A3000 in my laptop is set to 80w TGP by default (90w max according to nvidia-settings), and that works just fine, when i do nvidia-smi or nvidia-settings after fresh boot, i see 80w.
But when i suspend and then resume, TGP goes down to 35w and it is stuck there
There seems to be something severely wrong with the nvidia gpu in that laptop. Runtime suspend doesn’t seem to work, so the nvidia gpu doesn’t shut off. I also suspect while in suspend, the nvidia gpu is on and not cooled anymore, it’s at 63°C in the logs after suspend/resume while nothing running on it and it should be sleeping.
/sys/bus/pci/devices/0000:01:00.0/power/control: on
Please check for a bios update first.
Everything seems to be fine and working correctly. Please suspend and resume, then post the output of
cat /sys/bus/pci/devices/0000:01:00.0/power/control
No, it’s not fine at all. The system is reporting the gpu is sleeping but it reports a temperature of 68°C when waked up. This is really dangerous, please report it to HP.
