We have a HP Z820 windows 7 Professional 64bit Workstation with one Quadro K600 and two K40c GPUs. In the Device Manager, the NVIDIA_ControlPanel and the nvidia-smi tool all these Devices are listed and everything looks okay. But in the application we use and also in the DeviceQuery.exe from the Nvidia Cuda Samples only one the K600 and one K40 (PCI Bus ID = 65) is listed.
If we disable this K40 in the device manager the other K40 (PCI Bus ID = 6) is listed by DeviceQuery.exe and also works fine. When you look in the code cudaGetDeviceCount() returns 2 despite 3 cards installed in the computer.
Do you have an idea how we can get both K40 to work at the same time?
The output of nvidia-smi -q:
==============NVSMI LOG==============
Timestamp : Fri Sep 05 10:05:06 2014
Driver Version : 333.11
Attached GPUs : 3
GPU 0000:05:00.0
Product Name : Quadro K600
Display Mode : Enabled
Display Active : Enabled
Persistence Mode : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 128
Driver Model
Current : WDDM
Pending : WDDM
Serial Number : N/A
GPU UUID : GPU-fef0a0c7-797e-7aae-5cb9-aee185592eae
Minor Number : N/A
VBIOS Version : 80.07.77.00.0A
Inforom Version
Image Version : N/A
OEM Object : N/A
ECC Object : N/A
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
PCI
Bus : 0x05
Device : 0x00
Domain : 0x0000
Device Id : 0x0FFA10DE
Bus Id : 0000:05:00.0
Sub System Id : 0x094B103C
GPU Link Info
PCIe Generation
Max : 2
Current : 1
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Fan Speed : 25 %
Performance State : P8
Clocks Throttle Reasons : N/A
FB Memory Usage
Total : 1023 MiB
Used : 985 MiB
Free : 38 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 36 MiB
Free : 220 MiB
Compute Mode : Default
Utilization
Gpu : 4 %
Memory : 14 %
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Texture Memory : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending : N/A
Temperature
Gpu : 38 C
Power Readings
Power Management : N/A
Power Draw : N/A
Power Limit : N/A
Default Power Limit : N/A
Enforced Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
Clocks
Graphics : 324 MHz
SM : 324 MHz
Memory : 324 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 875 MHz
SM : 875 MHz
Memory : 891 MHz
Compute Processes
Process ID : 940
Name : Insufficient Permissions
Used GPU Memory : Not available in WDDM driver model
Process ID : 1176
GPU 0000:06:00.0
Product Name : Tesla K40c
Display Mode : Disabled
Display Active : Disabled
Driver Model
Current : TCC
Pending : TCC
Serial Number : 0323913091252
GPU UUID : GPU-a7ea7678-f060-95a5-0051-abfa6e2f50ae
Minor Number : N/A
VBIOS Version : 80.80.27.00.01
Inforom Version
Image Version : 2081.0206.01.04
OEM Object : 1.1
ECC Object : 3.0
GPU Operation Mode
Current : N/A
Pending : N/A
PCI
Bus : 0x06
Device : 0x00
Domain : 0x0000
Device Id : 0x102410DE
Bus Id : 0000:06:00.0
Sub System Id : 0x098310DE
GPU Link Info
PCIe Generation
Max : 3
Current : 1
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Fan Speed : 23 %
Idle : Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
Unknown : Not Active
FB Memory Usage
Total : 12287 MiB
Used : 22 MiB
Free : 12265 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 2 MiB
Free : 254 MiB
Utilization
Gpu : 0 %
Memory : 0 %
Ecc Mode
Current : Disabled
Pending : Disabled
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Retired Pages
Single Bit ECC : 0
Double Bit ECC : 3
Pending : No
Temperature
Gpu : 25 C
Power Readings
Power Management : Supported
Power Draw : 19.74 W
Power Limit : 235.00 W
Default Power Limit : 235.00 W
Enforced Power Limit : 235.00 W
Min Power Limit : 150.00 W
Max Power Limit : 235.00 W
Clocks
Graphics : 324 MHz
SM : 324 MHz
Memory : 324 MHz
Applications Clocks
Graphics : 745 MHz
Memory : 3004 MHz
Graphics : 745 MHz
Memory : 3004 MHz
Max Clocks
Graphics : 875 MHz
SM : 875 MHz
Memory : 3004 MHz
Compute Processes : None
GPU 0000:41:00.0
Driver Model
Current : TCC
Pending : TCC
Serial Number : 0323913091431
GPU UUID : GPU-50ae0829-893c-f51f-d06f-71128586ae00
Minor Number : N/A
Inforom Version
OEM Object : 1.1
ECC Object : 3.0
GPU Operation Mode
Current : N/A
Pending : N/A
PCI
Bus : 0x41
Device : 0x00
Domain : 0x0000
Bus Id : 0000:41:00.0
GPU Link Info
PCIe Generation
Max : 3
Current : 1
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Fan Speed : 23 %
Idle : Active
FB Memory Usage
Total : 12287 MiB
Used : 22 MiB
Free : 12265 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 2 MiB
Free : 254 MiB
Utilization
Gpu : 0 %
Memory : 0 %
Ecc Mode
Current : Disabled
Pending : Disabled
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Retired Pages
Single Bit ECC : 0
Double Bit ECC : 0
Pending : No
Temperature
Gpu : 32 C
Power Readings
Power Draw : 19.36 W
Clocks
Graphics : 324 MHz
SM : 324 MHz
Memory : 324 MHz
Applications Clocks
Graphics : 745 MHz
Memory : 3004 MHz
Graphics : 745 MHz
Memory : 3004 MHz
Max Clocks
Graphics : 875 MHz
SM : 875 MHz
Memory : 3004 MHz
looks good. But by DeviceQuerry.exe only one K40 is listed.
Output of DeviceQuery.exe:
DeviceQuerry.exe Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 2 CUDA Capable device(s)
Device 0: “Tesla K40c”
CUDA Driver Version / Runtime Version 6.0 / 5.0
CUDA Capability Major/Minor version number: 3.5
Total amount of global memory: 12288 MBytes (12884705280 bytes)
(15) Multiprocessors x (192) CUDA Cores/MP: 2880 CUDA Cores
GPU Clock rate: 876 MHz (0.88 GHz)
Memory Clock rate: 3004 Mhz
Memory Bus Width: 384-bit
L2 Cache Size: 1572864 bytes
Max Texture Dimension Size (x,y,z) 1D=(65536), 2D=(65536,65536), 3D=(4096,4096,4096)
Max Layered Texture Size (dim) x layers 1D=(16384) x 2048, 2D=(16384,16384) x 2048
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Maximum sizes of each dimension of a block: 1024 x 1024 x 64
Maximum sizes of each dimension of a grid: 2147483647 x 65535 x 65535
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device PCI Bus ID / PCI location ID: 6 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
Device 1: “Quadro K600”
CUDA Capability Major/Minor version number: 3.0
Total amount of global memory: 1024 MBytes (1073741824 bytes)
( 1) Multiprocessors x (192) CUDA Cores/MP: 192 CUDA Cores
Memory Clock rate: 891 Mhz
Memory Bus Width: 128-bit
L2 Cache Size: 262144 bytes
Warp size: 32
Concurrent copy and kernel execution: Yes with 1 copy engine(s)
Run time limit on kernels: Yes
Device PCI Bus ID / PCI location ID: 5 / 0
Compute Mode:
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 6.0, CUDA Runtime Version = 5.0, NumDevs = 2, Device0 = Tesla K40c, Device1 = Quadro K600
