RTX PRO 6000 Blackwell + RTX 5090: Xid 79 fallen off the bus, 7 events, no precursor
This is a Threadripper PRO workstation with two Blackwell cards in it, and since 31 August one of them has abruptly disappeared from the PCIe bus seven times. The messages come in the same order every time. The PCIe root port reports a DPC containment event, which means the link went down. A moment later the NVIDIA driver reports Xid 79, GPU has fallen off the bus, and then Xid 154, which sets the recovery action for the node to Node Reboot Required. Service restarts and driver reloads never bring the card back. Only a full reboot does.
A few things make this hard to pin down. The two cards are different products, an RTX PRO 6000 Blackwell Workstation Edition and a GeForce RTX 5090, and both have failed with the same sequence of messages. And in every event with telemetry, it is the card that was working that leaves the bus, never the idle one.
There is no warning on the link side. This host samples 16 PCIe link-layer counters per GPU once a second, and the last sample before the drop, taken 0.6 seconds before the event, still shows Gen5 x16 with every one of those counters at zero. With a one-second interval the final 0.6 seconds is not covered by any sample, so what I describe is the 30 minutes of samples that are covered. On the card side there are small changes in the last second, and those are listed further down. What the link layer never shows is a warning: it goes from clean to gone. The other direction does not point at the victim either, at least not in the last event, where the card that survived was running hotter and drawing more, 599 W at 80-81 C, against 563 W at 71-72 C for the card that died.
The machine is an ASUS Pro WS WRX90E-SAGE SE, Rev 1.xx, BIOS 1317, with an AMD Ryzen Threadripper PRO 9975WX, running Ubuntu 26.04.1 on kernel 7.0.0-38-generic. The driver is 595.99.02, open kernel module, CUDA 13.2. The RTX PRO 6000 Blackwell Workstation Edition sits at 0000:11:00.0 behind root port 0000:10:01.1, VBIOS 98.02.81.00.07. The GeForce RTX 5090 sits at 0000:f1:00.0 behind root port 0000:f0:01.1, VBIOS 98.02.2E.40.34. Both cards are set to a 600 W power limit on a Gen5 x16 link, and each card runs one vLLM instance for continuous LLM inference.
This is what the most recent event looks like in the kernel log:
17:26:47 pcieport 0000:f0:01.1: DPC: containment event, status:0x1f01: unmasked uncorrectable error detected
17:26:47 pcieport 0000:f0:01.1: PCIe Bus Error: severity=Uncorrectable (Fatal), type=Transaction Layer, (Receiver ID)
17:26:47 pcieport 0000:f0:01.1:   device [1022:153e] error status/mask=00000020/00000000
17:26:47 pcieport 0000:f0:01.1:    [ 5] SDES                   (First)
17:26:47 nvidia 0000:f1:00.0: AER: can't recover (no error_detected callback)
17:26:47 snd_hda_intel 0000:f1:00.1: AER: can't recover (no error_detected callback)
17:26:48 NVRM: GPU at PCI:0000:f1:00: GPU-<redacted>
17:26:48 NVRM: Xid (PCI:0000:f1:00): 79, GPU has fallen off the bus.
17:26:48 NVRM: GPU 0000:f1:00.0: GPU serial number is 0.
17:26:48 NVRM: Xid (PCI:0000:f1:00): 154, GPU recovery action changed from 0x0 (None) to 0x2 (Node Reboot Required)
17:26:48 NVRM: Xid (PCI:0000:11:00): 154, GPU recovery action changed from 0x0 (None) to 0x2 (Node Reboot Required)
17:26:48 pcieport 0000:f0:01.1: broken device, retraining non-functional downstream link at 2.5GT/s
17:26:49 pcieport 0000:f0:01.1: AER: device recovery failed
In plain terms, the root port sees the link go down. The only bit set in the error status is 0x20, which is SDES, bit 5, meaning the link went down unexpectedly rather than a data error being detected, so this signature can appear with every per-lane error counter at zero. In one of the seven events the status also had the completion-timeout bit set alongside SDES; the other six had SDES on its own. The whole endpoint disappears at once, both the GPU function f1:00.0 and its audio function f1:00.1. The driver gives up and marks the node as needing a reboot, and when the root port tries to retrain the link it drops to Gen1 speed and fails there too.
