Failed: CUDA driver version is insufficient for CUDA runtime version
I am struggling to resolve the CUDA version conflict between driver and runtime when running from singularity. I have used two containers (build from docker)
clara-parabricks_4.1.2-1.sif
clara-parabricks_4.2.0-1.sif
(details are below) “[PB Error 2023-Nov-14 11:27:02][src/stitchPiece_step0.cu:438] cudaSafeCall() failed: CUDA driver version is insufficient for CUDA runtime version, exiting.”
when running the singularity container on HPC gpu node.
What would I need to do to resolve this conflict? (A challenge to note is on HPC cluster users do not have root privileges )
I don’t understand why nvidia-smi shows CUDA Version shows 11.8 when singularity has the CUDA-12.2. I also looked at the requirement variable. I guess if fix the paths it might work.
Singularity> echo $NVIDIA_REQUIRE_CUDA
cuda>=12.2 brand=tesla,driver>=450,driver<451
cuda>brand=tesla,driver>=470,driver<471
cuda>brand=unknown,driver>=470,driver<471
cuda>brand=nvidia,driver>=470,driver<471
cuda>brand=nvidiartx,driver>=470,driver<471
cuda>brand=geforce,driver>=470,driver<471
cuda>brand=geforcertx,driver>=470,driver<471
cuda>brand=quadro,driver>=470,driver<471
cuda>brand=quadrortx,driver>=470,driver<471
cuda>brand=titan,driver>=470,driver<471
cuda>brand=titanrtx,driver>=470,driver<471
cuda>brand=tesla,driver>=525,driver<526
cuda>brand=unknown,driver>=525,driver<526
cuda>brand=nvidia,driver>=525,driver<526
cuda>brand=nvidiartx,driver>=525,driver<526
cuda>brand=geforce,driver>=525,driver<526
cuda>brand=geforcertx,driver>=525,driver<526
cuda>brand=quadro,driver>=525,driver<526
cuda>brand=quadrortx,driver>=525,driver<526
cuda>brand=titan,driver>=525,driver<526
cuda>brand=titanrtx,driver>=525,driver<526
Don’t understand why CUDA Version shows 11.8 when singularity has the CUDA-12.2
Singularity> nvidia-smi
Tue Nov 14 11:39:19 2023
| NVIDIA-SMI 520.61.05 Driver Version: 520.61.05 CUDA Version: 11.8 |
| | | MIG M. |
| 0 NVIDIA GeForce … On | 00000000:86:00.0 Off | N/A |
| 30% 33C P8 13W / 250W | 1MiB / 11264MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
Singularity> echo $PATH
/usr/local/nvidia/bin:/usr/local/cuda/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
Singularity> uname -a
Linux gpu0035.vampire 3.10.0-1160.71.1.el7.x86_64 #1 SMP Tue Jun 28 15:37:28 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Singularity> ls /usr/local/cuda*
/usr/local/cuda:
compat doc gds lib64 targets
/usr/local/cuda-12:
/usr/local/cuda-12.2:
Singularity> time pbrun rna_fq2bam --in-fq
Singularity> /nobackup/h_vmac/user/janveva1/Project/RNAseq/bulk_RNAseq_g
Singularity> pu/test_data/Sample_043_END1.fastq.gz
Singularity> pu/test_data/Sample_043_END2.fastq.gz --genome-lib-dir
Singularity> pu/genome_index/ --ref
Singularity> pu/test_data/101bp_r110/Homo_sapiens.GRCh38.110.dna_sm.prim
Singularity> ary_assembly.fa --output-dir
Singularity> pu/output/ --out-bam Sample_043_END2_gpu.bam
Singularity> --read-files-command zcat
Please visit NVIDIA Clara - NVIDIA Docs for detailed documentation
[Parabricks Options Mesg]: Automatically generating ID prefix [Parabricks Options Mesg]: Read group created for /panfs/accrepfs.vampire/nobackup/h_vmac/user/janveva1/Project/RNAseq/bulk_RNAseq_gpu/test_data/Sample_043_END1.fastq.gz
and
/panfs/accrepfs.vampire/nobackup/h_vmac/user/janveva1/Project/RNAseq/bulk_RNAseq_gpu/test_data/Sample_043_END2.fastq.gz
[Parabricks Options Mesg]: @RG\tID:HYWM7BCXX161201.1\tLB:lib1\tPL:bar\tSM:sample\tPU:HYWM7BCXX161201.1
[PB Info 2023-Nov-14 12:02:40] ------------------------------------------------------------------------------
[PB Info 2023-Nov-14 12:02:40] || Parabricks accelerated Genomics Pipeline ||
[PB Info 2023-Nov-14 12:02:40] || Version 4.2.0-1 ||
[PB Info 2023-Nov-14 12:02:40] || star ||
[PB Info 2023-Nov-14 12:02:40] … started STAR run [PB Info 2023-Nov-14 12:02:40] … loading genome [PB Info 2023-Nov-14 12:03:55] read from genomeDir done 74.864 [PB Info 2023-Nov-14 12:03:55] Gpu num:1 Cpu thread num: 4 [PB Info 2023-Nov-14 12:03:55] … started mapping [PB Error 2023-Nov-14 12:03:55][src/stitchPiece_step0.cu:438] cudaSafeCall() failed: CUDA driver version is insufficient for CUDA runtime version, exiting.
