BUG: Sporadic hang on suspend `GPU:0: Failed to query display engine channel state`
IIUC, this is the place for reporting bugs? nvidia-bug-report.sh just exits after collecting information.
Upon suspending my work laptop I occasionally get a freeze, with display staying lit and laptop starting to heat up. If I wait for a while, display then shows a stacktrace as below. This happens in ≈10% of cases. I haven’t seen this to happen on the first suspend after system is booted.
I think this is a regression, because I don’t seem to remember seeing this an year ago. Worth noting that some sporadic hang also happens with Nouaveau, but I didn’t compare stack traces/errors.
Log information (click to open)
мая 30 08:12:49 dell-g15 systemd-logind[625]: The system will suspend now!
мая 30 08:12:49 dell-g15 NetworkManager[623]: <info>  [1748581969.9755] manager: sleep: sleep requested (sleeping: no  enabled: yes)
мая 30 08:12:49 dell-g15 NetworkManager[623]: <info>  [1748581969.9755] device (enp3s0): state change: unavailable -> unmanaged (reason 'unmanaged-sleeping', managed-type: 'full')
мая 30 08:12:49 dell-g15 NetworkManager[623]: <info>  [1748581969.9815] device (p2p-dev-wlan0): state change: disconnected -> unmanaged (reason 'unmanaged-sleeping', managed-type: 'full')
мая 30 08:12:49 dell-g15 NetworkManager[623]: <info>  [1748581969.9817] manager: NetworkManager state is now ASLEEP
мая 30 08:12:49 dell-g15 NetworkManager[623]: <info>  [1748581969.9819] device (wlan0): state change: activated -> deactivating (reason 'sleeping', managed-type: 'full')
мая 30 08:12:49 dell-g15 systemd[1]: Starting Network Manager Script Dispatcher Service...
мая 30 08:12:50 dell-g15 systemd[1]: Started Network Manager Script Dispatcher Service.
мая 30 08:12:50 dell-g15 kernel: wlan0: deauthenticating from 60:e3:27:ab:bf:9c by local choice (Reason: 3=DEAUTH_LEAVING)
мая 30 08:12:50 dell-g15 wpa_supplicant[692]: nl80211: send_event_marker failed: Source based routing not supported
мая 30 08:12:50 dell-g15 wpa_supplicant[692]: wlan0: CTRL-EVENT-DISCONNECTED bssid=60:e3:27:ab:bf:9c reason=3 locally_generated=1
мая 30 08:12:50 dell-g15 wpa_supplicant[692]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
мая 30 08:12:50 dell-g15 NetworkManager[623]: <info>  [1748581970.0821] device (wlan0): state change: deactivating -> disconnected (reason 'sleeping', managed-type: 'full')
мая 30 08:12:50 dell-g15 NetworkManager[623]: <info>  [1748581970.0825] dhcp4 (wlan0): canceled DHCP transaction
мая 30 08:12:50 dell-g15 NetworkManager[623]: <info>  [1748581970.0825] dhcp4 (wlan0): activation: beginning transaction (timeout in 45 seconds)
мая 30 08:12:50 dell-g15 NetworkManager[623]: <info>  [1748581970.0825] dhcp4 (wlan0): state changed no lease
мая 30 08:12:50 dell-g15 kernel: ACPI Error: Thread 2286951296 cannot release Mutex [ECMX] acquired by thread 1642215168 (20240827/exmutex-378)
мая 30 08:12:50 dell-g15 kernel: ACPI Error: Aborting method \_SB.PCI0.LPCB.ECDV._Q66 due to previous error (AE_AML_NOT_OWNER) (20240827/psparse-529)
мая 30 08:12:50 dell-g15 NetworkManager[623]: <info>  [1748581970.1006] device (wlan0): set-hw-addr: set MAC address to 7A:DB:BF:E7:2A:76 (scanning)
мая 30 08:12:50 dell-g15 systemd-resolved[335115]: wlan0: Bus client set default route setting: no
мая 30 08:12:50 dell-g15 systemd-resolved[335115]: wlan0: Bus client reset DNS server list.
мая 30 08:12:50 dell-g15 NetworkManager[623]: <info>  [1748581970.1441] device (wlan0): supplicant interface state: completed -> disconnected
мая 30 08:12:50 dell-g15 NetworkManager[623]: <info>  [1748581970.1446] device (wlan0): state change: disconnected -> unmanaged (reason 'unmanaged-sleeping', managed-type: 'full')
мая 30 08:12:50 dell-g15 NetworkManager[623]: <info>  [1748581970.2733] device (wlan0): set-hw-addr: reset MAC address to F4:A4:75:D4:C3:FD (unmanage)
мая 30 08:12:50 dell-g15 wpa_supplicant[692]: p2p-dev-wlan0: CTRL-EVENT-DSCP-POLICY clear_all
мая 30 08:12:50 dell-g15 wpa_supplicant[692]: nl80211: deinit ifname=p2p-dev-wlan0 disabled_11b_rates=0
мая 30 08:12:50 dell-g15 wpa_supplicant[692]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
мая 30 08:12:50 dell-g15 systemd[1]: Reached target Sleep.
мая 30 08:12:50 dell-g15 systemd[1]: Starting NVIDIA system suspend actions...
мая 30 08:12:50 dell-g15 suspend[450748]: nvidia-suspend.service
мая 30 08:12:50 dell-g15 logger[450748]: <13>May 30 08:12:50 suspend: nvidia-suspend.service
мая 30 08:12:50 dell-g15 kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:0:0:0x00000011
мая 30 08:12:50 dell-g15 kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:2:0:0x00000011
мая 30 08:12:50 dell-g15 kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:4:0:0x00000011
        [… ⚠️ here spam of the presiouv message for thousands of lines. skipped ⚠️ …]
мая 30 08:12:51 dell-g15 kernel: nvidia-modeset: ERROR: GPU:0: Timed out waiting for core channel idle.
мая 30 08:12:51 dell-g15 kernel: nvidia-modeset: ERROR: GPU:0: Failed to tear down display engine channel
мая 30 08:12:51 dell-g15 kernel: nvidia-modeset: ERROR: GPU:0: Failed to tear down Disp
мая 30 08:12:51 dell-g15 kernel: ------------[ cut here ]------------
мая 30 08:12:51 dell-g15 kernel: WARNING: CPU: 7 PID: 450753 at nvidia/nv.c:4337 nv_set_system_power_state+0x2f9/0x480 [nvidia]
мая 30 08:12:51 dell-g15 kernel: Modules linked in: nft_nat wireguard curve25519_x86_64 libchacha20poly1305 chacha_x86_64 poly1305_x86_64 libcurve25519_generic libchacha ip6_udp_tunnel udp_tunnel rndis_host cdc_ether usbnet mii mptcp_diag tcp_diag udp_diag raw_diag inet_diag unix_diag rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device nft_queue nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables nfnetlink_queue ccm snd_ctl_led snd_soc_skl_hda_dsp snd_soc_intel_sof_board_helpers snd_sof_probes snd_soc_intel_hda_dsp_common snd_hda_codec_realtek snd_hda_codec_generic snd_hda_scodec_component snd_soc_dmic snd_sof_pci_intel_cnl snd_sof_intel_hda_generic soundwire_intel soundwire_cadence snd_sof_intel_hda_common snd_soc_hdac_hda snd_sof_intel_hda_mlink snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_acpi_intel_match snd_soc_acpi_intel_sdca_quirks soundwire_generic_allocation snd_soc_acpi soundwire_bus snd_soc_sdca snd_soc_avs snd_soc_hda_codec snd_hda_ext_core snd_soc_core
мая 30 08:12:51 dell-g15 kernel:  snd_compress ac97_bus snd_hda_codec_hdmi snd_pcm_dmaengine uhid cmac algif_hash algif_skcipher af_alg bnep intel_uncore_frequency intel_uncore_frequency_common intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel iwlmvm kvm irqbypass mac80211 polyval_clmulni polyval_generic ghash_clmulni_intel snd_hda_intel sha512_ssse3 libarc4 snd_intel_dspcfg uvcvideo sha1_ssse3 ptp pkcs8_key_parser snd_intel_sdw_acpi aesni_intel dell_pc pps_core nvidia_drm(POE) crypto_simd videobuf2_vmalloc snd_hda_codec btusb cryptd dell_laptop uvc nvidia_uvm(POE) rapl nvidia_modeset(POE) processor_thermal_device_pci_legacy videobuf2_memops btrtl iwlwifi snd_hda_core videobuf2_v4l2 processor_thermal_device dell_wmi btintel iTCO_wdt processor_thermal_wt_hint snd_hwdep videobuf2_common dell_smbios intel_cstate alienware_wmi btbcm vfat processor_thermal_rfim intel_pmc_bxt fat hid_multitouch ee1004 intel_rapl_msr mei_pxp mei_hdcp iTCO_vendor_support dell_wmi_sysman r8169 psmouse intel_uncore videodev spi_nor