The seven events, with the power reading from the last one-second sample before each one:
  • 2026-08-31 13:33:18, RTX PRO 6000, root port 10:01.1 (no telemetry was being collected yet at that point)
  • 2026-09-14 10:58:11, RTX PRO 6000, root port 10:01.1, 525 W
  • 2026-09-14 13:59:16, RTX PRO 6000, root port 10:01.1, 549 W
  • 2026-09-14 16:02:31, RTX PRO 6000, root port 10:01.1, 471 W
  • 2026-09-14 16:12:30, RTX PRO 6000, root port 10:01.1, 565 W
  • 2026-09-30 21:35:14, RTX 5090, root port f0:01.1, 531 W
  • 2026-10-14 17:26:48, RTX 5090, root port f0:01.1, 563 W
The last of these cost 28 minutes and 45 seconds of downtime, from 17:26:47 until the machine came back at 17:55:32. Once the node is rebooted the card comes back at Gen5 x16 and runs normally until the next event.
For the first event there is no telemetry. The only other signal around it is the BMC slot sensor for that card (PCIE04), which read 90-91 C. Following that alarm path in the BMC firmware, it contains no power-off or link-disable action, so it records a reading rather than causing the cut-off. The BMC log timestamps are not reliable enough to order that entry against the DPC line.
The sampler records, per GPU and once a second: power, temperature, PCIe link generation and width, and the NVML PCIe field counters for replay count, replay rollover, L0 to Recovery, lane errors, correctable errors, correctable error rate, NAKs received and sent, receiver error, bad TLP, bad DLLP, LCRC error, unsupported request and fatal errors.
For the most recent event, here is the victim next to the card that survived, over the same 30 minutes.
The card that died, the RTX 5090, held Gen5 x16 the whole time with zero L0 to Recovery transitions, and every error counter above was zero at every sample, right up to the last one 0.6 seconds before the event. Its power stayed between 542 and 569 W and its temperature between 71 and 72 C. At that moment vLLM was serving 10 running and 22 queued requests with the KV cache at 93 to 95 percent, generating around 1,572 to 1,618 tokens per second. Once the event happened its telemetry stopped updating: power and temperature froze at their last values and link width read as “None”.
The card that survived, the RTX PRO 6000, did 18 L0 to Recovery transitions in the same 30 minutes, cycling Gen5 to Gen2 to Gen1 and back as it went briefly idle, and every error counter stayed at zero. Its power cycled between 10 W and 600 W and its temperature ran at 80-81 C, and it kept serving requests throughout.
Across all six events that have telemetry, the numbers look like this. On each line, the victim first, then the survivor, as L0 to Recovery transitions, link generation changes, and power at the last sample:
  • 09-14 10:58, victim the PRO 6000: 15 transitions, 15 generation changes, 525 W. The 5090 had 53, 50, 25 W.
  • 09-14 13:59, victim the PRO 6000: 10, 10, 549 W. The 5090 had 15, 15, 462 W.
  • 09-14 16:02, victim the PRO 6000: 16, 16, 471 W. The 5090 had 5, 5, 23 W.
  • 09-14 16:12, victim the PRO 6000: 3, 3, 565 W. The 5090 had 5, 5, 24 W.
  • 09-30 21:35, victim the 5090: 3, 3, 531 W. The 6000 had 30, 30, 7 W.
  • 10-14 17:26, victim the 5090: 0, 0, 563 W. The 6000 had 18, 18, 599 W.
Two things stand out in that list. In every event with telemetry the victim’s utilisation at the last sample was 97 to 100 percent and its power was 471 W or more, while the survivor was idle at 7 to 25 W in four of the six. And link retraining is routine here rather than a fault in itself: the surviving card in the last event did 18 down and up transitions in 30 minutes with no errors at all, and in five of the six events the card that died had fewer link transitions than the card that lived. “The link retrains and fails” does not describe what happens on this machine.
The card side does move a little. Taking the five events before the last one, where the whole window was analysed: the temperature rises in the final second in some events and not others (+4, 0, +7, 0 and -1 C across them), the PRO 6000 events reach 89 to 90 C somewhere in that window while the 5090 events stay at or below 81 C, and the NVML clock event reason field is nonzero at the end, usually the software power cap bit and in one event a hardware slowdown bit as well. None of that is consistent enough to call a trigger, and the drop does not happen at peak power: in all five of those events the reading at the moment of death, 471 to 566 W, is below the peak of the last five minutes in the same window, which is 590 to 606 W.
What the data points away from, and why:
  • A fixed power or temperature threshold. The four PRO 6000 events on 14 September died at 86 to 90 C and the two 5090 events at 79 C and 72 C, and in the five earlier events the power at the moment of death was below the peak of the final five minutes.
  • Link degradation before the event. All 16 PCIe counters on the victim were zero in all six events, including the last sample 0.6 seconds before the death.
  • Link retraining by itself. Both cards retrain constantly: the survivor did 18 down and up transitions in 30 minutes with zero errors, and in five of the six events the victim retrained less than the card that survived.
  • A whole-host problem. In the same capture the other card’s path stayed healthy, and there are no host MCE, GHES, APEI, EDAC, pstore or vmcore records for that window.