For technical support visit Clara Parabricks v4.2.0 - NVIDIA Docs
Exiting…
Could not run rna_fq2bam
Exiting pbrun …
Best regrds,
Vaibhav
What is your driver version?
Parabricks v4.2.0-1 requires 525.60.13 or newer drivers
The nvidia-smi shows 520.61.05
How do I update this in the singularity where I don’t have admin access?
nvidia-smi -a | head -n55
==============NVSMI LOG==============
Timestamp : Wed Nov 15 13:12:26 2023
Driver Version : 520.61.05
Your admin needs to update to at least 525 or newer drivers on the host machine
Please see requirements here:
Is it possible to install the drivers in user directory and point to them or update the container ? I will reach out to admins to see if they would e willing to install the updates and the time frame for this?
Thank you!
Best regrds,
Vaibhav
I noticed the driver versions are different based on node assigned to my job.
I tried the same task on different assigned node and got out of memory error (38GB requested based on memory usage for same task in STAR ).
Tried again with 120GB memory and 2GPUs still got the same out of memory error. Whats the reason for this error?
“[PB Error 2023-Nov-16 02:50:29][src/stitchPiece_step0.cu:438] cudaSafeCall() failed: CUDA driver version is insufficient for CUDA runtime version, exiting.”
Notice the nvidia-smi gives different version of CUDA drivers. nvcc -V command is not found.
Using the latest container version singularity shell --nv clara-parabricks_4.2.0-1.sif I am still getting the driver conflict error.
[janveva1@gpu0040 ~]$ cd /nobackup/h_vmac/user/janveva1/Project/RNAseq/bulk_RNAseq_gpu/
[janveva1@gpu0040 bulk_RNAseq_gpu]$ singularity shell --nv clara-parabricks_4.0.1-1.sif
time pbrun rna_fq2bam --in-fq /nobackup/h_vmac/user/janveva1/Project/RNAseq/bulk_RNAseq_gpu/test_data/Sample_043_END1.fastq.gz /nobackup/h_vmac/user/janveva1/Project/RNAseq/bulk_RNAseq_gpu/test_data/Sample_043_END2.fastq.gz --genome-lib-dir /nobackup/h_vmac/user/janveva1/Project/RNAseq/bulk_RNAseq_gpu/genome_index/ --ref /nobackup/h_vmac/user/janveva1/Project/RNAseq/bulk_RNAseq_gpu/test_data/101bp_r110/Homo_sapiens.GRCh38.110.dna_sm.primary_assembly.fa --output-dir /nobackup/h_vmac/user/janveva1/Project/RNAseq/bulk_RNAseq_gpu/output/ --out-bam Sample_043_END2_gpu.bam --read-files-command zcat
Please visit https://docs.nvidia.com/clara/#parabricks for detailed documentation
Parabricks Options Mesg: Automatically generating ID prefix
Parabricks Options Mesg: Read group created for
and
[PB Info 2023-Nov-16 02:25:55] ------------------------------------------------------------------------------
[PB Info 2023-Nov-16 02:25:55] || Parabricks accelerated Genomics Pipeline ||
[PB Info 2023-Nov-16 02:25:55] || Version 4.0.1-1 ||
[PB Info 2023-Nov-16 02:25:55] || star ||
[PB Info 2023-Nov-16 02:25:56] … started STAR run
[PB Info 2023-Nov-16 02:25:56] … loading genome
[PB Info 2023-Nov-16 02:28:00] read from genomeDir done 124.206
[PB Info 2023-Nov-16 02:28:00] Gpu num:2 Cpu thread num: 4
[PB Info 2023-Nov-16 02:28:00] … started mapping
[PB Info 2023-Nov-16 02:28:12] gpu free memory: 6445268992, total 11554848768
cudaSuccess
[PB Error 2023-Nov-16 02:28:12][src/stitchPiece_step0.cu:88] cudaSafeCall() failed: out of memory, exiting.
