hi community,
I currently have an RTX A2000 12GB. I need to install an RTX A2000 ADA 16GB.
can they work in parallel?
HP Z4G5
Thank you
Related topics
Topic | Replies | Views | Activity | |
2x NVIDIA RTX 2000 Ada 16GB GPU for running 8 monitors (5k res 60hz) - possible? | 0 | 23 | May 3, 2025 | |
Will RTX A5500 and RTX A6000 work together? | 0 | 465 | July 17, 2023 | |
CUDA 12.1 compatibility with RTX 2000 Ada Generation, 8 GB | 1 | 2578 | May 3, 2024 | |
Is RTX 4000 ADA CUDA capable? | 7 | 1104 | December 24, 2024 | |
Install 2 Brands (Nvidia + other) of cards in the same machine? | 0 | 577 | October 13, 2014 | |
Can I install a Quadro P2000 and P4000 on the same machine? | 1 | 657 | December 6, 2018 | |
Two different cards in parallel with Cuda | 1 | 1534 | November 2, 2008 | |
Compatibility between RTX A4500 20GB and other GPU Cards | 3 | 639 | June 4, 2024 | |
CUDA WITH ATI | 2 | 833 | November 11, 2013 | |
questions about Cuda utilization of dual (NON-SLI) GPU resources in "newer" cards | 0 | 384 | November 30, 2019 |