  • A single bad card. Two different GPU models, workstation and consumer, fail with the same sequence on this machine.
That list comes from this machine’s own measurements. For context, the signature is not unique to this hardware either: one other user reports it on unrelated platforms, listing WRX80, WRX90, EPYC, X670E, AM4 and Z490, and reporting that driver versions 570, 575, 580 and 595 all still show it.
What I still cannot see:
  • No bug report was captured in any of these events. The reboots were manual and there was no automatic capture step; adding one is the first thing to fix on this side.
  • A secondary bus reset or an endpoint rescan has not been tried; the attempts so far were service restarts and driver reloads.
  • The telemetry is one sample per second. Anything that happens faster than that is invisible in this data set.
A few questions for NVIDIA:
  1. Does this match a bug you are already tracking? I have seen other reports of this signature, including two threads in this forum (RTX 5090 (GB202) + Ryzen 9 9950X3D: Xid 79 at idle, reproduced across 2 driver branches, ASPM confirmed disabled at register level, zero AER errors and Deterministic Xid 120 GSP kernel panic on RTX PRO 6000 Blackwell under sustained cuBLAS workload (595.84)) and RTX 5080 (GB203): Random Xid 79 with zero precursor — any load level, instant atomic GPU death, open kernel module 595.71.05 · Issue #1151 · NVIDIA/open-gpu-kernel-modules · GitHub, and I would like to know whether this is being tracked as a Linux driver or GSP issue, or as a hardware issue on the card side.
  2. Is there a supported way to recover without a full node reboot, such as a secondary bus reset, nvidia-smi --gpu-reset, or unbind and rebind, or is a reboot the only path?
  3. Your 615.71.09 release notes say: “NVML/nvidia-smi was calling into a library to get some extended PCI info fields for each GPU. Under unique conditions, this can result in GPU fallen off bus errors in low frequency. The fix is to remove the calls to that library in high frequency paths like nvidia-smi -q. The library call will be replaced with a standard RM control call.” This host runs 595.99.02, and the sampler polls NVML_FI_DEV_PCIE_* field counters, 16 per GPU, once a second. Is that a possible contributing factor for this signature, or is that note about a different failure mode? I am reluctant to turn off the only telemetry that captures these events without knowing.
I can now reproduce the RTX 5090 failure under heavy GPU compute load: the hotspot temperature rises sharply, followed by DPC/Xid 79 and the GPU falling off the bus. All four recorded isolated DCGM diagnostic attempts reproduced the failure, and it also occurred in generic mode. Fixing the AIO cooler fans at 100% did not prevent it.
During failing runs, reported hotspot temperatures reached 108.8–109.8 C while the core was around 59–61 C. Another run recorded a jump from 43.1 C to 103.0 C in roughly one second, then later reached 105 C. These are sampled readings; one-second monitoring may have missed higher instantaneous peaks.
The gpu-burn tests also showed the large hotspot-to-core gap, including 101.5 C versus 61 C. Those tests were deliberately limited: 10 seconds at the 600 W setting, or a 500 W cap for the five-minute run. Their completion without Xid does not demonstrate stability under sustained full-power load.
Both GPUs passed standard VRAM tests, and the 5090 completed a further 30 minutes without memory errors. At 400 W, the 5090 also completed the generic DCGM sequence once on each tested driver, with some tests skipped.
My current conclusion is that transient hotspot overheating under heavy GPU compute load is the likely trigger for the 5090 bus loss. I also suspect that the PRO 6000’s default fan curve allows excessive hotspot heating under load, leading to the same type of failure.
Update — 20 October 2026
I need to revise the thermal interpretation in my previous update. Further tests reproduced the RTX 5090 bus loss, but other workloads survived similarly high reported hotspot temperatures. The evidence supports a workload-dependent failure; it does not yet identify overheating, HGEMM, the power supply, or the PCIe link as the root cause.
The latest contrast is a 900-second gpu-burn run that completed successfully, while DCGM L3 still loses the GPU within seconds to tens of seconds in the failing configurations. Both were configured with a 600 W limit, but their actual power and execution patterns were different.
The results below concern the GIGABYTE AORUS RTX 5090 XTREME WATERFORCE 32G. I have not established that the earlier RTX PRO 6000 incidents have the same underlying cause. I am pausing further software stress testing and would appreciate NVIDIA’s assessment of the evidence already collected.
GPU models, firmware, and software versions
GPU Memory Recorded VBIOS
GIGABYTE AORUS GeForce RTX 5090 XTREME WATERFORCE 32G, 360 mm AIO model 32 GB 98.02.2E.40.34
NVIDIA RTX PRO 6000 Blackwell Workstation Edition 96 GB 98.02.81.00.07
The version inventory for the tests and historical comparisons discussed here is:
Component / use Versions and provenance
NVIDIA driver, RTX 5090 failure investigation 595.84, 595.99.02, 615.71.09, 615.78.08. The latest tests used 615.78.08.
