So far I have done everything as root. Yes I am able to successfully run CUDA sample codes:
# /usr/local/cuda/samples/bin/ppc64le/linux/release/bandwidthTest
[CUDA Bandwidth Test] - Starting...
Running on...
Device 0: Tesla P100-SXM2-16GB
Quick Mode
Host to Device Bandwidth, 1 Device(s)
PINNED Memory Transfers
Transfer Size (Bytes) Bandwidth(MB/s)
33554432 29517.4
Device to Host Bandwidth, 1 Device(s)
33554432 21339.9
Device to Device Bandwidth, 1 Device(s)
33554432 449507.2
Result = PASS
NOTE: The CUDA Samples are not meant for performance measurements. Results may vary when GPU Boost is enabled.
# /usr/local/cuda/samples/bin/ppc64le/linux/release/deviceQuery
/usr/local/cuda/samples/bin/ppc64le/linux/release/deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 4 CUDA Capable device(s)
Device 0: "Tesla P100-SXM2-16GB"
CUDA Driver Version / Runtime Version 8.0 / 8.0
CUDA Capability Major/Minor version number: 6.0
Total amount of global memory: 16281 MBytes (17071669248 bytes)
(56) Multiprocessors, ( 64) CUDA Cores/MP: 3584 CUDA Cores
GPU Max Clock rate: 1481 MHz (1.48 GHz)
Memory Clock rate: 715 Mhz
Memory Bus Width: 4096-bit
L2 Cache Size: 4194304 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 3 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Enabled
Device supports Unified Addressing (UVA): Yes
Device PCI Domain ID / Bus ID / location ID: 2 / 1 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
Device 1: "Tesla P100-SXM2-16GB"
Warp size: 32
Device PCI Domain ID / Bus ID / location ID: 3 / 1 / 0
Compute Mode:
Device 2: "Tesla P100-SXM2-16GB"
Warp size: 32
Device PCI Domain ID / Bus ID / location ID: 10 / 1 / 0
Compute Mode:
Device 3: "Tesla P100-SXM2-16GB"
Warp size: 32
Device PCI Domain ID / Bus ID / location ID: 11 / 1 / 0
Compute Mode:
> Peer access from Tesla P100-SXM2-16GB (GPU0) -> Tesla P100-SXM2-16GB (GPU1) : Yes
> Peer access from Tesla P100-SXM2-16GB (GPU0) -> Tesla P100-SXM2-16GB (GPU2) : No
> Peer access from Tesla P100-SXM2-16GB (GPU0) -> Tesla P100-SXM2-16GB (GPU3) : No
> Peer access from Tesla P100-SXM2-16GB (GPU1) -> Tesla P100-SXM2-16GB (GPU0) : Yes
> Peer access from Tesla P100-SXM2-16GB (GPU1) -> Tesla P100-SXM2-16GB (GPU2) : No
> Peer access from Tesla P100-SXM2-16GB (GPU1) -> Tesla P100-SXM2-16GB (GPU3) : No
> Peer access from Tesla P100-SXM2-16GB (GPU2) -> Tesla P100-SXM2-16GB (GPU0) : No
> Peer access from Tesla P100-SXM2-16GB (GPU2) -> Tesla P100-SXM2-16GB (GPU1) : No
> Peer access from Tesla P100-SXM2-16GB (GPU2) -> Tesla P100-SXM2-16GB (GPU3) : Yes
> Peer access from Tesla P100-SXM2-16GB (GPU3) -> Tesla P100-SXM2-16GB (GPU0) : No
> Peer access from Tesla P100-SXM2-16GB (GPU3) -> Tesla P100-SXM2-16GB (GPU1) : No
> Peer access from Tesla P100-SXM2-16GB (GPU3) -> Tesla P100-SXM2-16GB (GPU2) : Yes
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 8.0, CUDA Runtime Version = 8.0, NumDevs = 4, Device0 = Tesla P100-SXM2-16GB, Device1 = Tesla P100-SXM2-16GB, Device2 = Tesla P100-SXM2-16GB, Device3 = Tesla P100-SXM2-16GB
Result = PASS
