I want to report a bug I’ve seen multiple times over the past 2 days on a fresh Manjaro Gnome Linux install using the proprietary NVIDIA drivers.
Here are my system specs:
ankit@desktop-linux:~/crashes$ cat /etc/lsb-release
DISTRIB_ID=ManjaroLinux
DISTRIB_RELEASE=21.1.6
DISTRIB_CODENAME=Pahvo
DISTRIB_DESCRIPTION="Manjaro Linux"
ankit@desktop-linux:~/crashes$ nvidia-smi
Tue Nov 9 22:21:04 2021
| NVIDIA-SMI 470.63.01 Driver Version: 470.63.01 CUDA Version: 11.4 |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:29:00.0 On | N/A |
| 20% 50C P0 42W / 180W | 923MiB / 8085MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 4518 G /usr/lib/Xorg 492MiB |
| 0 N/A N/A 4584 G /usr/bin/gnome-shell 131MiB |
| 0 N/A N/A 5158 G ...1/usr/lib/firefox/firefox 286MiB |
| 0 N/A N/A 8526 G ...1/usr/lib/firefox/firefox 2MiB |
| 0 N/A N/A 8872 G ...1/usr/lib/firefox/firefox 2MiB |
| 0 N/A N/A 9326 G ...1/usr/lib/firefox/firefox 2MiB |
Periodically, seems like once or twice a day, my display completely freezes, and the mouse/keyboard become unresponsive. Pressing Alt+F3 etc. to switch X FBs has no effect.
I was able to SSH into the machine and tried to collect all the info I could, though I am not a graphics driver expert. This was all collected while the display was still hung and I was SSH’ed in:
- Restarting GDM with
systemctl restart gdmhas no effect. The Xorg process was in an uninterruptible sleep and cannot be terminated with `kill -9:
[ankit@desktop-linux crashes]$ ps aux | grep X
root 50905 0.8 0.2 25352196 70668 tty3 D+ 21:02 0:09 /usr/lib/Xorg vt3 -displayfd 3 -auth /run/user/1000/gdm/Xauthority -nolisten tcp -background none -noreset -keeptty -novtswitch -verbose 3
Here is the output of
nvidia-bug-report.sh --safe-mode --extra-system-data. It hung but had partial output: nvidia-bug-report.log.nov9-910pm.gz (593 Bytes) -
Output of `cat /proc/50905/status:
Umask: 0022
State: D (disk sleep)
Tgid: 50905
Ngid: 0
Pid: 50905
PPid: 1
TracerPid: 0
Uid: 1000 0 0 0
Gid: 1000 1000 1000 1000
FDSize: 256
Groups: 90 98 963 984 987 991 994 996 998 1000
NStgid: 50905
NSpid: 50905
NSpgid: 50903
NSsid: 50903
VmPeak: 25354644 kB
VmSize: 25352196 kB
VmLck: 0 kB
VmPin: 0 kB
VmHWM: 74424 kB
VmRSS: 70668 kB
RssAnon: 27312 kB
RssFile: 34548 kB
RssShmem: 8808 kB
VmData: 28384 kB
VmStk: 204 kB
VmExe: 1672 kB
VmLib: 51276 kB
VmPTE: 288 kB
VmSwap: 0 kB
HugetlbPages: 0 kB
CoreDumping: 0
THP_enabled: 1
Threads: 1
SigQ: 9/128161
SigPnd: 0000000000000100
ShdPnd: 0000000000006301
SigBlk: 0000000000000000
SigIgn: 0000000000001000
SigCgt: 00000001c18066ef
CapInh: 0000000000000000
CapPrm: 000001ffffffffff
CapEff: 000001ffffffffff
CapBnd: 000001ffffffffff
CapAmb: 0000000000000000
NoNewPrivs: 0
Seccomp: 0
Seccomp_filters: 0
Speculation_Store_Bypass: thread vulnerable
SpeculationIndirectBranch: conditional enabled
Cpus_allowed: 00000fff
Cpus_allowed_list: 0-11
Mems_allowed: 00000001
Mems_allowed_list: 0
voluntary_ctxt_switches: 478628
nonvoluntary_ctxt_switches: 1178
Here is the Xorg.0.log at around 9:11PM: Xorg.0.nov9_910PM.txt (39.5 KB)
cat /proc/50905/syscallshowing X11 was hung on anioctl:
[ankit@desktop-linux crashes]$ sudo cat /proc/50905/syscall > x11_stack_trace.txt
16 0x13 0xc0106d00 0x7fff5dedda10 0x7fff5dee17e0 0x1 0x1 0x7fff5dedda08 0x7f18ed5ad59b
- Here is the output of
cat /proc/50905/stackshowing the stack trace at a (somewhere in nvidia driver land?):
[ankit@desktop-linux crashes]$ sudo cat /proc/50905/stack > x11_stack_trace.txt
[<0>] down+0x3b/0x50
[<0>] os_acquire_semaphore+0x31/0x40 [nvidia]
[<0>] _nv035255rm+0xc/0x30 [nvidia]
- Here is the
dmesgoutput starting from the first error i saw (showing a segfault in X11 and an error in NVIDIA?):
[ 5173.083790] gnome-shell[47475]: segfault at 0 ip 00007fedd4529f43 sp 00007ffc0ab887e0 error 4 in libX11.so.6.4.0[7fedd4505000+8a000]
[ 5173.083802] Code: 48 89 f5 53 48 89 d3 48 83 ec 58 64 48 8b 04 25 28 00 00 00 48 89 44 24 48 48 8b 87 30 0a 00 00 48 8b 97 f8 00 00 00 83 e2 01 <48> 8b 30 48 89 34 24 0f 85 53 01 00 00 48 8b 97 a8 00 00 00 49 89
[ 5173.083842] audit: type=1701 audit(1636520521.610:1070): auid=1000 uid=1000 gid=1000 ses=4 subj==unconfined pid=47475 comm="gnome-shell" exe="/usr/bin/gnome-shell" sig=11 res=1
[ 5173.117740] audit: type=1334 audit(1636520521.643:1071): prog-id=120 op=LOAD
[ 5173.117854] audit: type=1334 audit(1636520521.643:1072): prog-id=121 op=LOAD
[ 5173.117904] audit: type=1334 audit(1636520521.643:1073): prog-id=122 op=LOAD
[ 5173.119025] audit: type=1130 audit(1636520521.643:1074): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@2-50488-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5173.625374] audit: type=1131 audit(1636520522.150:1075): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5173.823393] audit: type=1334 audit(1636520522.350:1076): prog-id=119 op=UNLOAD
[ 5173.823406] audit: type=1334 audit(1636520522.350:1077): prog-id=118 op=UNLOAD