Additional historical PRO 6000 diagnostic baseline 595.91.07, recorded in the 14 September DCGM results. This is a separate historical entry, not an additional 5090 reproduction on that driver.
DCGM 4.6.1 (nvcr.io/nvidia/cloud-native/dcgm:4.6.1-1-ubuntu24.04) and 4.7.0(nvcr.io/nvidia/cloud-native/dcgm:4.7.0-ubuntu24.04). The custom image remained DCGM 4.7.0.
CUDA used by the PyTorch component tests 13.0, reported by PyTorch 2.13.0+cu130. The August NVBandwidth result also recorded CUDA Runtime 13.0 (13000).
Host CUDA toolkit used to build the standalone reproducer and the latest gpu-burn build 13.1.1; nvcc 13.1.115. The toolkit’s component manifest lists CUDA Runtime 13.1.80and cuBLAS 13.2.1.1. These identify the build/toolkit installation; they are not a per-run trace of every loaded library.
Stock DCGM container CUDA environment Both inspected DCGM 4.6.1 and 4.7.0 images declared CUDA 13.3.0, with NV_CUDA_CUDART_VERSION=13.3.29-1. This is image metadata, not proof of the diagnostic plugin’s exact cuBLAS implementation.
CUDA runtime added to the custom DCGM 4.7.0 image 13.4.2, from nvidia/cuda:13.4.2-runtime-ubuntu24.04; copied files included libcudart.so.13.4.92 and libcublas.so.13.8.0.4. The resulting image was tagged dcgm-cu134:4.7.0-cu13.4.2.
DCGM-bundled cuBLAS observed during linkage inspection 13.4.0.1 under DCGM’s cuda13/lib directory. The recorded ldd check of dcgmproftester13 resolved that bundled library. That executable is not the failing diagnostic plugin, so this does not establish which cuBLAS the failed L3 diagnostic loaded.
For completeness, earlier nvidia-smi logs displayed CUDA 13.2, the August NVBandwidth output reported CUDA Driver API 13.3 (13030), and the latest driver reported CUDA UMD 13.4. These driver/API-facing fields are distinct from the application runtime and toolkit versions above. I am not treating them as evidence that every test ran against those runtime versions.
Driver and baseline comparisons
The 5090 failure was recorded across the four driver versions listed above; updating to 615.78.08 did not resolve it.
A useful historical comparison is that this 5090 passed DCGM L3 and L4 at its 600 W power limit on 25 August with driver 595.84 and DCGM 4.6.1. On 19 October, restoring that driver and the same DCGM container image did not restore the earlier behavior: L1/L2 passed, but L3 produced bus loss. This weakens an explanation limited to a recent driver regression, although it does not make the hardware state or ambient conditions identical across those dates.
At 400 W, the generic DCGM L1–L4 sequence completed on two tested driver versions, subject to the individual plugins’ reported skips. A 500 W L3 run completed, but a subsequent 500 W L4 run lost the GPU after approximately 117 seconds. Lowering the power limit therefore helped in the recorded tests, but 500 W was not a reliable boundary. A cap also changes clock, voltage, temperature, and execution rate; it is not an isolated test of the PSU.
HGEMM variants tested and the conditions that reproduced bus loss
I tested direct cublasHgemm calls in a standalone reproducer based on DCGM 4.6.1’s diagnostic allocation/GEMM/comparison loop, as well as separate PyTorch FP16 matrix-multiplication workloads. The reproducer approximates that path; it is not the complete DCGM diagnostic. The standalone runs below used driver 615.78.08 and the host CUDA 13.1.1 build environment described above.
The two failing standalone configurations shared these recorded settings:
  • 2048 × 2048 matrices, CUBLAS_OP_N for both operands, alpha=1, beta=0.
  • DCGM-style input generation: srand(10), alternating A/B draws using rand()%1000000/100000.0, then conversion to FP32/FP16. Values before conversion were in [0,10). Inputs were generated once on the CPU and reused, not regenerated for each GEMM.
  • --usemem 0.90: approximately 27.69 GiB of output buffers, with 886 base allocations. Each FP16 phase issued 3,544 HGEMMs into distinct output views; a requested FP32 phase issued 1,772 SGEMMs.
  • Each precision phase was followed by device synchronization, a result-comparison kernel, and error/NaN counter copies to the host. Thus “HGEMM only” below means FP16 was the only GEMM precision; comparison and memory operations were still present.
