Here’s the output from lscpci and the devicequery prior to hanging. I’m not certain about finding useful info in the log files, but am happy to provide it if you have a suggested place to look.
51:00.0 VGA compatible controller: NVIDIA Corporation GA104GL [RTX A4000] (rev a1)
51:00.1 Audio device: NVIDIA Corporation GA104 High Definition Audio Controller (rev a1)
9c:00.0 VGA compatible controller: NVIDIA Corporation GA104GL [RTX A4000] (rev a1)
9c:00.1 Audio device: NVIDIA Corporation GA104 High Definition Audio Controller (rev a1)
Here’s the output from deviceQuery
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 2 CUDA Capable device(s)
Device 0: "NVIDIA RTX A4000"
CUDA Driver Version / Runtime Version 12.1 / 12.0
CUDA Capability Major/Minor version number: 8.6
Total amount of global memory: 16086 MBytes (16866869248 bytes)
(048) Multiprocessors, (128) CUDA Cores/MP: 6144 CUDA Cores
GPU Max Clock rate: 1560 MHz (1.56 GHz)
Memory Clock rate: 7001 Mhz
Memory Bus Width: 256-bit
L2 Cache Size: 4194304 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total shared memory per multiprocessor: 102400 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 1536
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device supports Managed Memory: No
Device supports Compute Preemption: Yes
Supports Cooperative Kernel Launch: Yes
Supports MultiDevice Co-op Kernel Launch: Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 81 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
The other sample program deviceQueryDrv
in the cuda-samples repo completes successfully and shows
CUDA Device Query (Driver API) statically linked version
CUDA Driver Version: 12.1
(48) Multiprocessors, (128) CUDA Cores/MP: 6144 CUDA Cores
Max Texture Dimension Sizes 1D=(131072) 2D=(131072, 65536) 3D=(16384, 16384, 16384)
Warp size: 32
Concurrent kernel execution: Yes
Compute Mode:
Device 1: "NVIDIA RTX A4000"
Total amount of global memory: 16108 MBytes (16890462208 bytes)
Warp size: 32
Device PCI Domain ID / Bus ID / location ID: 0 / 156 / 0
Compute Mode:
> Peer-to-Peer (P2P) access from NVIDIA RTX A4000 (GPU0) -> NVIDIA RTX A4000 (GPU1) : Yes
> Peer-to-Peer (P2P) access from NVIDIA RTX A4000 (GPU1) -> NVIDIA RTX A4000 (GPU0) : Yes
Result = PASS
Here’s nvidia-smi as well:
| NVIDIA-SMI 530.30.02 Driver Version: 530.30.02 CUDA Version: 12.1 |
| | | MIG M. |
| 0 NVIDIA RTX A4000 On | 00000000:51:00.0 Off | Off |
| 41% 36C P8 17W / 140W| 0MiB / 16376MiB | 0% Default |
| | | N/A |
| 1 NVIDIA RTX A4000 On | 00000000:9C:00.0 Off | Off |
| 41% 28C P8 7W / 140W| 0MiB / 16376MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