мая 30 08:12:51 dell-g15 kernel:  processor_thermal_rapl btmtk dcdbas platform_profile nvidia(POE) dell_smm_hwmon firmware_attributes_class snd_pcm dell_wmi_descriptor realtek intel_rapl_common cfg80211 mtd intel_wmi_thunderbolt wmi_bmof mc i2c_i801 ucsi_acpi processor_thermal_wt_req mei_me mdio_devres bluetooth i2c_smbus snd_timer intel_lpss_pci libphy i2c_mux snd typec_ucsi processor_thermal_power_floor mei intel_lpss typec processor_thermal_mbox i2c_hid_acpi rfkill soundcore idma64 drm_ttm_helper intel_soc_dts_iosf intel_pch_thermal roles i2c_hid int3403_thermal mousedev intel_pmc_core joydev int340x_thermal_zone int3400_thermal pmt_telemetry pinctrl_cannonlake acpi_pad pmt_class acpi_thermal_rel intel_hid intel_vsec acpi_tad sparse_keymap mac_hid i2c_dev crypto_user dm_mod loop nfnetlink ip_tables x_tables nvme nvme_core sha256_ssse3 serio_raw spi_intel_pci atkbd nvme_auth spi_intel libps2 vivaldi_fmap i8042 serio hid_generic usbhid i915 i2c_algo_bit drm_buddy video wmi ttm intel_gtt drm_display_helper cec
мая 30 08:12:51 dell-g15 kernel: CPU: 7 UID: 0 PID: 450753 Comm: nvidia-sleep.sh Tainted: P           OE      6.14.7-arch2-1 #1 b64f38217d3fe6ae2df8fdbff12b3e301689405c
мая 30 08:12:51 dell-g15 kernel: Tainted: [P]=PROPRIETARY_MODULE, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
мая 30 08:12:51 dell-g15 kernel: Hardware name: Dell Inc. Dell G15 5510/050GJP, BIOS 1.5.0 07/02/2021
мая 30 08:12:51 dell-g15 kernel: RIP: 0010:nv_set_system_power_state+0x2f9/0x480 [nvidia]
мая 30 08:12:51 dell-g15 kernel: Code: 9b d0 06 00 00 48 85 db 75 d3 e9 d1 fd ff ff 0f 0b e9 0b fe ff ff 48 8b 3d ec 13 ee 00 4c 89 f6 e8 ac d4 e6 e8 e9 09 ff ff ff <0f> 0b 4c 89 ff e8 8d e8 ac e9 4d 85 f6 74 0d e8 33 4d cc 00 84 c0
мая 30 08:12:51 dell-g15 kernel: RSP: 0018:ffffa63522fa7b20 EFLAGS: 00010206
мая 30 08:12:51 dell-g15 kernel: RAX: 0000000000000011 RBX: 0000000000000011 RCX: ffffa63522fa7aa0
мая 30 08:12:51 dell-g15 kernel: RDX: 0000000000000000 RSI: 0000000000000246 RDI: ffffa63522fa7a50
мая 30 08:12:51 dell-g15 kernel: RBP: ffff8eb78a852000 R08: 0000000000000000 R09: ffffffffc1c90dc6
мая 30 08:12:51 dell-g15 kernel: R10: ffff8eb7ab3d94e0 R11: ffffe04e04acf640 R12: 0000000000000001
мая 30 08:12:51 dell-g15 kernel: R13: 0000000000000000 R14: ffff8eb80e530000 R15: ffff8eb78a8526a8
мая 30 08:12:51 dell-g15 kernel: FS:  00007f510cd76b80(0000) GS:ffff8ebb0d780000(0000) knlGS:0000000000000000
мая 30 08:12:51 dell-g15 kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
мая 30 08:12:51 dell-g15 kernel: CR2: 00007f510cfcf7b0 CR3: 000000012619e002 CR4: 00000000007726f0
мая 30 08:12:51 dell-g15 kernel: PKRU: 55555554
мая 30 08:12:51 dell-g15 kernel: Call Trace:
мая 30 08:12:51 dell-g15 kernel:  <TASK>
мая 30 08:12:51 dell-g15 kernel:  nv_procfs_write_suspend+0xde/0x150 [nvidia 7926522257c812c14b43f20767a52a0b66dc8d7e]
мая 30 08:12:51 dell-g15 kernel:  ? shmem_parse_opt_casefold.isra.0+0x40/0x100
мая 30 08:12:51 dell-g15 kernel:  proc_reg_write+0x57/0xb0
мая 30 08:12:51 dell-g15 kernel:  vfs_write+0xf1/0x470
мая 30 08:12:51 dell-g15 kernel:  ? __x64_sys_fcntl+0x90/0xf0
мая 30 08:12:51 dell-g15 kernel:  ? syscall_exit_to_user_mode+0x37/0x1c0
мая 30 08:12:51 dell-g15 kernel:  ksys_write+0x74/0xf0
мая 30 08:12:51 dell-g15 kernel:  do_syscall_64+0x7b/0x190
мая 30 08:12:51 dell-g15 kernel:  ? do_syscall_64+0x87/0x190
мая 30 08:12:51 dell-g15 kernel:  ? filp_flush+0x5d/0xa0
мая 30 08:12:51 dell-g15 kernel:  ? filp_close+0x25/0x40
мая 30 08:12:51 dell-g15 kernel:  ? do_dup2+0xaa/0x150
мая 30 08:12:51 dell-g15 kernel:  ? ksys_dup3+0x67/0xf0
мая 30 08:12:51 dell-g15 kernel:  ? clear_bhb_loop+0x40/0x90
мая 30 08:12:51 dell-g15 kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
мая 30 08:12:51 dell-g15 kernel: RIP: 0033:0x7f510ce79006
мая 30 08:12:51 dell-g15 kernel: Code: 5d e8 41 8b 93 08 03 00 00 59 5e 48 83 f8 fc 75 19 83 e2 39 83 fa 08 75 11 e8 26 ff ff ff 66 0f 1f 44 00 00 48 8b 45 10 0f 05 <48> 8b 5d f8 c9 c3 0f 1f 40 00 f3 0f 1e fa 55 48 89 e5 48 83 ec 08
мая 30 08:12:51 dell-g15 kernel: RSP: 002b:00007ffd70338310 EFLAGS: 00000202 ORIG_RAX: 0000000000000001
мая 30 08:12:51 dell-g15 kernel: RAX: ffffffffffffffda RBX: 0000000000000008 RCX: 00007f510ce79006
мая 30 08:12:51 dell-g15 kernel: RDX: 0000000000000008 RSI: 000055851898ca50 RDI: 0000000000000001
мая 30 08:12:51 dell-g15 kernel: RBP: 00007ffd70338330 R08: 0000000000000000 R09: 0000000000000000
мая 30 08:12:51 dell-g15 kernel: R10: 0000000000000000 R11: 0000000000000202 R12: 0000000000000008
мая 30 08:12:51 dell-g15 kernel: R13: 000055851898ca50 R14: 00007f510cfce5c0 R15: 0000000000000000
мая 30 08:12:51 dell-g15 kernel:  </TASK>
мая 30 08:12:51 dell-g15 kernel: ---[ end trace 0000000000000000 ]---
мая 30 08:12:51 dell-g15 kernel: WARNING: CPU: 7 PID: 450753 at nvidia/nv.c:4542 nv_set_system_power_state+0x315/0x480 [nvidia]
мая 30 08:12:51 dell-g15 kernel: CPU: 7 UID: 0 PID: 450753 Comm: nvidia-sleep.sh Tainted: P        W  OE      6.14.7-arch2-1 #1 b64f38217d3fe6ae2df8fdbff12b3e301689405c
мая 30 08:12:51 dell-g15 kernel: Tainted: [P]=PROPRIETARY_MODULE, [W]=WARN, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
мая 30 08:12:51 dell-g15 kernel: RIP: 0010:nv_set_system_power_state+0x315/0x480 [nvidia]
мая 30 08:12:51 dell-g15 kernel: Code: 00 4c 89 f6 e8 ac d4 e6 e8 e9 09 ff ff ff 0f 0b 4c 89 ff e8 8d e8 ac e9 4d 85 f6 74 0d e8 33 4d cc 00 84 c0 0f 85 44 01 00 00 <0f> 0b 48 c7 c7 10 b9 0e c2 45 31 e4 e8 6a e8 ac e9 48 c7 c7 10 b9
мая 30 08:12:51 dell-g15 kernel: RSP: 0018:ffffa63522fa7b20 EFLAGS: 00010246
мая 30 08:12:51 dell-g15 kernel: RAX: 0000000000000000 RBX: 0000000000000011 RCX: 000000002256c007
мая 30 08:12:51 dell-g15 kernel: RDX: 000000002256a007 RSI: 00003779f2415ee0 RDI: 0018530eb88effff
мая 30 08:12:51 dell-g15 kernel: RBP: ffff8eb78a852000 R08: 0000000000000000 R09: ffffffffc120a6b8
мая 30 08:12:51 dell-g15 kernel: R10: ffff8eb80e530000 R11: ffffe04e06394c00 R12: 0000000000000001
мая 30 08:12:51 dell-g15 kernel: WARNING: CPU: 7 PID: 450753 at nvidia/nv.c:4287 nv_restore_user_channels+0x4e/0x1d0 [nvidia]
мая 30 08:12:51 dell-g15 kernel: RIP: 0010:nv_restore_user_channels+0x4e/0x1d0 [nvidia]
мая 30 08:12:51 dell-g15 kernel: Code: 24 a8 06 00 00 4c 89 ef e8 cf 25 ad e9 f6 43 10 01 74 76 48 89 de 31 ff e8 9f 1c cc 00 41 89 c6 85 c0 0f 84 40 01 00 00 31 ed <0f> 0b 49 8d bc 24 e0 07 00 00 e8 a3 25 ad e9 be 01 00 00 00 48 89
мая 30 08:12:51 dell-g15 kernel: RSP: 0018:ffffa63522fa7af0 EFLAGS: 00010206
мая 30 08:12:51 dell-g15 kernel: RAX: 0000000000000011 RBX: ffff8eb78a852000 RCX: ffffa63522fa7a70
мая 30 08:12:51 dell-g15 kernel: RDX: 0000000000000000 RSI: 0000000000000246 RDI: ffffa63522fa7a20
мая 30 08:12:51 dell-g15 kernel: RBP: ffff8eb80e530000 R08: 0000000000000000 R09: ffffffffc1c90dc6
мая 30 08:12:51 dell-g15 kernel: R10: ffff8eb7ab3d94e0 R11: ffffe04e04acf640 R12: ffff8eb78a852000
мая 30 08:12:51 dell-g15 kernel: R13: ffff8eb78a8526a8 R14: 0000000000000011 R15: ffff8eb78a8526a8
мая 30 08:12:51 dell-g15 kernel:  nv_set_system_power_state+0x34b/0x480 [nvidia 7926522257c812c14b43f20767a52a0b66dc8d7e]
мая 30 08:12:51 dell-g15 systemd-resolved[335115]: Switching to fallback DNS server 1.1.1.1#cloudflare-dns.com.