[ 5173.823410] audit: type=1334 audit(1636520522.350:1078): prog-id=117 op=UNLOAD
[ 5178.517411] kauditd_printk_skb: 28 callbacks suppressed
[ 5178.517413] audit: type=1334 audit(1636520527.043:1101): prog-id=124 op=LOAD
[ 5178.517535] audit: type=1334 audit(1636520527.043:1102): prog-id=125 op=LOAD
[ 5178.517599] audit: type=1334 audit(1636520527.043:1103): prog-id=126 op=LOAD
[ 5178.571499] audit: type=1130 audit(1636520527.096:1104): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5178.621397] audit: type=1130 audit(1636520527.146:1105): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5178.758896] audit: type=1334 audit(1636520527.283:1106): prog-id=127 op=LOAD
[ 5178.758965] audit: type=1334 audit(1636520527.283:1107): prog-id=128 op=LOAD
[ 5178.758991] audit: type=1334 audit(1636520527.283:1108): prog-id=129 op=LOAD
[ 5178.814890] audit: type=1130 audit(1636520527.340:1109): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5178.831390] rfkill: input handler disabled
[ 5179.294558] audit: type=1334 audit(1636520527.820:1110): prog-id=130 op=LOAD
[ 5186.446469] kauditd_printk_skb: 3 callbacks suppressed
[ 5186.446474] audit: type=1100 audit(1636520534.970:1114): pid=50868 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="ankit" exe="/usr/lib/gdm-session-worker" hostname=desktop-linux addr=? terminal=/dev/tty1 res=success'
[ 5186.447861] audit: type=1101 audit(1636520534.973:1115): pid=50868 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="ankit" exe="/usr/lib/gdm-session-worker" hostname=desktop-linux addr=? terminal=/dev/tty1 res=success'
[ 5186.448698] audit: type=1103 audit(1636520534.973:1116): pid=50868 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="ankit" exe="/usr/lib/gdm-session-worker" hostname=desktop-linux addr=? terminal=/dev/tty1 res=success'
[ 5186.451341] audit: type=1006 audit(1636520534.976:1117): pid=50868 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=27 res=1
[ 5186.451347] audit: type=1300 audit(1636520534.976:1117): arch=c000003e syscall=1 success=yes exit=4 a0=a a1=7fff25e30600 a2=4 a3=3e8 items=0 ppid=629 pid=50868 auid=1000 uid=0 gid=1000 euid=0 suid=0 fsuid=0 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=27 comm="gdm-session-wor" exe="/usr/lib/gdm-session-worker" subj==unconfined key=(null)
[ 5186.451350] audit: type=1327 audit(1636520534.976:1117): proctitle=67646D2D73657373696F6E2D776F726B6572205B70616D2F67646D2D70617373776F72645D
[ 5186.503043] audit: type=1105 audit(1636520535.026:1118): pid=50868 uid=0 auid=1000 ses=27 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="ankit" exe="/usr/lib/gdm-session-worker" hostname=desktop-linux addr=? terminal=/dev/tty3 res=success'
[ 5186.973288] rfkill: input handler enabled
[ 5188.908607] rfkill: input handler disabled
[ 5188.957034] audit: type=1701 audit(1636520537.483:1119): auid=1000 uid=1000 gid=1000 ses=4 subj==unconfined pid=51268 comm="touchegg" exe="/usr/bin/touchegg" sig=6 res=1
[ 5189.000572] audit: type=1334 audit(1636520537.526:1120): prog-id=131 op=LOAD
[ 5189.000640] audit: type=1334 audit(1636520537.526:1121): prog-id=132 op=LOAD
[ 5200.434336] kauditd_printk_skb: 8 callbacks suppressed
[ 5200.434340] audit: type=1131 audit(1636520548.960:1130): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5200.501087] audit: type=1131 audit(1636520549.026:1131): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5203.937551] audit: type=1334 audit(1636520552.463:1132): prog-id=134 op=LOAD
[ 5203.937657] audit: type=1334 audit(1636520552.463:1133): prog-id=135 op=LOAD
[ 5203.937713] audit: type=1334 audit(1636520552.463:1134): prog-id=136 op=LOAD
[ 5203.993682] audit: type=1130 audit(1636520552.520:1135): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5210.005228] audit: type=1131 audit(1636520558.530:1136): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5210.226874] audit: type=1334 audit(1636520558.753:1137): prog-id=130 op=UNLOAD
[ 5218.978492] audit: type=1131 audit(1636520567.503:1138): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5219.200218] audit: type=1334 audit(1636520567.726:1139): prog-id=126 op=UNLOAD
[ 5219.200223] audit: type=1334 audit(1636520567.726:1140): prog-id=125 op=UNLOAD
[ 5219.200225] audit: type=1334 audit(1636520567.726:1141): prog-id=124 op=UNLOAD
[ 5231.951388] audit: type=1326 audit(1636520580.476:1142): auid=1000 uid=1000 gid=1000 ses=4 subj==snap.firefox.firefox (enforce) pid=52553 comm="GeckoMain" exe="/snap/firefox/701/usr/lib/firefox/firefox" sig=0 arch=c000003e syscall=314 compat=0 ip=0x7f556cdeb89d code=0x50000
[ 5234.028508] audit: type=1131 audit(1636520582.553:1143): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5234.088732] audit: type=1334 audit(1636520582.613:1144): prog-id=136 op=UNLOAD
[ 5234.088738] audit: type=1334 audit(1636520582.613:1145): prog-id=135 op=UNLOAD
[ 5234.088741] audit: type=1334 audit(1636520582.613:1146): prog-id=134 op=UNLOAD
