cudaGetDeviceCount not detecting multiple cards
Good day,
I have a workstation with Ubuntu linux installed (14.04) and two nvidia cards:
-Quadro NVS 310
-Tesla K20
If I type:
lspci | grep NVIDIA
I get
03:00.0 VGA compatible controller: NVIDIA Corporation GF119 [NVS 310] (rev a1)
03:00.1 Audio device: NVIDIA Corporation GF119 HDMI Audio Controller (rev a1)
04:00.0 3D controller: NVIDIA Corporation GK110GL [Tesla K20c] (rev a1)
So I know the cards is recognized. However, if I use
cudaGetDeviceCount
function I get just one card listed and
cudaGetDeviceProperties
shows only the Quadro card:
Device Number: 0
  Device name: NVS 310
  Memory Clock Rate (KHz): 875000
  Memory Bus Width (bits): 64
  Peak Memory Bandwidth (GB/s): 14.000000
The code I use is:
int nDevices;
  cudaGetDeviceCount(&nDevices);
  cout << nDevices << " cards.\n";
  for (int i = 0; i < nDevices; i++) {
    cudaDeviceProp prop;
    cudaGetDeviceProperties(&prop, i);
    printf("Device Number: %d\n", i);
    printf("  Device name: %s\n", prop.name);
    printf("  Memory Clock Rate (KHz): %d\n",
           prop.memoryClockRate);
    printf("  Memory Bus Width (bits): %d\n",
           prop.memoryBusWidth);
    printf("  Peak Memory Bandwidth (GB/s): %f\n\n",
           2.0*prop.memoryClockRate*(prop.memoryBusWidth/8)/1.0e6);
Can someone help me with this?
Thank you :)
what is the output of:
nvidia-smi
and:
sudo dmesg |grep NVRM
Hi, and thank you for the reply.
nvidia-smi:
| NVIDIA-SMI 346.82     Driver Version: 346.82         |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  NVS 310             Off  | 0000:03:00.0     N/A |                  N/A |
| 30%   52C    P8    N/A /  N/A |    228MiB /   511MiB |     N/A      Default |
| Processes:                                                       GPU Memory |
|  GPU       PID  Type  Process name                               Usage      |
|    0              C   Not Supported                                         |
dmesg |grep NVRM:
[   17.159543] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  346.82  Wed Jun 17 10:37:46 PDT 2015
[   22.363096] NVRM: RmInitAdapter failed! (0x25:0x1c:1270)
[   22.363106] NVRM: rm_init_adapter failed for device bearing minor number 1
[   22.363130] NVRM: nvidia_frontend_open: minor 1, module->open() failed, error -5
[  472.740284] NVRM: RmInitAdapter failed! (0x25:0x1c:1270)
[  472.740297] NVRM: rm_init_adapter failed for device bearing minor number 1
[  472.740327] NVRM: nvidia_frontend_open: minor 1, module->open() failed, error -5
[14278.115520] NVRM: RmInitAdapter failed! (0x25:0x40:1270)
[14278.115542] NVRM: rm_init_adapter failed for device bearing minor number 1
[14278.115572] NVRM: nvidia_frontend_open: minor 1, module->open() failed, error -5
[17662.200736] NVRM: RmInitAdapter failed! (0x25:0x40:1270)
[17662.200755] NVRM: rm_init_adapter failed for device bearing minor number 1
[17662.200788] NVRM: nvidia_frontend_open: minor 1, module->open() failed, error -5
[17970.566928] NVRM: RmInitAdapter failed! (0x25:0x40:1270)
[17970.566949] NVRM: rm_init_adapter failed for device bearing minor number 1
[17970.566980] NVRM: nvidia_frontend_open: minor 1, module->open() failed, error -5
[20196.492173] NVRM: RmInitAdapter failed! (0x25:0x40:1270)
[20196.492192] NVRM: rm_init_adapter failed for device bearing minor number 1
[20196.492224] NVRM: nvidia_frontend_open: minor 1, module->open() failed, error -5
Which CUDA version did you install?
Did you follow the instructions in the linux getting started guide?
Which method (package manager or runfile installer) did you use to install CUDA?
At any time did you switch methods between package manager and installer?
Did you install the driver separately from installing CUDA?
Did you remove the nouveau driver?
Originally I shot down lightdm, then I removed (purged) all nvidia-* and installed the cuda 7.0 toolkit,
and finally added
export CUDA_HOME=/usr/local/cuda-7.0
export LD_LIBRARY_PATH=${CUDA_HOME}/lib64
PATH=${CUDA_HOME}/bin:${PATH}
export PATH
to the .bashrc file
If you want my help, please answer my questions.
version 7.0
Yes
local package installer (dpkg -i)
No.