мая 30 08:12:51 dell-g15 kernel: usb 1-1.1: USB disconnect, device number 68
мая 30 08:13:00 dell-g15 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
мая 30 08:13:08 dell-g15 kernel: usb 1-1: USB disconnect, device number 67
мая 30 08:13:08 dell-g15 kernel: usb 1-1.2: USB disconnect, device number 69
мая 30 08:13:42 dell-g15 systemd-logind[625]: Lid opened.
мая 30 08:13:42 dell-g15 kernel: ACPI Error: Thread 3767606144 cannot release Mutex [ECMX] acquired by thread 2759571200 (20240827/exmutex-378)
мая 30 08:13:42 dell-g15 kernel: ACPI Error: Aborting method \_SB.PCI0.LPCB.ECDV._Q66 due to previous error (AE_AML_NOT_OWNER) (20240827/psparse-529)
мая 30 08:13:49 dell-g15 systemd-logind[625]: Lid closed.
мая 30 08:13:49 dell-g15 kernel: ACPI Error: Thread 2942252800 cannot release Mutex [ECMX] acquired by thread 2503187328 (20240827/exmutex-378)
мая 30 08:13:49 dell-g15 kernel: ACPI Error: Aborting method \_SB.PCI0.LPCB.ECDV._Q66 due to previous error (AE_AML_NOT_OWNER) (20240827/psparse-529)
мая 30 08:15:55 dell-g15 kernel: BUG: unable to handle page fault for address: ffffa635011c9010
мая 30 08:15:55 dell-g15 kernel: #PF: supervisor read access in kernel mode
мая 30 08:15:55 dell-g15 kernel: #PF: error_code(0x0000) - not-present page
мая 30 08:15:55 dell-g15 kernel: PGD 100000067 P4D 100000067 PUD 10025a067 PMD 10840e067 PTE 0
мая 30 08:15:55 dell-g15 kernel: Oops: Oops: 0000 [#1] PREEMPT SMP NOPTI
мая 30 08:15:55 dell-g15 kernel: CPU: 1 UID: 0 PID: 450753 Comm: nvidia-sleep.sh Tainted: P        W  OE      6.14.7-arch2-1 #1 b64f38217d3fe6ae2df8fdbff12b3e301689405c
мая 30 08:15:55 dell-g15 kernel: Tainted: [P]=PROPRIETARY_MODULE, [W]=WARN, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
мая 30 08:15:55 dell-g15 kernel: Hardware name: Dell Inc. Dell G15 5510/050GJP, BIOS 1.5.0 07/02/2021
мая 30 08:15:55 dell-g15 kernel: RIP: 0010:_nv000117kms+0xbe/0x140 [nvidia_modeset]
мая 30 08:15:55 dell-g15 kernel: Code: 00 48 8d b5 0c fe ff ff 48 89 df e8 6c 55 06 00 48 89 c2 48 85 c0 75 cc 41 83 c4 01 48 83 c3 10 41 83 fc 04 75 ad 49 8b 7d 00 <48> 8b 47 08 8b 90 78 02 00 00 85 d2 74 45 8d 4a ff 4c 89 f0 48 8d
мая 30 08:15:55 dell-g15 kernel: RSP: 0018:ffffa63522fa7620 EFLAGS: 00010246
мая 30 08:15:55 dell-g15 kernel: RAX: 0000000000000000 RBX: ffff8eb7c2f10238 RCX: 0000000000000006
мая 30 08:15:55 dell-g15 kernel: RDX: 0000000000000000 RSI: ffff8eb7a8a6c288 RDI: ffffa635011c9008
мая 30 08:15:55 dell-g15 kernel: RBP: ffffa63522fa7820 R08: 0000000000000000 R09: ffffa63522fa762c
мая 30 08:15:55 dell-g15 kernel: R10: ffff8eb7d5380000 R11: ffffe04e0554e000 R12: 0000000000000004
мая 30 08:15:55 dell-g15 kernel: R13: ffff8eb7c2f100d8 R14: ffffa63522fa7630 R15: ffff8eb7c2f10018
мая 30 08:15:55 dell-g15 kernel: FS:  00007f510cd76b80(0000) GS:ffff8ebb0d480000(0000) knlGS:0000000000000000
мая 30 08:15:55 dell-g15 kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
мая 30 08:15:55 dell-g15 kernel: CR2: ffffa635011c9010 CR3: 000000012619e006 CR4: 00000000007726f0
мая 30 08:15:55 dell-g15 kernel: PKRU: 55555554
мая 30 08:15:55 dell-g15 kernel: Call Trace:
мая 30 08:15:55 dell-g15 kernel:  <TASK>
мая 30 08:15:55 dell-g15 kernel:  _nv000406kms+0x23/0x170 [nvidia_modeset 0dedb4ee533728d410b657e4cf4df2c466fe4f44]
мая 30 08:15:55 dell-g15 kernel:  ? _nv002895kms+0x97/0xb0 [nvidia_modeset 0dedb4ee533728d410b657e4cf4df2c466fe4f44]
мая 30 08:15:55 dell-g15 kernel:  _nv003104kms+0x8d/0xa0 [nvidia_modeset 0dedb4ee533728d410b657e4cf4df2c466fe4f44]
мая 30 08:15:55 dell-g15 kernel:  _nv000406kms+0x155/0x170 [nvidia_modeset 0dedb4ee533728d410b657e4cf4df2c466fe4f44]
мая 30 08:15:55 dell-g15 kernel:  _nv003103kms+0x226/0x240 [nvidia_modeset 0dedb4ee533728d410b657e4cf4df2c466fe4f44]
мая 30 08:15:55 dell-g15 kernel:  ? schedule+0x27/0xf0
мая 30 08:15:55 dell-g15 kernel:  ? schedule_timeout+0xbf/0x100
мая 30 08:15:55 dell-g15 kernel:  nvKmsResume+0x7f/0xb0 [nvidia_modeset 0dedb4ee533728d410b657e4cf4df2c466fe4f44]
мая 30 08:15:55 dell-g15 kernel:  nvkms_resume+0x1f/0x50 [nvidia_modeset 0dedb4ee533728d410b657e4cf4df2c466fe4f44]
мая 30 08:15:55 dell-g15 kernel:  nv_set_system_power_state+0x36f/0x480 [nvidia 7926522257c812c14b43f20767a52a0b66dc8d7e]
мая 30 08:15:55 dell-g15 kernel:  nv_procfs_write_suspend+0xde/0x150 [nvidia 7926522257c812c14b43f20767a52a0b66dc8d7e]
мая 30 08:15:55 dell-g15 kernel:  ? shmem_parse_opt_casefold.isra.0+0x40/0x100
мая 30 08:15:55 dell-g15 kernel:  proc_reg_write+0x57/0xb0
мая 30 08:15:55 dell-g15 kernel:  vfs_write+0xf1/0x470
мая 30 08:15:55 dell-g15 kernel:  ? __x64_sys_fcntl+0x90/0xf0
мая 30 08:15:55 dell-g15 kernel:  ? syscall_exit_to_user_mode+0x37/0x1c0
мая 30 08:15:55 dell-g15 kernel:  ksys_write+0x74/0xf0
мая 30 08:15:55 dell-g15 kernel:  do_syscall_64+0x7b/0x190
мая 30 08:15:55 dell-g15 kernel:  ? do_syscall_64+0x87/0x190
мая 30 08:15:55 dell-g15 kernel:  ? filp_flush+0x5d/0xa0
мая 30 08:15:55 dell-g15 kernel:  ? filp_close+0x25/0x40
мая 30 08:15:55 dell-g15 kernel:  ? do_dup2+0xaa/0x150
мая 30 08:15:55 dell-g15 kernel:  ? ksys_dup3+0x67/0xf0
мая 30 08:15:55 dell-g15 kernel:  ? clear_bhb_loop+0x40/0x90
мая 30 08:15:55 dell-g15 kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
