[./deviceQuery] starting…
./deviceQuery Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
There are 2 devices supporting CUDA
Device 0: “Tesla C1060”
CUDA Driver Version / Runtime Version 4.0 / 4.0
CUDA Capability Major/Minor version number: 1.3
Total amount of global memory: 4096 MBytes (4294770688 bytes)
(30) Multiprocessors x ( 8) CUDA Cores/MP: 240 CUDA Cores
GPU Clock Speed: 1.30 GHz
Memory Clock rate: 800.00 Mhz
Memory Bus Width: 512-bit
Max Texture Dimension Size (x,y,z) 1D=(8192), 2D=(65536,32768), 3D=(2048,2048,2048)
Max Layered Texture Size (dim) x layers 1D=(8192) x 512, 2D=(8192,8192) x 512
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 16384
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 2147483647 bytes
Texture alignment: 256 bytes
Concurrent copy and execution: Yes with 1 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Concurrent kernel execution: No
Alignment requirement for Surfaces: Yes
Device has ECC support enabled: No
Device is using TCC driver mode: No
Device supports Unified Addressing (UVA): No
Device PCI Bus ID / PCI location ID: 131 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
Device 1: “GeForce GT 430”
CUDA Capability Major/Minor version number: 2.1
Total amount of global memory: 1024 MBytes (1073414144 bytes)
( 2) Multiprocessors x (48) CUDA Cores/MP: 96 CUDA Cores
GPU Clock Speed: 1.40 GHz
Memory Clock rate: 667.00 Mhz
Memory Bus Width: 128-bit
L2 Cache Size: 131072 bytes
Max Texture Dimension Size (x,y,z) 1D=(65536), 2D=(65536,65535), 3D=(2048,2048,2048)
Max Layered Texture Size (dim) x layers 1D=(16384) x 2048, 2D=(16384,16384) x 2048
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 32768
Warp size: 32
Maximum number of threads per block: 1024
Maximum sizes of each dimension of a block: 1024 x 1024 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 65535
Texture alignment: 512 bytes
Concurrent copy and execution: Yes with 2 copy engine(s)
Concurrent kernel execution: Yes
Device supports Unified Addressing (UVA): Yes
Device PCI Bus ID / PCI location ID: 2 / 0
Compute Mode:
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 4.0, CUDA Runtime Version = 4.0, NumDevs = 2, Device = Tesla C1060, Device = GeForce GT 430
[./deviceQuery] test results…
PASSED