  • A 600 W power limit and a requested duration of 180 seconds. Neither failing run reached the reproducer’s halfway math-mode change at 90 seconds.
All times in the following tables are local ACDT. The first table contains 20 October runs:
Run start Input / execution Power limit Recorded result
10:50:16 Pseudorandom; HGEMM then SGEMM in each cycle (--precision hs) 600 W Completed cycles 0–4; last completed phase at 3.83 s, then cublasHgemm status 14, process rc=3. Kernel DPC/SDES and Xid 79 at 10:50:23.
11:06:34 Pseudorandom; HGEMM only (--precision h) 600 W Last completed pass was pass 167 at 41.35 s, then cublasHgemm status 14, rc=3. DPC at 11:07:18.821383, Xid 79 at 11:07:18.893357. Active power mean 574.75 W, maximum 608.90 W.
11:20:21 Same pseudorandom generation; HGEMM only 450 W Completed 180.2 s, 653 passes, zero comparison errors/NaNs. Active power mean 449.37 W.
12:44:46 Constant A=B=0.001; HGEMM only (--data-const) 600 W Completed 180.1 s, 789 passes, zero comparison errors/NaNs. Active power mean 494.91 W, maximum 508.45 W.
The 3.83 s and 41.35 s values are the last completed-phase timestamps, not exact times to bus loss. The kernel timestamps separately establish when bus loss was reported. Alternating FP16/FP32 is not required for reproduction, because the FP16-only configuration also failed. The failures also occurred before the scheduled math-mode change. This does not isolate the failing kernel or prove a specific tensor-core path: no per-kernel trace was captured.
The earlier reproducer used constant 0.001 inputs, before its input generation was changed at 10:33. Those results must be kept separate from the later pseudorandom tests:
Run start, 20 October Constant-input variant Power limit Recorded completion
00:34:13 HGEMM, 2048, full output allocation 400 W 180.2 s, 760 passes
00:44:25 HGEMM, 2048, --always-tensor 400 W 180.1 s, 766 passes
00:47:37 HGEMM, 8192, full allocation; 208 HGEMMs per phase 400 W 180.3 s, 282 passes
00:54:02 HGEMM/SGEMM alternating, 2048 400 W 180.1 s, 285 passes
00:57:14 HGEMM, 2048, extended duration 400 W 600.1 s, 2,531 passes
01:12:28 HGEMM, 2048, small output allocation: --small-fb 40, 1.25 GiB, 160 HGEMMs per phase 600 W 60.0 s, 5,993 passes
01:14:55 HGEMM, 2048, full output allocation 600 W 180.0 s, 769 passes
01:21:16 HGEMM/SGEMM alternating, 2048 600 W 180.2 s, 293 passes
01:24:28 HGEMM, 2048, --always-tensor 600 W 180.2 s, 736 passes
All nine runs reported SURVIVED, zero comparison errors, and zero NaNs. Here, --always-tensor means the program requested CUBLAS_TENSOR_OP_MATH from the start. It is not proof of the hardware instructions cuBLAS selected, and the absence of that flag does not establish that tensor cores were unused.
I also tested these different FP16 execution patterns in PyTorch on 19 October. Each completed its requested 25 seconds and recorded SURVIVED:
Test FP16 matrix size Additional work / allocation Recorded work completed
E1 8192 Repeated torch.matmul, reusing one output matrix 5,030 matmuls
E4 8192 Host/device copies using a separate CUDA stream 2,630 matmuls and copy cycles
E5 8192 30 GiB separately allocated and filled before matmul 4,990 matmuls
E7 6144 Concurrent writes across 24 GiB of buffers 685 matmuls, 137 sweeps
E8 8192 Repeated 4 GiB allocation/fill/release operations 4,152 matmuls, 1,038 allocation cycles
E10 8192 Repeated 27 GiB allocation/write/release operations 1,032 matmuls, 258 allocation cycles
These used torch.randn FP16 inputs, a different distribution and execution pattern from the direct reproducer. They are not verified direct cublasHgemm calls or evidence of the same selected cuBLAS kernel. Their short duration also limits the comparison.
The demonstrated reproduction condition is the DCGM-style pseudorandom, 2048, large-output-buffer calculation/comparison loop at 600 W, in both FP16-only and FP16/FP32 forms. This is an observed configuration, not a proven necessary-and-sufficient trigger. The corresponding 450 W FP16 run and multiple constant-input variants survived; I have not established the outcome of every combination, such as pseudorandom 8192 or pseudorandom small-buffer runs at 600 W.