мая 30 08:15:55 dell-g15 kernel: RIP: 0033:0x7f510ce79006
мая 30 08:15:55 dell-g15 kernel: Code: 5d e8 41 8b 93 08 03 00 00 59 5e 48 83 f8 fc 75 19 83 e2 39 83 fa 08 75 11 e8 26 ff ff ff 66 0f 1f 44 00 00 48 8b 45 10 0f 05 <48> 8b 5d f8 c9 c3 0f 1f 40 00 f3 0f 1e fa 55 48 89 e5 48 83 ec 08
мая 30 08:15:55 dell-g15 kernel: RSP: 002b:00007ffd70338310 EFLAGS: 00000202 ORIG_RAX: 0000000000000001
мая 30 08:15:55 dell-g15 kernel: RAX: ffffffffffffffda RBX: 0000000000000008 RCX: 00007f510ce79006
мая 30 08:15:55 dell-g15 kernel: RDX: 0000000000000008 RSI: 000055851898ca50 RDI: 0000000000000001
мая 30 08:15:55 dell-g15 kernel: RBP: 00007ffd70338330 R08: 0000000000000000 R09: 0000000000000000
мая 30 08:15:55 dell-g15 kernel: R10: 0000000000000000 R11: 0000000000000202 R12: 0000000000000008
мая 30 08:15:55 dell-g15 kernel: R13: 000055851898ca50 R14: 00007f510cfce5c0 R15: 0000000000000000
мая 30 08:15:55 dell-g15 kernel:  </TASK>
мая 30 08:15:55 dell-g15 kernel: Modules linked in: nft_nat wireguard curve25519_x86_64 libchacha20poly1305 chacha_x86_64 poly1305_x86_64 libcurve25519_generic libchacha ip6_udp_tunnel udp_tunnel rndis_host cdc_ether usbnet mii mptcp_diag tcp_diag udp_diag raw_diag inet_diag unix_diag rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device nft_queue nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables nfnetlink_queue ccm snd_ctl_led snd_soc_skl_hda_dsp snd_soc_intel_sof_board_helpers snd_sof_probes snd_soc_intel_hda_dsp_common snd_hda_codec_realtek snd_hda_codec_generic snd_hda_scodec_component snd_soc_dmic snd_sof_pci_intel_cnl snd_sof_intel_hda_generic soundwire_intel soundwire_cadence snd_sof_intel_hda_common snd_soc_hdac_hda snd_sof_intel_hda_mlink snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_acpi_intel_match snd_soc_acpi_intel_sdca_quirks soundwire_generic_allocation snd_soc_acpi soundwire_bus snd_soc_sdca snd_soc_avs snd_soc_hda_codec snd_hda_ext_core snd_soc_core
мая 30 08:15:55 dell-g15 kernel:  snd_compress ac97_bus snd_hda_codec_hdmi snd_pcm_dmaengine uhid cmac algif_hash algif_skcipher af_alg bnep intel_uncore_frequency intel_uncore_frequency_common intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel iwlmvm kvm irqbypass mac80211 polyval_clmulni polyval_generic ghash_clmulni_intel snd_hda_intel sha512_ssse3 libarc4 snd_intel_dspcfg uvcvideo sha1_ssse3 ptp pkcs8_key_parser snd_intel_sdw_acpi aesni_intel dell_pc pps_core nvidia_drm(POE) crypto_simd videobuf2_vmalloc snd_hda_codec btusb cryptd dell_laptop uvc nvidia_uvm(POE) rapl nvidia_modeset(POE) processor_thermal_device_pci_legacy videobuf2_memops btrtl iwlwifi snd_hda_core videobuf2_v4l2 processor_thermal_device dell_wmi btintel iTCO_wdt processor_thermal_wt_hint snd_hwdep videobuf2_common dell_smbios intel_cstate alienware_wmi btbcm vfat processor_thermal_rfim intel_pmc_bxt fat hid_multitouch ee1004 intel_rapl_msr mei_pxp mei_hdcp iTCO_vendor_support dell_wmi_sysman r8169 psmouse intel_uncore videodev spi_nor
мая 30 08:15:55 dell-g15 kernel:  processor_thermal_rapl btmtk dcdbas platform_profile nvidia(POE) dell_smm_hwmon firmware_attributes_class snd_pcm dell_wmi_descriptor realtek intel_rapl_common cfg80211 mtd intel_wmi_thunderbolt wmi_bmof mc i2c_i801 ucsi_acpi processor_thermal_wt_req mei_me mdio_devres bluetooth i2c_smbus snd_timer intel_lpss_pci libphy i2c_mux snd typec_ucsi processor_thermal_power_floor mei intel_lpss typec processor_thermal_mbox i2c_hid_acpi rfkill soundcore idma64 drm_ttm_helper intel_soc_dts_iosf intel_pch_thermal roles i2c_hid int3403_thermal mousedev intel_pmc_core joydev int340x_thermal_zone int3400_thermal pmt_telemetry pinctrl_cannonlake acpi_pad pmt_class acpi_thermal_rel intel_hid intel_vsec acpi_tad sparse_keymap mac_hid i2c_dev crypto_user dm_mod loop nfnetlink ip_tables x_tables nvme nvme_core sha256_ssse3 serio_raw spi_intel_pci atkbd nvme_auth spi_intel libps2 vivaldi_fmap i8042 serio hid_generic usbhid i915 i2c_algo_bit drm_buddy video wmi ttm intel_gtt drm_display_helper cec
мая 30 08:15:55 dell-g15 kernel: ---[ end trace 0000000000000000 ]---
мая 30 08:15:55 dell-g15 kernel: note: nvidia-sleep.sh[450753] exited with irqs disabled
мая 30 08:15:55 dell-g15 kernel: PM: suspend entry (s2idle)
мая 30 08:15:55 dell-g15 systemd[1]: nvidia-suspend.service: Main process exited, code=killed, status=9/KILL
мая 30 08:15:55 dell-g15 systemd[1]: nvidia-suspend.service: Failed with result 'signal'.
мая 30 08:15:55 dell-g15 systemd[1]: Failed to start NVIDIA system suspend actions.
мая 30 08:15:55 dell-g15 systemd[1]: nvidia-suspend.service: Consumed 3min 3.989s CPU time, 1.9M memory peak.
мая 30 08:15:55 dell-g15 systemd[1]: Starting System Suspend...
мая 30 08:15:55 dell-g15 systemd-sleep[450843]: User sessions remain unfrozen on explicit request ($SYSTEMD_SLEEP_FREEZE_USER_SESSIONS=0).
мая 30 08:15:55 dell-g15 systemd-sleep[450843]: This is not recommended, and might result in unexpected behavior, particularly
мая 30 08:15:55 dell-g15 systemd-sleep[450843]: in suspend-then-hibernate operations or setups with encrypted home directories.
мая 30 08:15:55 dell-g15 systemd-sleep[450843]: Performing sleep operation 'suspend'...