For technical support visit https://docs.nvidia.com/clara/parabricks/4.0.0/Help.html
Exiting…
Thu Nov 16 02:46:13 2023
| NVIDIA-SMI 510.47.03 Driver Version: 510.47.03 CUDA Version: 11.6 |
| | | MIG M. |
| 0 NVIDIA GeForce … On | 00000000:3B:00.0 Off | N/A |
| 29% 31C P8 13W / 250W | 1MiB / 11264MiB | 0% Default |
| | | N/A |
| 1 NVIDIA GeForce … On | 00000000:5E:00.0 Off | N/A |
| 29% 30C P8 14W / 250W | 1MiB / 11264MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
Singularity> nvcc -V
bash: nvcc: command not found
[janveva1@gpu0040 bulk_RNAseq_gpu]$ singularity shell --nv clara-parabricks_4.2.0-1.sif
Singularity> time pbrun rna_fq2bam --in-fq /nobackup/h_vmac/user/janveva1/Project/RNAseq/bulk_RNAseq_gpu/test_data/Sample_043_END1.fastq.gz /nobackup/h_vmac/user/janveva1/Project/RNAseq/bulk_RNAseq_gpu/test_data/Sample_043_END2.fastq.gz --genome-lib-dir /nobackup/h_vmac/user/janveva1/Project/RNAseq/bulk_RNAseq_gpu/genome_index/ --ref /nobackup/h_vmac/user/janveva1/Project/RNAseq/bulk_RNAseq_gpu/test_data/101bp_r110/Homo_sapiens.GRCh38.110.dna_sm.primary_assembly.fa --output-dir /nobackup/h_vmac/user/janveva1/Project/RNAseq/bulk_RNAseq_gpu/output/ --out-bam Sample_043_END2_gpu.bam --read-files-command zcat
and
Parabricks Options Mesg: @RG\tID:HYWM7BCXX161201.1\tLB:lib1\tPL:bar\tSM:sample\tPU:HYWM7BCXX161201.1
[PB Info 2023-Nov-16 02:49:59] ------------------------------------------------------------------------------
[PB Info 2023-Nov-16 02:49:59] || Parabricks accelerated Genomics Pipeline ||
[PB Info 2023-Nov-16 02:49:59] || Version 4.2.0-1 ||
[PB Info 2023-Nov-16 02:49:59] || star ||
[PB Info 2023-Nov-16 02:49:59] … started STAR run
[PB Info 2023-Nov-16 02:49:59] … loading genome
[PB Info 2023-Nov-16 02:50:29] read from genomeDir done 29.094
[PB Info 2023-Nov-16 02:50:29] Gpu num:2 Cpu thread num: 4
[PB Info 2023-Nov-16 02:50:29] … started mapping
Exiting…
Exiting pbrun …
Hi @vaibhav.a.janve
You seem to be using a GPU with less than 16 GB of memory.
One of the requirement for all Parabricks versions is :
Any NVIDIA GPU that supports CUDA architecture 60, 70, 75, or 80 and has at least 16GB of GPU RAM.
Please refer to the requirements here :
Best
Thank you @mdemouth! As I requested 120GB and 2GPU’s from cluster for this test. I assumed it would meet the 16GB requirement.
How to find the NVIDIA GPU RAM size?