The comparison is not fully controlled: the failed 11:06 FP16 run had persistence mode disabled, while the 11:20 and 12:44 runs had it enabled. The last run added the constant-input option without changing the GEMM/comparison loop, but used a rebuilt binary after recovery. Changing inputs also reduced actual power. The power averages above exclude the idle tail and post-failure samples; they are software telemetry, not external electrical measurements. A 600 W limit did not mean the constant-input runs continuously consumed 600 W. These results narrow the workload conditions without proving either a random-data library bug or a purely electrical cause.
Suspected transient power excursion during DCGM’s GEMM workload
One specific hypothesis is that short power excursions associated with DCGM’s HGEMM workload may exceed the configured power limit, destabilize the GPU’s power delivery, and contribute to bus loss. During the 20 October L3 run with FP32 and FP16 enabled, the instantaneous-power telemetry field reported 684.888 W against a 600 W limit—approximately 85 W, or 14.1%, above the setting—at 10:07:18.363 ACDT. The ordinary power reading in the same sample was 588.63 W; adjacent energy-counter intervals averaged approximately 589.53 W and 574.74 W.
This makes a brief excursion worth considering alongside the observed benefit from lower power limits. However, it was a single sensor-reported value, approximately 9 seconds before Xid 79, not a measurement at the instant of bus loss. There was no synchronized per-kernel trace proving that the sample occurred during an HGEMM call, and no external electrical measurement validating the excursion. I therefore regard this as a possible trigger, not an established cause, and cannot infer a defective PSU or a power-limit implementation bug from the sample alone.
There is also a relevant counterexample: the successful 400 W constant-input HGEMM/SGEMM run recorded 484.723 W instantaneous power at 00:56:30.376, while ordinary power was 397.69 W, and completed 180.1 seconds. That is approximately 85 W, or 21.2%, above its cap without bus loss. Thus an above-cap sensor reading alone does not distinguish failure from success; the absolute load, excursion duration, and power-delivery response remain unverified factors.
High hotspot readings and HGEMM errors are not unique to the failing cases
A 60-second gpu-burn run survived with a reported hotspot maximum of 105.9 C. An earlier constant-input FP16 run survived 180 seconds at a reported hotspot maximum of 107.7 C, and three FP32 runs completed 180 seconds each with maxima of 107.2–107.4 C. These readings came from separate hotspot logging, not the ordinary nvidia-smi core temperature field.
The latest gpu-burn run, using its FP32/FLOATS mode, also completed the requested 900 seconds, returned exit code 0, and reported GPU 0: OK for the single visible device, the 5090. The active-interval telemetry averaged approximately 537 W, peaked at 597.24 W, and recorded a maximum core temperature of 70 C. The post-run GPU query succeeded, and the kernel log for the run contained no Xid/DPC/AER messages. That run’s telemetry captured core temperature, not hotspot, so I am not claiming that it duplicated the failing run’s thermal conditions.
This does not exclude thermal involvement or unobserved local/transient heating. It does mean that the highest sampled hotspot temperature alone does not separate passing and failing runs. The latest failed DCGM run also reported thermal violations, detailed below.
Nor is the recorded failure exclusive to HGEMM: one earlier FP32 run failed with cublasSgemm status 13 and DPC/Xid 79. Other FP32 runs subsequently passed. Stopping the other GPU’s inference workload also did not prevent the 5090 DCGM failure, so simultaneous inference on both GPUs is not required.
Latest DCGM failure and PCIe evidence
On 20 October, DCGM 4.7.0 L2 passed its software, memory, and PCIe tests. The following L3 failed in the diagnostic plugin, with FP32 and FP16 enabled. Its errors were:
cuMemcpyDtoH_v2: unspecified launch failure
cuMemFree_v2: unspecified launch failure
Thermal violations totaling 4.4 seconds started at 5.0 seconds into the test
This particular run did not report a cublasHgemm failure. The reporting API does not necessarily identify the originating operation: NVIDIA’s CUDA Driver API documentation notes that cuMemcpyDtoH can return errors from earlier asynchronous launches.
The final successful telemetry query was timestamped 13:18:14.373 ACDT: 588.05 W, core 59 C, 100% utilization, Gen5 x16. Xid 79 appeared at 13:18:14.614891, followed by DPC/SDES and Xid 154. The post-event root-port AER counters included:
SDES                 1
CmpltTO              1
TOTAL_ERR_FATAL      1
The correctable-error fields sampled before the failure remained zero. To be precise, this capture periodically read four correctable fields per device, not every AER counter. It also was not an exact 200 ms trace: the median interval was 228 ms, with gaps up to 1.093 seconds, and the timestamps preceded the GPU queries.
The defensible observation is that no gradual link degradation was observed in those samples. It does not exclude abrupt PCIe, connector, power, or endpoint failure. Likewise, the order in which Xid and DPC messages were printed does not establish which component physically failed first.