мая 30 08:15:55 dell-g15 kernel: Filesystems sync: 0.020 seconds
мая 30 08:15:56 dell-g15 kernel: Freezing user space processes
мая 30 08:15:56 dell-g15 kernel: Freezing user space processes completed (elapsed 0.002 seconds)
мая 30 08:15:56 dell-g15 kernel: OOM killer disabled.
мая 30 08:15:56 dell-g15 kernel: Freezing remaining freezable tasks
мая 30 08:15:56 dell-g15 kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
мая 30 08:15:56 dell-g15 kernel: printk: Suspending console(s) (use no_console_suspend to debug)
мая 30 08:15:56 dell-g15 kernel: NVRM: GPU 0000:01:00.0: PreserveVideoMemoryAllocations module parameter is set. System Power Management attempted without driver procfs suspend interface. Please refer to the 'Configuring Power Management Support' section in the driver README.
мая 30 08:15:56 dell-g15 kernel: nvidia 0000:01:00.0: PM: pci_pm_suspend(): nv_pmops_suspend [nvidia] returns -5
мая 30 08:15:56 dell-g15 kernel: nvidia 0000:01:00.0: PM: dpm_run_callback(): pci_pm_suspend returns -5
мая 30 08:15:56 dell-g15 kernel: nvidia 0000:01:00.0: PM: failed to suspend async: error -5
мая 30 08:15:56 dell-g15 kernel: PM: Some devices failed to suspend, or early wake event detected
мая 30 08:15:56 dell-g15 kernel: nvme nvme0: 12/0/0 default/read/poll queues
мая 30 08:15:56 dell-g15 kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
мая 30 08:15:56 dell-g15 kernel: OOM killer enabled.
мая 30 08:15:56 dell-g15 kernel: pci_bus 0000:02: Allocating resources
мая 30 08:15:56 dell-g15 kernel: Restarting tasks ...
мая 30 08:15:56 dell-g15 kernel: done.
мая 30 08:15:56 dell-g15 kernel: random: crng reseeded on system resumption
мая 30 08:15:56 dell-g15 kernel: PM: suspend exit
мая 30 08:15:56 dell-g15 kernel: PM: suspend entry (s2idle)
System/hw information:
CPU: 6-core Intel Core i5-10500H (-MT MCP-) speed/min/max: 900/800/4500 MHz
Kernel: 6.14.7-arch2-1 x86_64 Up: 55m Mem: 5.03/15.27 GiB (32.9%)
Storage: 476.94 GiB (92.7% used) Procs: 344 Shell: Zsh inxi: 3.3.38
Graphics:
  Device-1: Intel CometLake-H GT2 [UHD Graphics] driver: i915 v: kernel
  Device-2: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile] driver: nvidia
    v: 570.153.02
  Device-3: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6 driver: X:
    loaded: modesetting,nvidia dri: iris gpu: i915 resolution: 1: N/A
    2: 1920x1080~120Hz
  API: EGL v: 1.5 drivers: iris,nouveau,nvidia,swrast
    platforms: gbm,x11,surfaceless,device
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.1.1-arch1.1
    renderer: Mesa Intel UHD Graphics (CML GT2)
  API: Vulkan v: 1.4.313 drivers: intel,nvidia surfaces: N/A
  Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo
    de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: swaymsg,wayland-info
    x11: xdpyinfo, xprop, xrandr
Still a problem with NVidia 575.57.08 and kernel 6.15.2.
Just found about nvidia-smi -q, posting its output as well. Can’t edit the original post anymore.
nvidia-smi -q output
==============NVSMI LOG==============
Timestamp                                 : Sat Jun 14 11:38:43 2025
Driver Version                            : 575.57.08
CUDA Version                              : 12.9
Attached GPUs                             : 1
GPU 00000000:01:00.0
    Product Name                          : NVIDIA GeForce RTX 3050 Ti Laptop GPU
    Product Brand                         : GeForce
    Product Architecture                  : Ampere
    Display Mode                          : Requested functionality has been deprecated
    Display Attached                      : No
    Display Active                        : Disabled
    Persistence Mode                      : Disabled
    Addressing Mode                       : None
    MIG Mode
        Current                           : N/A
        Pending                           : N/A
    Accounting Mode                       : Disabled
    Accounting Mode Buffer Size           : 4000
    Driver Model
        Current                           : N/A
        Pending                           : N/A
    Serial Number                         : N/A
    GPU UUID                              : GPU-caf5380f-86eb-8100-f033-e7f685f3f3d9
    Minor Number                          : 0
    VBIOS Version                         : 94.07.3B.40.9A
    MultiGPU Board                        : No
    Board ID                              : 0x100
    Board Part Number                     : N/A
    GPU Part Number                       : 25A0-775-A1
    FRU Part Number                       : N/A
    Platform Info
        Chassis Serial Number             : N/A
        Slot Number                       : N/A
        Tray Index                        : N/A
        Host ID                           : N/A
        Peer Type                         : N/A
        Module Id                         : 1
        GPU Fabric GUID                   : N/A
    Inforom Version
        Image Version                     : G001.0000.03.03
        OEM Object                        : 2.0
        ECC Object                        : N/A
        Power Management Object           : N/A
    Inforom BBX Object Flush
        Latest Timestamp                  : N/A
        Latest Duration                   : N/A
    GPU Operation Mode
        Current                           : N/A
        Pending                           : N/A
    GPU C2C Mode                          : N/A
    GPU Virtualization Mode
        Virtualization Mode               : None
        Host VGPU Mode                    : N/A
        vGPU Heterogeneous Mode           : N/A
    GPU Reset Status
        Reset Required                    : Requested functionality has been deprecated
        Drain and Reset Recommended       : Requested functionality has been deprecated
    GPU Recovery Action                   : None
    GSP Firmware Version                  : 575.57.08
    IBMNPU
        Relaxed Ordering Mode             : N/A
    PCI
        Bus                               : 0x01
        Device                            : 0x00
        Domain                            : 0x0000
        Base Classcode                    : 0x3
        Sub Classcode                     : 0x0
        Device Id                         : 0x25A010DE
        Bus Id                            : 00000000:01:00.0
        Sub System Id                     : 0x0A641028
        GPU Link Info
            PCIe Generation
                Max                       : 3
                Current                   : 3
                Device Current            : 3
                Device Max                : 4
                Host Max                  : 3
            Link Width
                Max                       : 16x
                Current                   : 8x
        Bridge Chip
            Type                          : N/A
            Firmware                      : N/A
        Replays Since Reset               : 0
        Replay Number Rollovers           : 0
        Tx Throughput                     : 450 KB/s
        Rx Throughput                     : 350 KB/s
        Atomic Caps Outbound              : N/A
        Atomic Caps Inbound               : N/A
    Fan Speed                             : N/A
    Performance State                     : P0
    Clocks Event Reasons
        Idle                              : Active
        Applications Clocks Setting       : Not Active
        SW Power Cap                      : Not Active
        HW Slowdown                       : Not Active
            HW Thermal Slowdown           : Not Active
            HW Power Brake Slowdown       : Not Active
        Sync Boost                        : Not Active
        SW Thermal Slowdown               : Not Active
        Display Clock Setting             : Not Active
    Clocks Event Reasons Counters
        SW Power Capping                  : 0 us
        Sync Boost                        : 0 us
        SW Thermal Slowdown               : 0 us
