I’m using Ubuntu 16.04.5 LTS with GTX 1080 Ti GPUs. After installing the driver and CUDA 9.0, deviceQuery returns
/home/user/cuda-9.0/samples/1_Utilities/deviceQuery/deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 38
-> no CUDA-capable device is detected
Result = FAIL
HHowever, it runs with sudo
Detected 4 CUDA Capable device(s)
Device 0: "GeForce GTX 1080 Ti"
CUDA Driver Version / Runtime Version 9.0 / 9.0
CUDA Capability Major/Minor version number: 6.1
Total amount of global memory: 11172 MBytes (11715084288 bytes)
(28) Multiprocessors, (128) CUDA Cores/MP: 3584 CUDA Cores
GPU Max Clock rate: 1582 MHz (1.58 GHz)
Memory Clock rate: 5505 Mhz
Memory Bus Width: 352-bit
L2 Cache Size: 2883584 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Supports Cooperative Kernel Launch: Yes
Supports MultiDevice Co-op Kernel Launch: Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 2 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
Device 1: "GeForce GTX 1080 Ti"
Warp size: 32
Device PCI Domain ID / Bus ID / location ID: 0 / 3 / 0
Compute Mode:
Device 2: "GeForce GTX 1080 Ti"
Warp size: 32
Device PCI Domain ID / Bus ID / location ID: 0 / 129 / 0
Compute Mode:
Device 3: "GeForce GTX 1080 Ti"
Warp size: 32
Device PCI Domain ID / Bus ID / location ID: 0 / 130 / 0
Compute Mode:
> Peer access from GeForce GTX 1080 Ti (GPU0) -> GeForce GTX 1080 Ti (GPU1) : Yes
> Peer access from GeForce GTX 1080 Ti (GPU0) -> GeForce GTX 1080 Ti (GPU2) : No
> Peer access from GeForce GTX 1080 Ti (GPU0) -> GeForce GTX 1080 Ti (GPU3) : No
> Peer access from GeForce GTX 1080 Ti (GPU1) -> GeForce GTX 1080 Ti (GPU0) : Yes
> Peer access from GeForce GTX 1080 Ti (GPU1) -> GeForce GTX 1080 Ti (GPU2) : No
> Peer access from GeForce GTX 1080 Ti (GPU1) -> GeForce GTX 1080 Ti (GPU3) : No
> Peer access from GeForce GTX 1080 Ti (GPU2) -> GeForce GTX 1080 Ti (GPU0) : No
> Peer access from GeForce GTX 1080 Ti (GPU2) -> GeForce GTX 1080 Ti (GPU1) : No
> Peer access from GeForce GTX 1080 Ti (GPU2) -> GeForce GTX 1080 Ti (GPU3) : Yes
> Peer access from GeForce GTX 1080 Ti (GPU3) -> GeForce GTX 1080 Ti (GPU0) : No
> Peer access from GeForce GTX 1080 Ti (GPU3) -> GeForce GTX 1080 Ti (GPU1) : No
> Peer access from GeForce GTX 1080 Ti (GPU3) -> GeForce GTX 1080 Ti (GPU2) : Yes
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 9.0, CUDA Runtime Version = 9.0, NumDevs = 4
Result = PASS
Similar to Root access required for CUDA? - Stack Overflow
nvidia-smi
| NVIDIA-SMI 384.130 Driver Version: 384.130 |
| 0 GeForce GTX 108... On | 00000000:02:00.0 Off | N/A |
| 23% 35C P8 9W / 250W | 1MiB / 11172MiB | 0% Default |
| 1 GeForce GTX 108... On | 00000000:03:00.0 Off | N/A |
| 23% 30C P8 8W / 250W | 1MiB / 11172MiB | 0% Default |
| 2 GeForce GTX 108... On | 00000000:81:00.0 Off | N/A |
| 23% 28C P8 8W / 250W | 1MiB / 11172MiB | 0% Default |
| 3 GeForce GTX 108... On | 00000000:82:00.0 Off | N/A |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
/usr/bin/lspci | grep -i VGA
02:00.0 VGA compatible controller: NVIDIA Corporation Device 1b06 (rev a1)
03:00.0 VGA compatible controller: NVIDIA Corporation Device 1b06 (rev a1)
06:00.0 VGA compatible controller: ASPEED Technology, Inc. ASPEED Graphics Family (rev 30)
81:00.0 VGA compatible controller: NVIDIA Corporation Device 1b06 (rev a1)
82:00.0 VGA compatible controller: NVIDIA Corporation Device 1b06 (rev a1)
http://docs.nvidia.com/cuda/cuda-installation-guide-linux/index.html#runfile-verifications has been done.
ll /dev/nvidia*
crw-rw-rw- 1 root root 195, 0 Nov 16 16:29 /dev/nvidia0
crw-rw-rw- 1 root root 195, 1 Nov 16 16:29 /dev/nvidia1
crw-rw-rw- 1 root root 195, 2 Nov 16 16:29 /dev/nvidia2
crw-rw-rw- 1 root root 195, 3 Nov 16 16:29 /dev/nvidia3
crw-rw-rw- 1 root root 195, 255 Nov 16 16:29 /dev/nvidiactl
crw-rw-rw- 1 root root 195, 254 Nov 16 17:03 /dev/nvidia-modeset
crw-rw-rw- 1 root root 239, 0 Nov 16 16:29 /dev/nvidia-uvm
crw-rw-rw- 1 root root 239, 1 Nov 16 16:37 /dev/nvidia-uvm-tools
What could be the reason and possible solution to this problem? Thanks in advance!