CUDA container comparison and diagnostic captures
I also built the custom DCGM 4.7.0 / CUDA 13.4.2 image listed above by adding the runtime and adjusting the library search path. L3 still failed. However, this did not recompile DCGM. The available linkage inspection concerned dcgmproftester13, and I have not verified which cuBLAS implementation the failing diagnostic actually used. I therefore cannot claim to have tested the failure against a replaced/newer cuBLAS implementation solely from that image change.
I have preserved the diagnostic JSON, kernel logs, telemetry, and AER snapshots. I also verified that nvidia-debugdump and nvidia-bug-report.sh can collect data with the required privileges, and configured an event-triggered capture. The successful manual captures were made after reboot, while the GPU was accessible. They contain historical kernel logs, but I do not have a verified GPU-internal dump from the instant of bus loss, nor a validated automatic capture from a subsequent failure.
Working hypotheses, not conclusions
  • A local electrical or thermal margin problem exposed by a particular workload. In particular, the 684.888 W instantaneous-power sample raises the hypothesis of a transient excursion during DCGM’s GEMM workload contributing to power instability and bus loss. The power-cap effect and thermal-limit events support considering this, but do not distinguish the card’s power delivery, external power path, cooling, or another mechanism. Surviving high-hotspot workloads are a counterexample to a simple sampled-temperature threshold.
  • An abrupt PCIe/endpoint/platform failure. SDES and completion timeout are present. Clean preceding correctable counters do not rule this out, and the logs alone do not distinguish the root port from the endpoint or loss of endpoint power.
  • A driver/GSP or compute-library execution-path problem. The DCGM-style workload is a useful reproducer, but the affected API varies and the same older software combination once passed. A common problem across driver versions remains possible; a specific HGEMM bug has not been demonstrated.
Could NVIDIA assess whether this combination of reproducible DCGM diagnostic failure, thermal-limit activity, and abrupt SDES/Xid 79 matches a known issue in the tested stack?
In particular, how should the 684.888 W instantaneous reading under a 600 W cap be interpreted: could it reflect a transient relevant to this failure, or is it consistent with the normal power-cap averaging or telemetry behavior?
It would also help to confirm which cuBLAS implementation is included or selected by the DCGM 4.7.0 diagnostic, and whether the existing logs can distinguish a driver/GSP failure from a board, power-path, or PCIe fault. I can provide the preserved logs and reproducer source for review. I am seeking interpretation of these results and guidance on hardware assessment rather than starting another software stress-test campaign.
Further update — 20 October 2026: no bus-loss recurrence in six clock-limited DCGM runs
I have found an effective mitigation for the reproducible bus loss on my GIGABYTE AORUS RTX 5090 XTREME WATERFORCE 32G: limiting the GPU clock. All six subsequent DCGM L3 runs completed without bus loss or Xid errors, while the power limit remained at 600 W.
These tests used driver 615.78.08, DCGM 4.7.0, and the previously described custom image dcgm-cu134:4.7.0-cu13.4.2, with generic_mode=True. The CUDA version in that image tag does not establish which cuBLAS the diagnostic loaded.
Before applying a clock limit, the evening L3 run again failed: the diagnostic reported cublasHgemm with CUBLAS_STATUS_INTERNAL_ERROR, the kernel recorded DPC/SDES and Xid 79, and the GPU became inaccessible. The run returned rc=226 after approximately 17 seconds.
After applying GPU clock limits, the results were:
Requested GPU clock setting Power limit Full L3 run time Result
2,000 MHz 600 W 6 min 27 s Completed, diagnostic Pass, no Xid
2,200 MHz 600 W 6 min 27 s Completed, diagnostic Pass, no Xid
2,300 MHz 600 W 6 min 26 s Completed, diagnostic Pass, no Xid
2,407 MHz 600 W 6 min 24 s Completed, diagnostic Pass, no Xid
2,500 MHz 600 W 6 min 24 s Completed, diagnostic Pass, no Xid
2,600 MHz 600 W 6 min 23 s Completed, diagnostic Pass, no Xid
Each run returned rc=0, and the GPU remained accessible afterward. The diagnostic plugin explicitly reported Passwith FP32 and FP16 enabled in every run. The memory_bandwidth plugin was skipped; it is not being counted as a passed test.
The 2,600 MHz run is particularly relevant to the earlier power-excursion hypothesis:
  • Maximum ordinary power reading: 549.06 W.
  • Maximum instantaneous-power field: 609.882 W.
  • Recorded SM clocks: 2,385–2,602 MHz.
  • Maximum core temperature: 66 C.
  • No bus loss or Xid errors.
An instantaneous reading above the 600 W cap was therefore present in a successful run. The clock setting also did not hold every sampled SM clock at exactly one frequency.