        HW Thermal Slowdown               : 0 us
        HW Power Braking                  : 0 us
    Sparse Operation Mode                 : N/A
    FB Memory Usage
        Total                             : 4096 MiB
        Reserved                          : 328 MiB
        Used                              : 15 MiB
        Free                              : 3755 MiB
    BAR1 Memory Usage
        Total                             : 4096 MiB
        Used                              : 3 MiB
        Free                              : 4093 MiB
    Conf Compute Protected Memory Usage
        Total                             : 0 MiB
        Used                              : 0 MiB
        Free                              : 0 MiB
    Compute Mode                          : Default
    Utilization
        GPU                               : 0 %
        Memory                            : 0 %
        Encoder                           : 0 %
        Decoder                           : 0 %
        JPEG                              : 0 %
        OFA                               : 0 %
    Encoder Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    FBC Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    DRAM Encryption Mode
        Current                           : N/A
        Pending                           : N/A
    ECC Mode
        Current                           : N/A
        Pending                           : N/A
    ECC Errors
        Volatile
            SRAM Correctable              : N/A
            SRAM Uncorrectable Parity     : N/A
            SRAM Uncorrectable SEC-DED    : N/A
            DRAM Correctable              : N/A
            DRAM Uncorrectable            : N/A
        Aggregate
            SRAM Threshold Exceeded       : N/A
        Aggregate Uncorrectable SRAM Sources
            SRAM L2                       : N/A
            SRAM SM                       : N/A
            SRAM Microcontroller          : N/A
            SRAM PCIE                     : N/A
            SRAM Other                    : N/A
    Retired Pages
        Single Bit ECC                    : N/A
        Double Bit ECC                    : N/A
        Pending Page Blacklist            : N/A
    Remapped Rows                         : N/A
    Temperature
        GPU Current Temp                  : 40 C
        GPU T.Limit Temp                  : N/A
        GPU Shutdown Temp                 : 100 C
        GPU Slowdown Temp                 : 97 C
        GPU Max Operating Temp            : 105 C
        GPU Target Temperature            : 87 C
        Memory Current Temp               : N/A
        Memory Max Operating Temp         : N/A
    GPU Power Readings
        Average Power Draw                : N/A
        Instantaneous Power Draw          : 13.55 W
        Current Power Limit               : 80.00 W
        Requested Power Limit             : 80.00 W
        Default Power Limit               : 80.00 W
        Min Power Limit                   : 1.00 W
        Max Power Limit                   : 95.00 W
    GPU Memory Power Readings
        Instantaneous Power Draw          : N/A
    Module Power Readings
        Current Power Limit               : N/A
        Requested Power Limit             : N/A
        Default Power Limit               : N/A
        Min Power Limit                   : N/A
        Max Power Limit                   : N/A
    Power Smoothing                       : N/A
    Workload Power Profiles
        Requested Profiles                : N/A
        Enforced Profiles                 : N/A
    Clocks
        Graphics                          : 1695 MHz
        SM                                : 1695 MHz
        Memory                            : 6000 MHz
        Video                             : 1492 MHz
    Applications Clocks
        Graphics                          : N/A
        Memory                            : N/A
    Default Applications Clocks
        Graphics                          : N/A
        Memory                            : N/A
    Deferred Clocks
        Memory                            : N/A
    Max Clocks
        Graphics                          : 2100 MHz
        SM                                : 2100 MHz
        Memory                            : 6001 MHz
        Video                             : 1950 MHz
    Max Customer Boost Clocks
        Graphics                          : N/A
    Clock Policy
        Auto Boost                        : N/A
        Auto Boost Default                : N/A
    Voltage
        Graphics                          : Requested functionality has been deprecated
    Fabric
        State                             : N/A
        Status                            : N/A
        CliqueId                          : N/A
        ClusterUUID                       : N/A
        Health
            Bandwidth                     : N/A
            Route Recovery in progress    : N/A
            Route Unhealthy               : N/A
            Access Timeout Recovery       : N/A
    Processes
        GPU instance ID                   : N/A
        Compute instance ID               : N/A
        Process ID                        : 724
            Type                          : G
            Used GPU Memory               : 4 MiB
    Capabilities
        EGM                               : disabled
This becomes serious, I suspended twice today, and both times my system crashed. Can we please get some action here, it’s been ½ a month and driver seems deteriorate with newer releases.
yup, having same issue.
Jun 14 12:44:10 fedora systemd[1]: Reached target sleep.target - Sleep.
Jun 14 12:44:10 fedora systemd[1]: Starting nvidia-suspend.service - NVIDIA system suspend actions...
Jun 14 12:44:10 fedora suspend[22439]: nvidia-suspend.service
Jun 14 12:44:10 fedora logger[22439]: <13>Jun 14 12:44:10 suspend: nvidia-suspend.service
Jun 14 12:44:10 fedora kernel: rfkill: input handler enabled
Jun 14 12:44:10 fedora kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:0:0:0x00000011
Jun 14 12:44:10 fedora kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:2:0:0x00000011
Jun 14 12:44:10 fedora kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:4:0:0x00000011
Jun 14 12:44:10 fedora kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:6:0:0x00000011
Jun 14 12:44:10 fedora kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67d:0:0:0x00000011
Jun 14 12:44:14 fedora kernel: nvidia-modeset: ERROR: GPU:0: Failed to tear down display engine channel
Jun 14 12:44:14 fedora kernel: NVRM: _issueRpcAndWait: rpcSendMessage failed with status 0x00000011 for fn 10!
Jun 14 12:44:14 fedora kernel: NVRM: rpcRmApiFree_GSP: GspRmFree failed: hClient=0xc1d00002; hObject=0x00010011; paramsStatus=0x00000000; status=0x00000011
Jun 14 12:44:14 fedora kernel: NVRM: nvAssertFailedNoLog: Assertion failed: (status == NV_OK) || (status == NV_ERR_GPU_IN_FULLCHIP_RESET) @ rs_client.c:844
Jun 14 12:44:14 fedora kernel: NVRM: nvAssertFailedNoLog: Assertion failed: (status == NV_OK) || (status == NV_ERR_GPU_IN_FULLCHIP_RESET) @ rs_server.c:259
Jun 14 12:44:14 fedora kernel: nvidia-modeset: ERROR: GPU:0: Failed to tear down Disp
Jun 14 12:44:14 fedora kernel: ------------[ cut here ]------------
Jun 14 12:44:14 fedora kernel: WARNING: CPU: 6 PID: 22440 at nvidia/nv.c:4430 nv_suspend_devices+0x19c/0x300 [nvidia]
Jun 14 12:44:14 fedora kernel: Modules linked in: uinput rfcomm snd_seq_dummy snd_hrtimer nf_conntrack_netbios_ns nf_conntrack_broadcast nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables ip_set qrtr uhid bnep sunrpc binfmt_misc vfat fat snd_ctl_led snd_soc_skl_hda_dsp snd_soc_intel_sof_board_helpers snd_sof_probes snd_soc_intel_hda_dsp_common snd_hda_codec_realtek snd_hda_codec_generic snd_hda_scodec_component snd_soc_dmic snd_sof_pci_intel_tgl snd_sof_pci_intel_cnl snd_sof_intel_hda_generic soundwire_intel soundwire_cadence snd_sof_intel_hda_common snd_soc_hdac_hda snd_sof_intel_hda_mlink snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_acpi_intel_match snd_soc_acpi_intel_sdca_quirks soundwire_generic_allocation snd_soc_acpi soundwire_bus snd_soc_sdca snd_soc_avs snd_soc_hda_codec snd_hda_ext_core snd_soc_core snd_hda_codec_hdmi snd_compress ac97_bus snd_pcm_dmaengine
