress test: 15 minutes of sustained heavy GPU compute on both cards simultaneously. Zero errors.
Multi-GPU model loading: The model loads correctly across both GPUs with
device_map="auto". Forward pass for inference works. The crash is specific to the backward pass during training. -
Basic PyTorch tensor ops on both GPUs: Creating tensors, moving between devices, matrix multiplies — all work fine.
What I’ve ruled out:
Thermal throttling: GPUs stay well within limits during the brief period before crash
Power delivery: 1250W PSU, combined draw ~530W under stress, plenty of headroom
PCIe errors: Zero WHEA errors in Event Viewer, zero PCIe lane errors in stress testing
Memory corruption: memtest clean, no other stability issues
Likely contributing factors:
- The FP8 model’s custom
modeling_nemotron_h.pyuses a naive Python Mamba forward implementation (torch_forward) instead of the fast mamba-ssm CUDA kernels. This creates very large intermediate tensors (1-8GB per Mamba layer) during forward/backward. On a single GPU this would OOM normally, but across two GPUs the cross-device tensor management appears to trigger the driver crash rather than a clean OOM error.
Expected Behavior
With gradient checkpointing: Training should work across both GPUs, with activations recomputed correctly on the appropriate device.
Without gradient checkpointing: If VRAM is insufficient, PyTorch should raise a clean
torch.cuda.OutOfMemoryErrorrather than crashing the CUDA driver. -
The driver should never enter an unrecoverable state that requires a system reboot.
Questions for NVIDIA
Is multi-GPU training across two sm_120 devices with different VRAM sizes (32GB + 16GB) a supported configuration for PyTorch
device_map="auto"? -
Is there a known issue with the CUDA driver crashing (rather than returning OOM) when backward pass memory allocation fails on sm_120?
Are there recommended driver versions or settings for multi-GPU training on RTX 5090 + 5070 Ti?
Thank you for any guidance. Happy to provide additional logs, nvidia-bug-report outputs, or run specific diagnostic steps.