No
No
what is the output from:
sudo lspci -vvv |grep -A 20 -i nvidia
and
sudo lsmod |grep -i nvidia
and
sudo lsmod |grep -i nouveau
sudo lspci -vvv |grep -A 20 -i nvidia:
03:00.0 VGA compatible controller: NVIDIA Corporation GF119 [NVS 310] (rev a1) (prog-if 00 [VGA controller])
	Subsystem: NVIDIA Corporation Device 094e
	Physical Slot: 2
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Interrupt: pin A routed to IRQ 86
	Region 0: Memory at f8000000 (32-bit, non-prefetchable)
	Region 1: Memory at e8000000 (64-bit, prefetchable)
	Region 3: Memory at f0000000 (64-bit, prefetchable)
	Region 5: I/O ports at d000
	[virtual] Expansion ROM at f9000000 [disabled]
	Capabilities: [60] Power Management version 3
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
		Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
	Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
		Address: 00000000fee00718  Data: 0000
	Capabilities: [78] Express (v2) Endpoint, MSI 00
		DevCap:	MaxPayload 128 bytes, PhantFunc 0, Latency L0s unlimited, L1 <64us
			ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
		DevCtl:	Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
			RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop-
	Kernel driver in use: nvidia
	Physical Slot: 2
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Latency: 0
	Interrupt: pin B routed to IRQ 36
	Region 0: Memory at f9080000 (32-bit, non-prefetchable)
	Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
		Address: 0000000000000000  Data: 0000
		DevCap:	MaxPayload 128 bytes, PhantFunc 0, Latency L0s <4us, L1 <64us
			RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop+
			MaxPayload 128 bytes, MaxReadReq 512 bytes
		DevSta:	CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
		LnkCap:	Port #0, Speed 2.5GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <256ns, L1 <4us
			ClockPM+ Surprise- LLActRep- BwNot-
	Subsystem: NVIDIA Corporation Device 0982
	Physical Slot: 4
	Latency: 0
	Interrupt: pin A routed to IRQ 40
	Region 0: Memory at fa000000 (32-bit, non-prefetchable)
	Region 1: Memory at d0000000 (64-bit, prefetchable)
	Region 3: Memory at e0000000 (64-bit, prefetchable)
		Address: 00000000fee00738  Data: 0000
		DevCap:	MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 <64us
			MaxPayload 256 bytes, MaxReadReq 512 bytes
		DevSta:	CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
06:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
	Subsystem: Dell Device 0619
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
	Latency: 0
	Interrupt: pin A routed to IRQ 19
	Region 0: Memory at fb500000 (32-bit, non-prefetchable)
	Region 2: I/O ports at c000
	Region 3: Memory at fb580000 (32-bit, non-prefetchable)
	Capabilities: [40] Power Management version 3
		Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
		Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=1 PME-
	Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
		Masking: 00000000  Pending: 00000000
	Capabilities: [70] MSI-X: Enable+ Count=5 Masked-
		Vector table: BAR=3 offset=00000000
		PBA: BAR=3 offset=00002000
	Capabilities: [a0] Express (v2) Endpoint, MSI 00
sudo lsmod |grep -i nvidia:
nvidia               8379750  43
drm                   303102  2 nvidia
sudo lsmod |grep -i nouveau: Nothing appears.
However the following packages appear installed using the synaptic package manager:
  • xserver-xorg-video-nouveau-lts-quantal
  • libdrm-nouveau2
Well, I don’t see any problems except the obvious ones reported by nvidia-smi and dmesg: the driver is not happy with the K20c.
Its remotely possible that it might be a defective motherboard or GPU at this point. Or something else that I am unaware of. But my guess right now is a broken driver install.
If it were my system, I would start with a clean build of ubuntu 14.04 and just install the driver, and use the runfile installer method. Effectively this means downloading and using a driver installer from nvidia.com (not apt). If that does not work for some reason, the driver installer log may provide some clues. If it does work, then you could move on to installing the CUDA toolkit via runfile installer method, or starting over with the package manager method and see if any mistakes were made along the way, or more closely analyzing what is going on and getting installed.
The lsmod output should have shown both an nvidia entry, and an nvidia_uvm entry. So I suspect a broken driver install at this point, although if you followed the instructions from the linux getting started guide, you should have gotten all the driver pieces. Trying to fix this using a package manager method would effectively mean removing or purging all the existing nvidia packages, and basically repeating the process that you already did. If you possibly made a mistake somewhere in that process, repeating the same process is not likely to produce a different result, which is why I suggest installing the driver via runfile installer.
If you decide to install the driver via runfile installer, be sure to follow the steps for removal of the nouveau driver. That is not just blacklisting, but also removal from the initrd image. These steps should work (as root):
echo -e "blacklist nouveau\noptions nouveau modeset=0"  > /etc/modprobe.d/disable-nouveau.conf
update-initramfs -u
Ok, I’ll try the run installation. Thanks.
Ok. So I did the .run installation and nvidia.smi told me that the card was underpowered. So I opened the case and there it was, for some reason the person that assembled the workstation did not connect both power cables to the k20. Now nvidia.smi detects both cards.
Thank you for the help.