Jun 14 12:44:14 fedora kernel:  squashfs intel_uncore_frequency intel_uncore_frequency_common iwlmvm x86_pkg_temp_thermal intel_powerclamp coretemp mac80211 kvm_intel nvidia_drm(OE) nvidia_modeset(OE) libarc4 kvm nvidia_uvm(OE) snd_hda_intel iwlwifi snd_intel_dspcfg snd_intel_sdw_acpi snd_hda_codec uvcvideo btusb btrtl snd_hda_core uvc btintel videobuf2_vmalloc spi_nor iTCO_wdt videobuf2_memops videobuf2_v4l2 btbcm irqbypass intel_pmc_bxt snd_hwdep videobuf2_common btmtk rapl mtd mei_hdcp mei_pxp spd5118 iTCO_vendor_support intel_rapl_msr cfg80211 snd_seq intel_cstate bluetooth videodev thunderbolt snd_seq_device nvidia(OE) processor_thermal_device_pci intel_uncore snd_pcm processor_thermal_device mc processor_thermal_wt_hint mei_me pcspkr processor_thermal_rfim snd_timer processor_thermal_rapl wmi_bmof snd mei intel_rapl_common spi_intel_pci i2c_i801 idma64 rfkill spi_intel processor_thermal_wt_req soundcore i2c_smbus igen6_edac processor_thermal_power_floor processor_thermal_mbox int3403_thermal intel_pmc_core joydev
Jun 14 12:44:14 fedora kernel:  int340x_thermal_zone pmt_telemetry int3400_thermal pmt_class intel_hid acpi_thermal_rel acpi_tad sparse_keymap acpi_pad loop nfnetlink zram lz4hc_compress lz4_compress dm_crypt xe drm_ttm_helper gpu_sched drm_suballoc_helper drm_gpuvm drm_exec i915 i2c_algo_bit drm_buddy ttm nvme sdhci_pci drm_display_helper nvme_core sdhci_uhs2 polyval_clmulni sdhci polyval_generic ghash_clmulni_intel sha512_ssse3 cqhci sha256_ssse3 hid_multitouch nvidia_wmi_ec_backlight mmc_core sha1_ssse3 cec nvme_auth intel_vsec i2c_hid_acpi i2c_hid video wmi pinctrl_tigerlake i2c_dev fuse
Jun 14 12:44:14 fedora kernel: CPU: 6 UID: 0 PID: 22440 Comm: nvidia-sleep.sh Tainted: G           OE      6.14.9-300.fc42.x86_64 #1
Jun 14 12:44:14 fedora kernel: Tainted: [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
Jun 14 12:44:14 fedora kernel: Hardware name: Razer Blade 15 (2022) - RZ09-0421/CH580, BIOS 2.06 11/01/2023
Jun 14 12:44:14 fedora kernel: RIP: 0010:nv_suspend_devices+0x19c/0x300 [nvidia]
Jun 14 12:44:14 fedora kernel: Code: 3c d9 e9 f4 fe ff ff 48 c7 c7 f0 29 75 c1 e8 9b ae 16 da 31 ed 48 83 c4 08 89 e8 5b 5d 41 5c 41 5d 41 5e 41 5f c3 cc cc cc cc <0f> 0b 4c 89 e7 e8 7a ae 16 da 4d 85 ed 74 0d e8 20 d0 12 00 84 c0
Jun 14 12:44:14 fedora kernel: RSP: 0018:ffffd391a8f5bda8 EFLAGS: 00010206
Jun 14 12:44:14 fedora kernel: RAX: 0000000000000011 RBX: ffff8d10c3600000 RCX: ffffd391a8f5bd38
Jun 14 12:44:14 fedora kernel: RDX: 0000000000000000 RSI: 0000000000000292 RDI: ffffd391a8f5bcf8
Jun 14 12:44:14 fedora kernel: RBP: 0000000000000011 R08: 0000000000000000 R09: ffffffffc1712b86
Jun 14 12:44:14 fedora kernel: R10: ffff8d10fbbc4de0 R11: fffff57704eef100 R12: ffff8d10c36006a8
Jun 14 12:44:14 fedora kernel: R13: 0000000000000000 R14: 0000000000000001 R15: 0000000000000000
Jun 14 12:44:14 fedora kernel: FS:  00007f23b947f740(0000) GS:ffff8d145d500000(0000) knlGS:0000000000000000
Jun 14 12:44:14 fedora kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jun 14 12:44:14 fedora kernel: CR2: 000055ad5638b888 CR3: 0000000104b7b001 CR4: 0000000000f72ef0
Jun 14 12:44:14 fedora kernel: PKRU: 55555554
Jun 14 12:44:14 fedora kernel: Call Trace:
Jun 14 12:44:14 fedora kernel:  <TASK>
Jun 14 12:44:14 fedora kernel:  nv_set_system_power_state+0x8a/0x1a0 [nvidia]
Jun 14 12:44:14 fedora kernel:  nv_procfs_write_suspend+0x102/0x1c0 [nvidia]
Jun 14 12:44:14 fedora kernel:  ? security_file_permission+0x50/0xf0
Jun 14 12:44:14 fedora kernel:  proc_reg_write+0x57/0xb0
Jun 14 12:44:14 fedora kernel:  vfs_write+0xf1/0x470
Jun 14 12:44:14 fedora kernel:  ? count_memcg_events.constprop.0+0x1a/0x30
Jun 14 12:44:14 fedora kernel:  ? handle_mm_fault+0x227/0x340
Jun 14 12:44:14 fedora kernel:  ksys_write+0x74/0xf0
Jun 14 12:44:14 fedora kernel:  do_syscall_64+0x7b/0x160
Jun 14 12:44:14 fedora kernel:  ? exc_page_fault+0x7e/0x1a0
Jun 14 12:44:14 fedora kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
Jun 14 12:44:14 fedora kernel: RIP: 0033:0x7f23b94efa06
Jun 14 12:44:14 fedora kernel: Code: 5d e8 41 8b 93 08 03 00 00 59 5e 48 83 f8 fc 75 19 83 e2 39 83 fa 08 75 11 e8 26 ff ff ff 66 0f 1f 44 00 00 48 8b 45 10 0f 05 <48> 8b 5d f8 c9 c3 0f 1f 40 00 f3 0f 1e fa 55 48 89 e5 48 83 ec 08
Jun 14 12:44:14 fedora kernel: RSP: 002b:00007ffd08fa8470 EFLAGS: 00000202 ORIG_RAX: 0000000000000001
Jun 14 12:44:14 fedora kernel: RAX: ffffffffffffffda RBX: 0000000000000008 RCX: 00007f23b94efa06
Jun 14 12:44:14 fedora kernel: RDX: 0000000000000008 RSI: 00005621bebb9e10 RDI: 0000000000000001
Jun 14 12:44:14 fedora kernel: RBP: 00007ffd08fa8490 R08: 0000000000000000 R09: 0000000000000000
Jun 14 12:44:14 fedora kernel: R10: 0000000000000000 R11: 0000000000000202 R12: 0000000000000008
Jun 14 12:44:14 fedora kernel: R13: 00005621bebb9e10 R14: 00007f23b966b5c0 R15: 0000000000000000
Jun 14 12:44:14 fedora kernel:  </TASK>
Jun 14 12:44:14 fedora kernel: ---[ end trace 0000000000000000 ]---
Same issue here as well.
Jun 15 14:38:43 fedora systemd[1]: Reached target sleep.target - Sleep.
Jun 15 14:38:43 fedora systemd[1]: Starting nvidia-suspend.service - NVIDIA system suspend actions...
Jun 15 14:38:43 fedora suspend[8841]: nvidia-suspend.service
Jun 15 14:38:43 fedora logger[8841]: <13>Jun 15 14:38:43 suspend: nvidia-suspend.service
Jun 15 14:38:43 fedora kernel: rfkill: input handler enabled
Jun 15 14:38:43 fedora bluetoothd[1102]: Endpoint unregistered: sender=:1.106 path=/MediaEndpoint/A2DPSource/ldac
Jun 15 14:38:43 fedora bluetoothd[1102]: Endpoint unregistered: sender=:1.106 path=/MediaEndpoint/A2DPSink/aac
Jun 15 14:38:43 fedora bluetoothd[1102]: Endpoint unregistered: sender=:1.106 path=/MediaEndpoint/A2DPSource/aac
Jun 15 14:38:43 fedora bluetoothd[1102]: Endpoint unregistered: sender=:1.106 path=/MediaEndpoint/A2DPSink/opus_g
Jun 15 14:38:43 fedora bluetoothd[1102]: Endpoint unregistered: sender=:1.106 path=/MediaEndpoint/A2DPSource/opus_g
Jun 15 14:38:43 fedora bluetoothd[1102]: Endpoint unregistered: sender=:1.106 path=/MediaEndpoint/A2DPSink/sbc
Jun 15 14:38:43 fedora bluetoothd[1102]: Endpoint unregistered: sender=:1.106 path=/MediaEndpoint/A2DPSource/sbc
Jun 15 14:38:43 fedora bluetoothd[1102]: Endpoint unregistered: sender=:1.106 path=/MediaEndpoint/A2DPSource/faststream
Jun 15 14:38:43 fedora bluetoothd[1102]: Endpoint unregistered: sender=:1.106 path=/MediaEndpoint/A2DPSource/faststream_duplex
Jun 15 14:38:43 fedora bluetoothd[1102]: Endpoint unregistered: sender=:1.106 path=/MediaEndpoint/A2DPSink/opus_05
Jun 15 14:38:43 fedora bluetoothd[1102]: Endpoint unregistered: sender=:1.106 path=/MediaEndpoint/A2DPSource/opus_05
Jun 15 14:38:43 fedora bluetoothd[1102]: Endpoint unregistered: sender=:1.106 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Jun 15 14:38:43 fedora bluetoothd[1102]: Endpoint unregistered: sender=:1.106 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Jun 15 14:38:43 fedora gsd-media-keys[2604]: Unable to get default source
Jun 15 14:38:43 fedora gsd-media-keys[2604]: Unable to get default sink
Jun 15 14:38:43 fedora kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:0:0:0x00000011
Jun 15 14:38:43 fedora kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:2:0:0x00000011
Jun 15 14:38:43 fedora kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:4:0:0x00000011
Jun 15 14:38:43 fedora kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:6:0:0x00000011
Jun 15 14:38:43 fedora kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c77d:0:0:0x00000011
Hi. I am having the same problem here. I am using arch linux.
