Hm. Interesting.
dmesg | grep NVRM yields:
[ 13.932709] NVRM: The NVIDIA probe routine was not called for 2 device(s).
[ 13.932712] NVRM: This can occur when a driver such as:
[ 13.932712] NVRM: nouveau, rivafb, nvidiafb or rivatv
[ 13.932712] NVRM: was loaded and obtained ownership of the NVIDIA device(s).
[ 13.932715] NVRM: Try unloading the conflicting kernel module (and/or
[ 13.932715] NVRM: reconfigure your kernel without the conflicting
[ 13.932715] NVRM: driver(s)), then try loading the NVIDIA kernel module
[ 13.932715] NVRM: again.
[ 13.932718] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 346.46 Tue Feb 17 17:56:08 PST 2015
[ 15.706270] NVRM: Your system is not currently configured to drive a VGA console
[ 15.706273] NVRM: on the primary VGA device. The NVIDIA Linux graphics driver
[ 15.706274] NVRM: requires the use of a text-mode VGA console. Use of other console
[ 15.706275] NVRM: drivers including, but not limited to, vesafb, may result in
[ 15.706275] NVRM: corruption and stability problems, and is not supported.
That seems illuminating.
lspci-vvv | grep -i -A 20 nvidia gave me
pcilib: sysfs_read_vpd: read failed: Connection timed out
05:00.0 VGA compatible controller: NVIDIA Corporation Device 17f0 (rev a1) (prog-if 00 [VGA controller])
Subsystem: NVIDIA Corporation Device 1129
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 68
Region 0: Memory at f6000000 (32-bit, non-prefetchable)
Region 1: Memory at a0000000 (64-bit, prefetchable)
Region 3: Memory at b0000000 (64-bit, prefetchable)
Region 5: I/O ports at e000
[virtual] Expansion ROM at f7000000 [disabled]
Capabilities: [60] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fee00000 Data: 40c5
Capabilities: [78] Express (v2) Legacy Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 <64us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop-
MaxPayload 256 bytes, MaxReadReq 512 bytes
Kernel driver in use: nvidia
05:00.1 Audio device: NVIDIA Corporation Device 0fb0 (rev a1)
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Latency: 0, Cache Line Size: 32 bytes
Interrupt: pin B routed to IRQ 67
Region 0: Memory at f7080000 (32-bit, non-prefetchable)
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [78] Express (v2) Endpoint, MSI 00
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop+
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #16, Speed 8GT/s, Width x16, ASPM not supported, Exit Latency L0s <512ns, L1 <4us
ClockPM+ Surprise- LLActRep- BwNot-
LnkCtl: ASPM L0s L1 Enabled; RCB 64 bytes Disabled- CommClk-
06:00.0 3D controller: NVIDIA Corporation GK110BGL [Tesla K40c] (rev a1)
Subsystem: NVIDIA Corporation Device 0983
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
Interrupt: pin A routed to IRQ 64
Region 0: Memory at f8000000 (32-bit, non-prefetchable)
Region 1: Memory at 80000000 (64-bit, prefetchable)
Region 3: Memory at 90000000 (64-bit, prefetchable)
Address: 00000000fee00000 Data: 4055
LnkCap: Port #8, Speed 8GT/s, Width x16, ASPM not supported, Exit Latency L0s <512ns, L1 <4us
09:00.0 3D controller: NVIDIA Corporation GK110BGL [Tesla K40c] (rev a1)
Interrupt: pin A routed to IRQ 63
Region 0: Memory at fa000000 (32-bit, non-prefetchable)
Region 1: Memory at c0000000 (64-bit, prefetchable)
Region 3: Memory at d0000000 (64-bit, prefetchable)
Address: 00000000fee00000 Data: 4045
I guess, I should try to deactivate that nouveau driver… But, any other insight would still be appreciated… Thanks!