[ 5235.045422] audit: type=1131 audit(1636520583.570:1147): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5235.200066] audit: type=1334 audit(1636520583.726:1148): prog-id=129 op=UNLOAD
[ 5235.200076] audit: type=1334 audit(1636520583.726:1149): prog-id=128 op=UNLOAD
[ 5235.200082] audit: type=1334 audit(1636520583.726:1150): prog-id=127 op=UNLOAD
[ 5238.982866] audit: type=1131 audit(1636520587.506:1151): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5281.024185] audit: type=1400 audit(1636520629.550:1152): apparmor="DENIED" operation="open" profile="snap.firefox.firefox" name="/proc/54033/environ" pid=52553 comm=427265616B70616420536572766572 requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[ 5281.024195] audit: type=1300 audit(1636520629.550:1152): arch=c000003e syscall=257 success=no exit=-13 a0=ffffff9c a1=7f551f35a7a0 a2=80000 a3=0 items=0 ppid=50971 pid=52553 auid=1000 uid=1000 gid=1000 euid=1000 suid=1000 fsuid=1000 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=4 comm=427265616B70616420536572766572 exe="/snap/firefox/701/usr/lib/firefox/firefox" subj==snap.firefox.firefox (enforce) key=(null)
[ 5281.024199] audit: type=1327 audit(1636520629.550:1152): proctitle="/snap/firefox/701/usr/lib/firefox/firefox"
[ 5281.027500] MediaSu~isor #2[54033]: segfault at 0 ip 00007f5fca679268 sp 00007f5fc1f5a5f0 error 4 in libxul.so[7f5fc9f7a000+53d9000]
[ 5281.027515] Code: 00 00 55 41 57 41 56 41 55 41 54 53 48 83 ec 18 89 d1 41 89 f7 49 89 fc 64 48 8b 04 25 28 00 00 00 48 89 44 24 10 48 8b 47 48 <8b> 30 8d 7e 03 83 e7 fc 41 8b 44 24 50 01 f8 31 d2 f7 f1 41 83 c7
[ 5281.027547] audit: type=1701 audit(1636520629.553:1153): auid=1000 uid=1000 gid=1000 ses=4 subj==snap.firefox.firefox (enforce) pid=53704 comm=4D6564696153757E69736F72202332 exe="/snap/firefox/701/usr/lib/firefox/firefox" sig=11 res=1
[ 5281.080798] audit: type=1334 audit(1636520629.606:1154): prog-id=137 op=LOAD
[ 5281.080940] audit: type=1334 audit(1636520629.606:1155): prog-id=138 op=LOAD
[ 5281.081013] audit: type=1334 audit(1636520629.606:1156): prog-id=139 op=LOAD
[ 5281.082061] audit: type=1130 audit(1636520629.606:1157): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@4-54218-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5281.740699] audit: type=1131 audit(1636520630.266:1158): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@4-54218-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5395.508240] kauditd_printk_skb: 3 callbacks suppressed
[ 5395.508243] audit: type=1101 audit(1636520744.033:1162): pid=54948 uid=0 auid=4294967295 ses=4294967295 subj==docker-default (enforce) msg='op=PAM:accounting grantors=pam_permit acct="ankit" exe="/usr/sbin/sshd" hostname=172.18.0.1 addr=172.18.0.1 terminal=ssh res=success'
[ 5395.509154] audit: type=1103 audit(1636520744.033:1163): pid=54948 uid=0 auid=4294967295 ses=4294967295 subj==docker-default (enforce) msg='op=PAM:setcred grantors=pam_permit,pam_cap acct="ankit" exe="/usr/sbin/sshd" hostname=172.18.0.1 addr=172.18.0.1 terminal=ssh res=success'
[ 5395.509203] audit: type=1006 audit(1636520744.033:1164): pid=54948 uid=0 subj==docker-default (enforce) old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=28 res=1
[ 5395.509206] audit: type=1300 audit(1636520744.033:1164): arch=c000003e syscall=1 success=yes exit=4 a0=3 a1=7ffddd5bd130 a2=4 a3=7f2d19e1e371 items=0 ppid=39525 pid=54948 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=28 comm="sshd" exe="/usr/sbin/sshd" subj==docker-default (enforce) key=(null)
[ 5395.509214] audit: type=1327 audit(1636520744.033:1164): proctitle=737368643A20616E6B6974205B707269765D
[ 5395.513649] audit: type=1105 audit(1636520744.040:1165): pid=54948 uid=0 auid=1000 ses=28 subj==docker-default (enforce) msg='op=PAM:session_open grantors=pam_selinux,pam_loginuid,pam_permit,pam_umask,pam_unix,pam_mail,pam_limits,pam_env,pam_env,pam_selinux acct="ankit" exe="/usr/sbin/sshd" hostname=172.18.0.1 addr=172.18.0.1 terminal=ssh res=success'
[ 5395.514505] audit: type=1103 audit(1636520744.040:1166): pid=54964 uid=0 auid=1000 ses=28 subj==docker-default (enforce) msg='op=PAM:setcred grantors=pam_permit,pam_cap acct="ankit" exe="/usr/sbin/sshd" hostname=172.18.0.1 addr=172.18.0.1 terminal=ssh res=success'
[ 5545.334128] audit: type=1334 audit(1636520893.860:1167): prog-id=140 op=LOAD
[ 5545.334264] audit: type=1334 audit(1636520893.860:1168): prog-id=141 op=LOAD
[ 5545.334321] audit: type=1334 audit(1636520893.860:1169): prog-id=142 op=LOAD
[ 5545.388622] audit: type=1130 audit(1636520893.913:1170): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5566.987738] BUG: kernel NULL pointer dereference, address: 00000000000001e9
[ 5566.987744] #PF: supervisor read access in kernel mode
[ 5566.987745] #PF: error_code(0x0000) - not-present page
[ 5566.987747] PGD 0 P4D 0
[ 5566.987749] Oops: 0000 [#1] PREEMPT SMP NOPTI
[ 5566.987751] CPU: 1 PID: 50601 Comm: irq/114-nvidia Tainted: P OE 5.13.19-2-MANJARO #1