[anon@bruh ~]$ uname -a
Linux bruh 6.15.2-zen1-1-zen #1 ZEN SMP PREEMPT_DYNAMIC Tue, 10 Jun 2025 21:32:14 +0000 x86_64 GNU/Linux
[anon@bruh ~]$
Here is the journalctl output of my first boot :- Archived mirror link
Here is the journalctl output of my second boot :- Archived mirror link
I have also created an arch linux forum issue regarding this topic but there was no response :- nvidia-modeset: ERROR: GPU:0: Failed to tear down display engine / Newbie Corner / Arch Linux Forums
Here is my full system information :-
[anon@bruh ~]$ inxi -Fxz
System:
  Kernel: 6.15.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
  Desktop: KDE Plasma v: 6.3.5 Distro: Arch Linux
Machine:
  Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A17 FA707XU_FA707XU
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: FA707XU v: 1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: FA707XU.314 date: 04/16/2024
Battery:
  ID-1: BAT1 charge: 71.7 Wh (100.0%) condition: 71.7/90.2 Wh (79.5%)
    volts: 16.8 min: 15.9 model: ASUS A32-K55 status: full
CPU:
  Info: 8-core model: AMD Ryzen 9 7940HS w/ Radeon 780M Graphics bits: 64
    type: MT MCP arch: Zen 4 rev: 1 cache: L1: 512 KiB L2: 8 MiB L3: 16 MiB
  Speed (MHz): avg: 2358 min/max: 403/5263 boost: enabled cores: 1: 2358
    2: 2358 3: 2358 4: 2358 5: 2358 6: 2358 7: 2358 8: 2358 9: 2358 10: 2358
    11: 2358 12: 2358 13: 2358 14: 2358 15: 2358 16: 2358 bogomips: 127759
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Graphics:
  Device-1: NVIDIA AD107M [GeForce RTX 4050 Max-Q / Mobile] vendor: ASUSTeK
    driver: nvidia v: 575.57.08 arch: Lovelace bus-ID: 01:00.0
  Device-2: Advanced Micro Devices [AMD/ATI] Phoenix1 vendor: ASUSTeK
    driver: amdgpu v: kernel arch: RDNA-3 bus-ID: 65:00.0 temp: 40.0 C
  Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    bus-ID: 1-4:2
  Display: wayland server: X.org v: 1.21.1.18 with: Xwayland v: 24.1.8
    compositor: kwin_wayland driver: X: loaded: modesetting,nvidia dri: radeonsi
    gpu: amdgpu resolution: 1920x1080~144Hz
  API: EGL v: 1.5 drivers: kms_swrast,nvidia,radeonsi,swrast platforms:
    active: gbm,wayland,x11,surfaceless,device inactive: device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.1.3-arch1.3
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M Graphics (radeonsi
    phoenix LLVM 20.1.6 DRM 3.63 6.15.2-zen1-1-zen)
  API: Vulkan v: 1.4.313 drivers: nvidia surfaces: N/A devices: 1
    de: kscreen-console,kscreen-doctor gpu: nvidia-settings,nvidia-smi
    wl: wayland-info x11: xdpyinfo, xprop, xrandr
Audio:
  Device-1: NVIDIA AD107 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 01:00.1
  Device-2: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
    [Rembrandt/Strix] driver: snd_hda_intel v: kernel bus-ID: 65:00.1
  Device-3: Advanced Micro Devices [AMD] Audio Coprocessor
    driver: snd_pci_ps v: kernel bus-ID: 65:00.5
  Device-4: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
    vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 65:00.6
  API: ALSA v: k6.15.2-zen1-1-zen status: kernel-api
  Server-1: PipeWire v: 1.4.5 status: active
Network:
  Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
    vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
  IF: enp2s0 state: down mac: <filter>
  Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
    vendor: AzureWave driver: mt7921e v: kernel bus-ID: 03:00.0
  IF: wlp3s0 state: up mac: <filter>
Bluetooth:
  Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
    bus-ID: 1-5:3
  Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
    lmp-v: 11
Drives:
  Local Storage: total: 1.04 TiB used: 133.26 GiB (12.5%)
  ID-1: /dev/nvme0n1 vendor: Micron model: 2400 MTFDKBA1T0QFM
    size: 953.87 GiB temp: 35.9 C
  ID-2: /dev/sda vendor: SanDisk model: USB 3.2Gen1 size: 114.6 GiB
    type: USB
Partition:
  ID-1: / size: 953.32 GiB used: 132.75 GiB (13.9%) fs: btrfs dev: /dev/dm-0
    mapped: root
  ID-2: /boot size: 548.9 MiB used: 238.3 MiB (43.4%) fs: vfat
    dev: /dev/nvme0n1p1
Swap:
  ID-1: swap-1 type: zram size: 4 GiB used: 0 KiB (0.0%) dev: /dev/zram0
Sensors:
  System Temperatures: cpu: 47.5 C mobo: 40.0 C gpu: amdgpu temp: 42.0 C
  Fan Speeds (rpm): cpu: 3000
Info:
  Memory: total: 16 GiB note: est. available: 14.84 GiB used: 4.99 GiB (33.6%)
  Processes: 392 Uptime: 45m Init: systemd
  Packages: 1257 Compilers: clang: 20.1.6 gcc: 15.1.1 Shell: Bash v: 5.2.37
    inxi: 3.3.38
[anon@bruh ~]$
Please patch this issue. This is a very serious one.
Please follow the issue-reporting template as described here.
Yup.
…and then you attach the file to your post.
Oddly enough, I didn’t get notifications about new replies besides the last one 😯
Folks, if by any chance you have access to logs, I’d be happy to delegate writing the comment per @ Tekstryder’s reply to you, because (the hang is obviously sporadic) I didn’t have it happen for the last couple of days to me, and before that I was trying to run nouveau, which turned out to have its own problem.
Most importantly… always attach your nvidia-bug-report.log.gz file whenever you report an issue.
Hi Thanks for replying!! As you have mentioned before in the arch forum, I forgot to upload the nvidia logs. I am sorry because this is my first time issuing a bug report so here is the nvidia-bug-report-log.gz file :-
nvidia-bug-report.log.gz (619.8 KB)
One attachment was provided above, here’s mine as well if you still need it. The last hang happened 6 hours prior to booting the system and posting this, had to hard-power-down the system. This attachment is a bit on the larger side it seems.
nvidia-bug-report.log.gz (1.6 MB)
Hi, could you pls clarify, is it being looked at or should I re-report this again due to file attached in comments and not in the top-post? FTR, I don’t have permissions to edit the top post anymore. But the NVidia laptop lately hangs pretty badly, like it won’t go a day without hanging on suspend.
FWIW, just was in the office, went away for 15 minutes. The laptop wasn’t suspended, was still running, but upon returning it suddenly no longer detects external monitor with
kernel: nvidia-modeset: ERROR: GPU:0: Failed detecting connected display devices
Before that in the log same spam of nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:7:0:0x00000011. So apparently, even suspending isn’t required for NVidia driver to break, it just does kind of on its own.
@Tekstryder ping
We have a bug 5156763 filed internally for tracking purpose and team is currently investigating for the root cause.
Does anybody try with nvidia-drm.modeset=0 and confirm if issue repro’s or not.
Thank you in advance for the help.
Still repro.
Ran for 1.5 day with the param:
λ cat /proc/cmdline
BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=720ec811-e3b9-4936-8aae-2d085e695875 rw loglevel=3 quiet systemd.unidfied_cgroup_hierarchy nowatchdog nvidia-drm.modeset=0
10 minutes ago tried suspending and the laptop froze.
Obsolete by the next comment (click to show)
Interestingly, after rebooting and looking through logs, I found that this time the problem does not start with a stacktrace, instead it starts with hundreds lines spam of
and only afterwards there’s a trace.
NVM, it always was this way.
Btw, looking through older logs, I found at some point it was starting up with this error:
kernel: nvidia-modeset: ERROR: GPU:0: The requested configuration of display devices (AOC 27P2G5 (HDMI-0)) is not supported on this GPU.
hopefully it’ll help.
@amrits looking forward to hearing more about this, i’ve been dealing with the same issue.
Aug 05 16:39:58 fedora systemd[1]: Reached target sleep.target - Sleep.
Aug 05 16:39:58 fedora systemd[1]: Starting nvidia-suspend.service - NVIDIA system suspend actions...
Aug 05 16:39:58 fedora suspend[20213]: nvidia-suspend.service
Aug 05 16:39:58 fedora logger[20213]: <13>Aug  5 16:39:58 suspend: nvidia-suspend.service
Aug 05 16:39:58 fedora kernel: rfkill: input handler enabled
Aug 05 16:39:58 fedora kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:0:0:0x00000011
Aug 05 16:39:58 fedora kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:2:0:0x00000011
Aug 05 16:39:58 fedora kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:4:0:0x00000011
Aug 05 16:39:58 fedora kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:6:0:0x00000011
Aug 05 16:39:58 fedora kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67d:0:0:0x00000011
When i opened my laptop lid, there were just lines of logs on my screen. I changed to a different virtual terminal and it looked like there was a couple of processes for “nvidia-sleep resume” that were stuck. I could not kill the processes. I took a bug report but it never really completed, possibly cause the log lines were constantly filling with nvidia errors.
logs.txt (211.1 KB)
nvidia-bug-report.log.gz (363 Bytes)
@amrits hello, any news? The thread has been open since May and I have to reboot my work laptop every few days because of NVidia driver freeze. I’ve been told NVidia has one of the best drivers, yet somehow it can’t keep running for more than 2-3 days, this is insane.