This isn’t clear from the output of nvidia-smi. I only see
FB Memory Usage
Total : 11264 MiB
Reserved : 244 MiB
Used : 1 MiB
Free : 11018 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 15 MiB
Free : 241 MiB
As relevant section.
Here’s the full output for nvidia-smi -a
Timestamp : Thu Nov 16 12:14:37 2023
Driver Version : 510.47.03
CUDA Version : 11.6
Attached GPUs : 2
GPU 00000000:3B:00.0
Product Name : NVIDIA GeForce RTX 2080 Ti
Product Brand : GeForce
Product Architecture : Turing
Display Mode : Disabled
Display Active : Disabled
Persistence Mode : Enabled
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-74874d65-8321-5043-ad54-e91b0af95df4
Minor Number : 0
VBIOS Version : 90.02.17.00.5F
MultiGPU Board : No
Board ID : 0x3b00
GPU Part Number : N/A
Module ID : 0
Inforom Version
Image Version : G001.0000.02.04
OEM Object : 1.1
ECC Object : N/A
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GSP Firmware Version : N/A
GPU Virtualization Mode
Virtualization Mode : None
Host VGPU Mode : N/A
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x3B
Device : 0x00
Domain : 0x0000
Device Id : 0x1E0410DE
Bus Id : 00000000:3B:00.0
Sub System Id : 0x250319DA
GPU Link Info
PCIe Generation
Max : 3
Current : 1
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 0
Replay Number Rollovers : 0
Tx Throughput : 0 KB/s
Rx Throughput : 0 KB/s
Fan Speed : 29 %
Performance State : P8
Clocks Throttle Reasons
Idle : Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
FB Memory Usage
Total : 11264 MiB
Reserved : 244 MiB
Used : 1 MiB
Free : 11018 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 15 MiB
Free : 241 MiB
Compute Mode : Default
Utilization
Gpu : 0 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
SRAM Correctable : N/A
SRAM Uncorrectable : N/A
DRAM Correctable : N/A
DRAM Uncorrectable : N/A
Aggregate
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending Page Blacklist : N/A
Remapped Rows : N/A
Temperature
GPU Current Temp : 31 C
GPU Shutdown Temp : 94 C
GPU Slowdown Temp : 91 C
GPU Max Operating Temp : 89 C
GPU Target Temperature : 84 C
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
Power Readings
Power Management : Supported
Power Draw : 13.65 W
Power Limit : 250.00 W
Default Power Limit : 250.00 W
Enforced Power Limit : 250.00 W
Min Power Limit : 100.00 W
Max Power Limit : 280.00 W
Clocks
Graphics : 300 MHz
SM : 300 MHz
Memory : 405 MHz
Video : 540 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 2100 MHz
SM : 2100 MHz
Memory : 7000 MHz
Video : 1950 MHz
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Voltage
Graphics : N/A
Processes : None
GPU 00000000:5E:00.0
MIG Mode
Current : N/A
Pending : N/A
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-de63eff9-02a0-18c2-64b1-90d8dd631b69
Minor Number : 1
MultiGPU Board : No
Board ID : 0x5e00
Module ID : 0
Inforom Version
OEM Object : 1.1
ECC Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
IBMNPU
PCI
Bus : 0x5E
Device : 0x00
Domain : 0x0000
Bus Id : 00000000:5E:00.0
GPU Link Info
PCIe Generation
Max : 3
Current : 1
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Fan Speed : 29 %
Idle : Active
FB Memory Usage
Total : 11264 MiB
Reserved : 244 MiB
Used : 1 MiB
Free : 11018 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 5 MiB
Free : 251 MiB
Utilization
Gpu : 0 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Aggregate
Retired Pages
Remapped Rows : N/A
Temperature
Power Readings
Power Draw : 14.25 W
Clocks
Graphics : 300 MHz
SM : 300 MHz
Memory : 405 MHz
Video : 540 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 2100 MHz
SM : 2100 MHz
Memory : 7000 MHz
Video : 1950 MHz
Graphics : N/A
Clock Policy
Auto Boost : N/A
Voltage
Graphics : N/A
Processes : None
Is there a version of clara-parabricks that would run with 11GB of memory?