[ 5566.987753] Hardware name: Micro-Star International Co., Ltd. MS-7B87/B450M GAMING PLUS (MS-7B87), BIOS 1.C4 06/10/2020
[ 5566.987754] RIP: 0010:_nv034124rm+0x34/0x1d0 [nvidia]
[ 5566.988067] Code: 89 f5 41 54 53 48 83 ed 10 48 8b b7 10 23 00 00 48 89 fb 89 4d 0c 45 89 c4 e8 e8 b4 e1 ff 4d 85 ed 49 89 c6 0f 84 ec 00 00 00 <41> f7 85 e8 01 00 00 fd ff ff ff 0f 85 0b 01 00 00 49 8b 75 68 48
[ 5566.988068] RSP: 0018:ffff9e82ceff7d18 EFLAGS: 00010202
[ 5566.988070] RAX: ffff90a714a7f008 RBX: ffff90a5ebe5c008 RCX: 0000000000000001
[ 5566.988071] RDX: 0000000000400100 RSI: ffff90a714a7f008 RDI: ffff90a5ebe5c008
[ 5566.988072] RBP: ffff90a5c4b4ab80 R08: 0000000000000020 R09: 0000000000000000
[ 5566.988073] R10: ffffffffc110c850 R11: ffff90a5c4b4aa08 R12: 0000000000000020
[ 5566.988074] R13: 0000000000000001 R14: ffff90a714a7f008 R15: 0000000000400100
[ 5566.988075] FS: 0000000000000000(0000) GS:ffff90acbea40000(0000) knlGS:0000000000000000
[ 5566.988077] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 5566.988078] CR2: 00000000000001e9 CR3: 000000014e0b2000 CR4: 0000000000350ee0
[ 5566.988079] Call Trace:
[ 5566.988082] ? _nv009834rm+0xdb/0x1a0 [nvidia]
[ 5566.988406] ? _nv009822rm+0x176/0x370 [nvidia]
[ 5566.988725] ? _nv024541rm+0xb3d/0x12b0 [nvidia]
[ 5566.989048] ? _nv029374rm+0x138/0xd90 [nvidia]
[ 5566.989371] ? _nv029382rm+0x161/0x440 [nvidia]
[ 5566.989684] ? _nv000725rm+0xb1/0x250 [nvidia]
[ 5566.989906] ? disable_irq_nosync+0x10/0x10
[ 5566.989910] ? rm_isr_bh+0x1c/0x60 [nvidia]
[ 5566.990128] ? nvidia_isr_kthread_bh+0x1b/0x40 [nvidia]
[ 5566.990314] ? irq_thread_fn+0x20/0x60
[ 5566.990316] ? irq_thread+0xf2/0x1a0
[ 5566.990317] ? irq_finalize_oneshot.part.0+0xe0/0xe0
[ 5566.990319] ? irq_thread_check_affinity+0xd0/0xd0
[ 5566.990321] ? kthread+0x133/0x160
[ 5566.990323] ? set_kthread_struct+0x40/0x40
[ 5566.990324] ? ret_from_fork+0x22/0x30
[ 5566.990327] Modules linked in: veth xt_nat xt_tcpudp xt_conntrack xt_MASQUERADE nf_conntrack_netlink nfnetlink xt_addrtype iptable_filter iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c br_netfilter bridge stp llc overlay rfcomm cmac algif_hash algif_skcipher af_alg mousedev joydev uvcvideo videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 snd_usb_audio videobuf2_common mt76x2u mt76x2_common videodev mt76x02_usb mt76_usb snd_usbmidi_lib mt76x02_lib snd_rawmidi snd_seq_device mc mt76 usbhid bnep btusb btrtl btbcm btintel bluetooth uas usb_storage ecdh_generic ecc qrtr ns iwlmvm mac80211 squashfs nvidia_drm(POE) snd_hda_codec_realtek nvidia_modeset(POE) intel_rapl_msr snd_hda_codec_generic intel_rapl_common ledtrig_audio snd_hda_codec_hdmi libarc4 snd_hda_intel edac_mce_amd snd_intel_dspcfg snd_intel_sdw_acpi snd_hda_codec kvm_amd ccp snd_hda_core iwlwifi rng_core wmi_bmof snd_hwdep kvm vfat nvidia(POE) cfg80211 fat drm_kms_helper irqbypass crct10dif_pclmul
[ 5566.990366] crc32_pclmul ghash_clmulni_intel snd_pcm aesni_intel r8169 snd_timer cec crypto_simd snd realtek syscopyarea cryptd sysfillrect sysimgblt mdio_devres sp5100_tco rapl pcspkr zenpower(OE) libphy i2c_piix4 rfkill soundcore fb_sys_fops ryzen_smu(OE) wmi gpio_amdpt pinctrl_amd gpio_generic mac_hid acpi_cpufreq loop drm agpgart fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 crc32c_intel xhci_pci
[ 5566.990388] CR2: 00000000000001e9
[ 5566.990389] ---[ end trace 7bef7c91870e73dd ]---
[ 5566.990390] RIP: 0010:_nv034124rm+0x34/0x1d0 [nvidia]
[ 5566.990683] Code: 89 f5 41 54 53 48 83 ed 10 48 8b b7 10 23 00 00 48 89 fb 89 4d 0c 45 89 c4 e8 e8 b4 e1 ff 4d 85 ed 49 89 c6 0f 84 ec 00 00 00 <41> f7 85 e8 01 00 00 fd ff ff ff 0f 85 0b 01 00 00 49 8b 75 68 48
[ 5566.990685] RSP: 0018:ffff9e82ceff7d18 EFLAGS: 00010202
[ 5566.990686] RAX: ffff90a714a7f008 RBX: ffff90a5ebe5c008 RCX: 0000000000000001
[ 5566.990687] RDX: 0000000000400100 RSI: ffff90a714a7f008 RDI: ffff90a5ebe5c008
[ 5566.990688] RBP: ffff90a5c4b4ab80 R08: 0000000000000020 R09: 0000000000000000
[ 5566.990689] R10: ffffffffc110c850 R11: ffff90a5c4b4aa08 R12: 0000000000000020
[ 5566.990689] R13: 0000000000000001 R14: ffff90a714a7f008 R15: 0000000000400100
[ 5566.990690] FS: 0000000000000000(0000) GS:ffff90acbea40000(0000) knlGS:0000000000000000
[ 5566.990692] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 5566.990693] CR2: 00000000000001e9 CR3: 000000014e0b2000 CR4: 0000000000350ee0
[ 5566.990706] BUG: unable to handle page fault for address: 00000000a0d08190
[ 5566.990707] #PF: supervisor instruction fetch in kernel mode
[ 5566.990708] #PF: error_code(0x0010) - not-present page
[ 5566.990709] PGD 0 P4D 0
[ 5566.990710] Oops: 0010 [#2] PREEMPT SMP NOPTI
[ 5566.990712] CPU: 1 PID: 50601 Comm: irq/114-nvidia Tainted: P D OE 5.13.19-2-MANJARO #1
[ 5566.990713] Hardware name: Micro-Star International Co., Ltd. MS-7B87/B450M GAMING PLUS (MS-7B87), BIOS 1.C4 06/10/2020
[ 5566.990714] RIP: 0010:0xa0d08190
[ 5566.990715] Code: Unable to access opcode bytes at RIP 0xa0d08166.
[ 5566.990716] RSP: 0018:ffff9e82ceff7ea8 EFLAGS: 00010286
[ 5566.990717] RAX: 00000000a0d08190 RBX: 0000000000000000 RCX: 0000000000000000
[ 5566.990718] RDX: 0000000000000001 RSI: 0000000000000000 RDI: ffff9e82ceff7ed0
[ 5566.990719] RBP: ffff90a704a49f40 R08: 0000000000000001 R09: 0000000000000000
[ 5566.990720] R10: 0000000000000001 R11: ffff90acdf326c00 R12: ffff90a704a4a7b4
[ 5566.990721] R13: ffff9e82ceff7c68 R14: ffff90a704a49f40 R15: 0000000000000000
[ 5566.990721] FS: 0000000000000000(0000) GS:ffff90acbea40000(0000) knlGS:0000000000000000
[ 5566.990723] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 5566.990723] CR2: 00000000a0d08190 CR3: 000000014e0b2000 CR4: 0000000000350ee0
[ 5566.990724] Call Trace:
[ 5566.990725] ? task_work_run+0x5c/0x90
[ 5566.990728] ? do_exit+0x375/0xae0
[ 5566.990730] ? irq_thread_check_affinity+0xd0/0xd0
[ 5566.990732] ? rewind_stack_do_exit+0x17/0x17
[ 5566.990735] Modules linked in: veth xt_nat xt_tcpudp xt_conntrack xt_MASQUERADE nf_conntrack_netlink nfnetlink xt_addrtype iptable_filter iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c br_netfilter bridge stp llc overlay rfcomm cmac algif_hash algif_skcipher af_alg mousedev joydev uvcvideo videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 snd_usb_audio videobuf2_common mt76x2u mt76x2_common videodev mt76x02_usb mt76_usb snd_usbmidi_lib mt76x02_lib snd_rawmidi snd_seq_device mc mt76 usbhid bnep btusb btrtl btbcm btintel bluetooth uas usb_storage ecdh_generic ecc qrtr ns iwlmvm mac80211 squashfs nvidia_drm(POE) snd_hda_codec_realtek nvidia_modeset(POE) intel_rapl_msr snd_hda_codec_generic intel_rapl_common ledtrig_audio snd_hda_codec_hdmi libarc4 snd_hda_intel edac_mce_amd snd_intel_dspcfg snd_intel_sdw_acpi snd_hda_codec kvm_amd ccp snd_hda_core iwlwifi rng_core wmi_bmof snd_hwdep kvm vfat nvidia(POE) cfg80211 fat drm_kms_helper irqbypass crct10dif_pclmul
[ 5566.990758] crc32_pclmul ghash_clmulni_intel snd_pcm aesni_intel r8169 snd_timer cec crypto_simd snd realtek syscopyarea cryptd sysfillrect sysimgblt mdio_devres sp5100_tco rapl pcspkr zenpower(OE) libphy i2c_piix4 rfkill soundcore fb_sys_fops ryzen_smu(OE) wmi gpio_amdpt pinctrl_amd gpio_generic mac_hid acpi_cpufreq loop drm agpgart fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 crc32c_intel xhci_pci
[ 5566.990772] CR2: 00000000a0d08190
[ 5566.990772] ---[ end trace 7bef7c91870e73de ]---
[ 5566.990773] RIP: 0010:_nv034124rm+0x34/0x1d0 [nvidia]
[ 5566.991067] Code: 89 f5 41 54 53 48 83 ed 10 48 8b b7 10 23 00 00 48 89 fb 89 4d 0c 45 89 c4 e8 e8 b4 e1 ff 4d 85 ed 49 89 c6 0f 84 ec 00 00 00 <41> f7 85 e8 01 00 00 fd ff ff ff 0f 85 0b 01 00 00 49 8b 75 68 48
[ 5566.991069] RSP: 0018:ffff9e82ceff7d18 EFLAGS: 00010202
[ 5566.991070] RAX: ffff90a714a7f008 RBX: ffff90a5ebe5c008 RCX: 0000000000000001
[ 5566.991071] RDX: 0000000000400100 RSI: ffff90a714a7f008 RDI: ffff90a5ebe5c008
[ 5566.991072] RBP: ffff90a5c4b4ab80 R08: 0000000000000020 R09: 0000000000000000
[ 5566.991072] R10: ffffffffc110c850 R11: ffff90a5c4b4aa08 R12: 0000000000000020
[ 5566.991073] R13: 0000000000000001 R14: ffff90a714a7f008 R15: 0000000000400100
[ 5566.991074] FS: 0000000000000000(0000) GS:ffff90acbea40000(0000) knlGS:0000000000000000
[ 5566.991075] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 5566.991076] CR2: 00000000a0d08190 CR3: 000000014e0b2000 CR4: 0000000000350ee0
[ 5566.991077] Fixing recursive fault but reboot is needed!
[ 5575.438581] audit: type=1131 audit(1636520923.963:1171): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5575.649936] audit: type=1334 audit(1636520924.176:1172): prog-id=142 op=UNLOAD
[ 5575.649944] audit: type=1334 audit(1636520924.176:1173): prog-id=141 op=UNLOAD
[ 5575.649947] audit: type=1334 audit(1636520924.176:1174): prog-id=140 op=UNLOAD
[ 5612.582161] audit: type=1101 audit(1636520961.106:1175): pid=57671 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="ankit" exe="/usr/bin/sshd" hostname=192.168.1.52 addr=192.168.1.52 terminal=ssh res=success'
[ 5612.583231] audit: type=1103 audit(1636520961.106:1176): pid=57671 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_env,pam_faillock acct="ankit" exe="/usr/bin/sshd" hostname=192.168.1.52 addr=192.168.1.52 terminal=ssh res=success'
[ 5612.583311] audit: type=1006 audit(1636520961.110:1177): pid=57671 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=29 res=1
[ 5612.583323] audit: type=1300 audit(1636520961.110:1177): arch=c000003e syscall=1 success=yes exit=4 a0=3 a1=7fffebea20c0 a2=4 a3=3e8 items=0 ppid=619 pid=57671 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=29 comm="sshd" exe="/usr/bin/sshd" subj==unconfined key=(null)
[ 5612.583327] audit: type=1327 audit(1636520961.110:1177): proctitle=737368643A20616E6B6974205B707269765D
[ 5612.630425] audit: type=1105 audit(1636520961.156:1178): pid=57671 uid=0 auid=1000 ses=29 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="ankit" exe="/usr/bin/sshd" hostname=192.168.1.52 addr=192.168.1.52 terminal=ssh res=success'
[ 5612.631442] audit: type=1103 audit(1636520961.156:1179): pid=57697 uid=0 auid=1000 ses=29 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_env,pam_faillock acct="ankit" exe="/usr/bin/sshd" hostname=192.168.1.52 addr=192.168.1.52 terminal=ssh res=success'
[ 5687.279639] audit: type=1100 audit(1636521035.803:1180): pid=58142 uid=1000 auid=1000 ses=29 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="ankit" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 5687.280646] audit: type=1101 audit(1636521035.806:1181): pid=58142 uid=1000 auid=1000 ses=29 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="ankit" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 5687.280783] audit: type=1110 audit(1636521035.806:1182): pid=58142 uid=1000 auid=1000 ses=29 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 5687.282219] audit: type=1105 audit(1636521035.806:1183): pid=58142 uid=1000 auid=1000 ses=29 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Even after resetting my system, I got to a blank login screen on Manjaro. Nothing loads after that. Only powering off the system works.
Here is the output from
nvidia-bug-report.sh --safe-mode --extra-system-dataafter reset - it still hangs so its partial output: nvidia-bug-report.log.gz.nov9-950pm.post_reset (88.7 KB) -
Here is partial
dmesgoutput after the reset showing more errors:
[ 134.164852] audit: type=1103 audit(1636523617.417:1326): pid=8349 uid=0 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_env,pam_faillock acct="ankit" exe="/usr/bin/sshd" hostname=192.168.1.52 addr=192.168.1.52 terminal=ssh res=success'
[ 245.360007] INFO: task systemd-udevd:369 blocked for more than 122 seconds.
[ 245.360013] Tainted: P OE 5.13.19-2-MANJARO #1
[ 245.360015] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 245.360016] task:systemd-udevd state:D stack: 0 pid: 369 ppid: 353 flags:0x00004224
[ 245.360021] Call Trace:
[ 245.360026] __schedule+0x310/0x930
[ 245.360033] schedule+0x5b/0xc0
[ 245.360036] schedule_timeout+0x11c/0x160
[ 245.360040] wait_for_completion+0xa3/0x100
[ 245.360044] __flush_work.isra.0+0x15b/0x210
[ 245.360048] ? flush_workqueue_prep_pwqs+0x130/0x130
[ 245.360051] __cancel_work_timer+0x12e/0x1c0
[ 245.360056] mt76u_stop_tx+0xb1/0x1d0 [mt76_usb]
[ 245.360063] mt76u_queues_deinit+0x23/0x1f0 [mt76_usb]
[ 245.360067] mt76x2u_probe+0x7b/0x130 [mt76x2u]
[ 245.360073] usb_probe_interface+0xe2/0x2a0
[ 245.360077] really_probe+0x384/0x4a0
[ 245.360082] driver_probe_device+0xe8/0x160
[ 245.360086] device_driver_attach+0xa1/0xb0
[ 245.360090] __driver_attach+0x8f/0x150
[ 245.360093] ? device_driver_attach+0xb0/0xb0
[ 245.360096] ? device_driver_attach+0xb0/0xb0
[ 245.360099] bus_for_each_dev+0x89/0xd0
[ 245.360102] bus_add_driver+0x12b/0x1e0
[ 245.360106] driver_register+0x8f/0xe0
[ 245.360108] usb_register_driver+0x84/0x120
[ 245.360111] ? 0xffffffffc04d4000
[ 245.360113] do_one_initcall+0x57/0x220
[ 245.360118] do_init_module+0x5c/0x270
[ 245.360121] load_module+0x2545/0x2740
[ 245.360127] ? __do_sys_init_module+0x12e/0x1b0
[ 245.360129] __do_sys_init_module+0x12e/0x1b0
[ 245.360133] do_syscall_64+0x40/0x80
[ 245.360136] entry_SYSCALL_64_after_hwframe+0x44/0xae
[ 245.360140] RIP: 0033:0x7f3c88b5132e
[ 245.360142] RSP: 002b:00007fff1272a468 EFLAGS: 00000246 ORIG_RAX: 00000000000000af
[ 245.360145] RAX: ffffffffffffffda RBX: 000055afa9014950 RCX: 00007f3c88b5132e
[ 245.360147] RDX: 00007f3c88cc3a9d RSI: 0000000000015f19 RDI: 000055afa92b5c20
[ 245.360149] RBP: 000055afa92b5c20 R08: 000055afa9011230 R09: 00007fff1272a229
[ 245.360150] R10: 000055aaf3fbe371 R11: 0000000000000246 R12: 00007f3c88cc3a9d
[ 245.360151] R13: 0000000000000001 R14: 000055afa90138a0 R15: 000055afa9014950
[ 298.367097] audit: type=1106 audit(1636523781.621:1327): pid=7824 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 298.367141] audit: type=1104 audit(1636523781.621:1328): pid=7824 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 368.239989] INFO: task systemd-udevd:369 blocked for more than 245 seconds.
[ 368.239995] Tainted: P OE 5.13.19-2-MANJARO #1
[ 368.239997] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 368.239998] task:systemd-udevd state:D stack: 0 pid: 369 ppid: 353 flags:0x00004224
[ 368.240003] Call Trace:
[ 368.240007] __schedule+0x310/0x930
[ 368.240015] schedule+0x5b/0xc0
[ 368.240018] schedule_timeout+0x11c/0x160
[ 368.240022] wait_for_completion+0xa3/0x100
[ 368.240026] __flush_work.isra.0+0x15b/0x210
[ 368.240030] ? flush_workqueue_prep_pwqs+0x130/0x130
[ 368.240033] __cancel_work_timer+0x12e/0x1c0
[ 368.240037] mt76u_stop_tx+0xb1/0x1d0 [mt76_usb]
[ 368.240044] mt76u_queues_deinit+0x23/0x1f0 [mt76_usb]
[ 368.240050] mt76x2u_probe+0x7b/0x130 [mt76x2u]
[ 368.240055] usb_probe_interface+0xe2/0x2a0
[ 368.240060] really_probe+0x384/0x4a0
[ 368.240065] driver_probe_device+0xe8/0x160
[ 368.240068] device_driver_attach+0xa1/0xb0
[ 368.240072] __driver_attach+0x8f/0x150
[ 368.240076] ? device_driver_attach+0xb0/0xb0
[ 368.240079] ? device_driver_attach+0xb0/0xb0
[ 368.240082] bus_for_each_dev+0x89/0xd0
[ 368.240085] bus_add_driver+0x12b/0x1e0
[ 368.240089] driver_register+0x8f/0xe0
[ 368.240091] usb_register_driver+0x84/0x120
[ 368.240094] ? 0xffffffffc04d4000
[ 368.240096] do_one_initcall+0x57/0x220
[ 368.240101] do_init_module+0x5c/0x270
[ 368.240104] load_module+0x2545/0x2740
[ 368.240110] ? __do_sys_init_module+0x12e/0x1b0
[ 368.240112] __do_sys_init_module+0x12e/0x1b0
[ 368.240116] do_syscall_64+0x40/0x80
[ 368.240119] entry_SYSCALL_64_after_hwframe+0x44/0xae
[ 368.240122] RIP: 0033:0x7f3c88b5132e
[ 368.240124] RSP: 002b:00007fff1272a468 EFLAGS: 00000246 ORIG_RAX: 00000000000000af
[ 368.240128] RAX: ffffffffffffffda RBX: 000055afa9014950 RCX: 00007f3c88b5132e
[ 368.240130] RDX: 00007f3c88cc3a9d RSI: 0000000000015f19 RDI: 000055afa92b5c20
[ 368.240131] RBP: 000055afa92b5c20 R08: 000055afa9011230 R09: 00007fff1272a229
[ 368.240132] R10: 000055aaf3fbe371 R11: 0000000000000246 R12: 00007f3c88cc3a9d
[ 368.240134] R13: 0000000000000001 R14: 000055afa90138a0 R15: 000055afa9014950
[ 368.592568] audit: type=1100 audit(1636523851.844:1329): pid=8380 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="ankit" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 368.593540] audit: type=1101 audit(1636523851.847:1330): pid=8380 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="ankit" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 368.593632] audit: type=1110 audit(1636523851.847:1331): pid=8380 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 368.595955] audit: type=1105 audit(1636523851.847:1332): pid=8380 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 373.867681] audit: type=1334 audit(1636523857.121:1333): prog-id=28 op=LOAD
[ 384.241501] audit: type=1106 audit(1636523867.494:1334): pid=8380 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 384.241550] audit: type=1104 audit(1636523867.494:1335): pid=8380 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 394.531336] audit: type=1101 audit(1636523877.784:1336): pid=8391 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="ankit" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 394.531448] audit: type=1110 audit(1636523877.784:1337): pid=8391 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 394.533474] audit: type=1105 audit(1636523877.787:1338): pid=8391 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 433.145844] audit: type=1106 audit(1636523916.397:1339): pid=8391 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 433.145859] audit: type=1104 audit(1636523916.397:1340): pid=8391 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 463.892642] audit: type=1130 audit(1636523947.144:1341): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 464.089796] audit: type=1334 audit(1636523947.341:1342): prog-id=28 op=UNLOAD
[ 472.297326] audit: type=1101 audit(1636523955.551:1343): pid=8409 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="ankit" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 472.297476] audit: type=1110 audit(1636523955.551:1344): pid=8409 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 472.299583] audit: type=1105 audit(1636523955.551:1345): pid=8409 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 472.300933] audit: type=1106 audit(1636523955.554:1346): pid=8409 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 472.300974] audit: type=1104 audit(1636523955.554:1347): pid=8409 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 491.119987] INFO: task systemd-udevd:369 blocked for more than 368 seconds.
[ 491.119992] Tainted: P OE 5.13.19-2-MANJARO #1
[ 491.119994] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 491.119996] task:systemd-udevd state:D stack: 0 pid: 369 ppid: 353 flags:0x00004224
[ 491.120001] Call Trace:
[ 491.120005] __schedule+0x310/0x930
[ 491.120013] schedule+0x5b/0xc0
[ 491.120016] schedule_timeout+0x11c/0x160
[ 491.120020] wait_for_completion+0xa3/0x100
[ 491.120024] __flush_work.isra.0+0x15b/0x210
[ 491.120028] ? flush_workqueue_prep_pwqs+0x130/0x130
[ 491.120030] __cancel_work_timer+0x12e/0x1c0
[ 491.120035] mt76u_stop_tx+0xb1/0x1d0 [mt76_usb]
[ 491.120042] mt76u_queues_deinit+0x23/0x1f0 [mt76_usb]
[ 491.120047] mt76x2u_probe+0x7b/0x130 [mt76x2u]
[ 491.120053] usb_probe_interface+0xe2/0x2a0
[ 491.120057] really_probe+0x384/0x4a0
[ 491.120062] driver_probe_device+0xe8/0x160
[ 491.120065] device_driver_attach+0xa1/0xb0
[ 491.120069] __driver_attach+0x8f/0x150
[ 491.120072] ? device_driver_attach+0xb0/0xb0
[ 491.120075] ? device_driver_attach+0xb0/0xb0
[ 491.120078] bus_for_each_dev+0x89/0xd0
[ 491.120081] bus_add_driver+0x12b/0x1e0
[ 491.120084] driver_register+0x8f/0xe0
[ 491.120086] usb_register_driver+0x84/0x120
[ 491.120090] ? 0xffffffffc04d4000
[ 491.120092] do_one_initcall+0x57/0x220
[ 491.120097] do_init_module+0x5c/0x270
[ 491.120100] load_module+0x2545/0x2740
[ 491.120106] ? __do_sys_init_module+0x12e/0x1b0
[ 491.120108] __do_sys_init_module+0x12e/0x1b0
[ 491.120112] do_syscall_64+0x40/0x80
[ 491.120116] entry_SYSCALL_64_after_hwframe+0x44/0xae
[ 491.120119] RIP: 0033:0x7f3c88b5132e
[ 491.120121] RSP: 002b:00007fff1272a468 EFLAGS: 00000246 ORIG_RAX: 00000000000000af
[ 491.120124] RAX: ffffffffffffffda RBX: 000055afa9014950 RCX: 00007f3c88b5132e
[ 491.120126] RDX: 00007f3c88cc3a9d RSI: 0000000000015f19 RDI: 000055afa92b5c20
[ 491.120127] RBP: 000055afa92b5c20 R08: 000055afa9011230 R09: 00007fff1272a229
[ 491.120128] R10: 000055aaf3fbe371 R11: 0000000000000246 R12: 00007f3c88cc3a9d
[ 491.120130] R13: 0000000000000001 R14: 000055afa90138a0 R15: 000055afa9014950
[ 542.246448] audit: type=1101 audit(1636524025.497:1348): pid=8417 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="ankit" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 542.246549] audit: type=1110 audit(1636524025.497:1349): pid=8417 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 542.248643] audit: type=1105 audit(1636524025.501:1350): pid=8417 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 546.131275] audit: type=1106 audit(1636524029.384:1351): pid=8417 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 546.131304] audit: type=1104 audit(1636524029.384:1352): pid=8417 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 553.691218] audit: type=1101 audit(1636524036.944:1353): pid=8421 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="ankit" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 553.691310] audit: type=1110 audit(1636524036.944:1354): pid=8421 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 553.692842] audit: type=1105 audit(1636524036.944:1355): pid=8421 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 556.476797] audit: type=1106 audit(1636524039.731:1356): pid=8421 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 556.476846] audit: type=1104 audit(1636524039.731:1357): pid=8421 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 571.142922] audit: type=1101 audit(1636524054.394:1358): pid=8428 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="ankit" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 571.142996] audit: type=1110 audit(1636524054.394:1359): pid=8428 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 571.144626] audit: type=1105 audit(1636524054.397:1360): pid=8428 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 571.146919] audit: type=1106 audit(1636524054.401:1361): pid=8428 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 571.146939] audit: type=1104 audit(1636524054.401:1362): pid=8428 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 600.951777] audit: type=1101 audit(1636524084.204:1363): pid=8436 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="ankit" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 600.951861] audit: type=1110 audit(1636524084.204:1364): pid=8436 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 600.953326] audit: type=1105 audit(1636524084.207:1365): pid=8436 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 606.902098] audit: type=1106 audit(1636524090.154:1366): pid=8436 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 606.902139] audit: type=1104 audit(1636524090.154:1367): pid=8436 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 613.999977] INFO: task systemd-udevd:369 blocked for more than 491 seconds.
[ 613.999983] Tainted: P OE 5.13.19-2-MANJARO #1
[ 613.999985] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 613.999986] task:systemd-udevd state:D stack: 0 pid: 369 ppid: 353 flags:0x00004224
[ 613.999991] Call Trace:
[ 613.999995] __schedule+0x310/0x930
[ 614.000003] schedule+0x5b/0xc0
[ 614.000006] schedule_timeout+0x11c/0x160
[ 614.000010] wait_for_completion+0xa3/0x100
[ 614.000014] __flush_work.isra.0+0x15b/0x210
[ 614.000018] ? flush_workqueue_prep_pwqs+0x130/0x130
[ 614.000021] __cancel_work_timer+0x12e/0x1c0
[ 614.000026] mt76u_stop_tx+0xb1/0x1d0 [mt76_usb]
[ 614.000033] mt76u_queues_deinit+0x23/0x1f0 [mt76_usb]
[ 614.000038] mt76x2u_probe+0x7b/0x130 [mt76x2u]
[ 614.000044] usb_probe_interface+0xe2/0x2a0
[ 614.000048] really_probe+0x384/0x4a0
[ 614.000053] driver_probe_device+0xe8/0x160
[ 614.000056] device_driver_attach+0xa1/0xb0
[ 614.000060] __driver_attach+0x8f/0x150
[ 614.000063] ? device_driver_attach+0xb0/0xb0
[ 614.000066] ? device_driver_attach+0xb0/0xb0
[ 614.000069] bus_for_each_dev+0x89/0xd0
[ 614.000073] bus_add_driver+0x12b/0x1e0
[ 614.000076] driver_register+0x8f/0xe0
[ 614.000078] usb_register_driver+0x84/0x120
[ 614.000081] ? 0xffffffffc04d4000
[ 614.000083] do_one_initcall+0x57/0x220
[ 614.000089] do_init_module+0x5c/0x270
[ 614.000092] load_module+0x2545/0x2740
[ 614.000098] ? __do_sys_init_module+0x12e/0x1b0
[ 614.000100] __do_sys_init_module+0x12e/0x1b0
[ 614.000104] do_syscall_64+0x40/0x80
[ 614.000107] entry_SYSCALL_64_after_hwframe+0x44/0xae
[ 614.000111] RIP: 0033:0x7f3c88b5132e
[ 614.000113] RSP: 002b:00007fff1272a468 EFLAGS: 00000246 ORIG_RAX: 00000000000000af
[ 614.000116] RAX: ffffffffffffffda RBX: 000055afa9014950 RCX: 00007f3c88b5132e
[ 614.000118] RDX: 00007f3c88cc3a9d RSI: 0000000000015f19 RDI: 000055afa92b5c20
[ 614.000119] RBP: 000055afa92b5c20 R08: 000055afa9011230 R09: 00007fff1272a229
[ 614.000120] R10: 000055aaf3fbe371 R11: 0000000000000246 R12: 00007f3c88cc3a9d
[ 614.000122] R13: 0000000000000001 R14: 000055afa90138a0 R15: 000055afa9014950
[ 621.801269] audit: type=1101 audit(1636524105.054:1368): pid=8444 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="ankit" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 621.801354] audit: type=1110 audit(1636524105.054:1369): pid=8444 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 621.802743] audit: type=1105 audit(1636524105.054:1370): pid=8444 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 692.252636] audit: type=1100 audit(1636524175.504:1371): pid=8455 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="ankit" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 692.253164] audit: type=1101 audit(1636524175.504:1372): pid=8455 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="ankit" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 692.253263] audit: type=1110 audit(1636524175.504:1373): pid=8455 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 692.254661] audit: type=1105 audit(1636524175.507:1374): pid=8455 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
I have also noticed firefox on my system often crashes a tab or entirely crashes. It is running in GPU-accelerated mode.
I also recall having these kinds of problems about a year ago on a different Linux distro. I ran Windows for a year+ on the same system and had no crashes like this.
Since this is happening quite frequently, i can provide more info if needed the next time this happens - I would really like some help to get to the bottom of this.These kinds of bugs have been reported all over the web by Nvidia users on linux.