I have selected -lgc 2600,2600 with the existing 600 W power limit as my operating setting. The practical result is that the previously reproducible failure did not recur in any of these six clock-limited runs.
My working diagnosis now focuses on instability associated with GPU Boost and its clock/voltage operating conditions. The comparison does not yet distinguish a problem at higher boost clocks from a problem during transitions or related changes in power. These results concern the RTX 5090; I have not performed the equivalent clock-limit comparison on the RTX PRO 6000.
I can confirm the same result from a different machine.
I have a GIGABYTE AORUS GeForce RTX 5090 STEALTH ICE, and it showed me the exact same sequence on two different AMD boards — first an ASUS A620M-A-CSM, then an ASRock X670E Steel Legend (BIOS 4.43), both with driver 615.78.08 (open kernel module), the same driver you tested with. Every time: Xid 79 followed by Xid 154, card gone, black screen, and only a full reboot bringing it back. Since the problem followed the card across two different chipsets, I would not call it board-specific. It happened under continuous LLM inference while I was running through several open-source projects (my own inference engine ninfer, vLLM, llama.cpp), so it was not specific to one workload.
I tested a few operating points, and the one that worked for me is exactly the one you landed on: 600 W power limit plus nvidia-smi -lgc 2600,2600. A 450 W cap alone did stop the events, but it cost real throughput, and 600 W without the clock lock was still in the risk zone. With the SM clock locked at 2600 MHz I keep the full 600 W, and the bus drops have not recurred — I have both settings applied at boot and it has been stable under sustained inference load since.
Your working diagnosis fits what I saw as well: it points at GPU Boost clock/voltage transitions rather than anything on the PCIe link side. Thanks for documenting this so thoroughly — the clock-limit result saved me a lot of trial and error.
Third GIGABYTE AORUS RTX 5090 data point: 10 × Xid 79 since August, all under CUDA load, none at 400 W
Adding our case because it matches what Jean_The_CAT and onurcansevero2014 describe on their AORUS cards, and because we have 10 Hz telemetry right up to several of the drops.
System
  • GPU: GIGABYTE AORUS GeForce RTX 5090 MASTER 32G (subsystem 1458:4199), VBIOS 98.02.2E.00.C9
  • Motherboard: GIGABYTE X870 AORUS ELITE WIFI7, BIOS F10, then F13e (AGESA 1.3.0.1d) since 12 Oct
  • CPU / RAM: Ryzen 9 9950X with PBO and Curve Optimizer; 2 × 48 GB DDR5-6800 (XMP)
  • PSU: ASRock Steel Legend SL-1200GW, 1200 W, ATX 3.1, native 12V-2x6 cable (visually fully seated)
  • Link: PCIe 5.0 x8 (this board splits the x16 slot when the CPU M.2 slots are populated); ASPM not supported on the root port; AER enabled in BIOS since 28 Sep
  • OS: CachyOS, open kernel modules 610.57.04, 615.71.09 and 615.78.08, kernels 7.1.8 to 7.3.1. Updated to 620.70.06 today, no events on it yet.
Signature (all 10 events)
Xid 79 followed by Xid 154 (OS Reboot). The GPU config space reads 0xFFFF, the root port retrains to 2.5 GT/s, and only a cold boot brings the card back. The CUDA process dies with “unspecified launch failure”. No thermal slowdown flag and no OOM at any event.
Events (“n/l” = not logged)
# Date Driver Power limit Workload Telemetry before the drop
1 2026-08-18 610.57.04 600 W llama.cpp prompt processing (~28K tokens) n/l
2 2026-09-26 615.71.09 600 W llama.cpp prompt processing n/l
3 2026-09-26 615.71.09 600 W llama.cpp prompt processing ~14 s at 540 to 610 W, 78 to 80 °C, 2.6 to 2.9 GHz
4 2026-09-27 615.71.09 600 W llama.cpp prompt processing 38 W to 665 W in 0.3 s, then ~600 W for 7 s
5 2026-09-27 615.71.09 550 W llama.cpp ~547 W steady
6 2026-09-28 615.71.09 600 W llama.cpp 498 to 611 W, 81 °C, 2,865 MHz
7 2026-09-28 615.71.09 600 W synthetic llama.cpp request loop, dropped after 12 min mean 582 W, max 683 W, core up to 84 °C
8 2026-10-10 615.78.08 600 W (probably) PyTorch (OCR + embeddings) 430 to 500 W
9 2026-10-11 615.78.08 600 W PyTorch (sentence-transformers embeddings, bf16) n/l
10 2026-11-07 615.78.08 600 W our own CUDA photogrammetry code 520 to 600 W, SM 2,820 to 2,932 MHz, 74 to 81 °C, GPU fans at 100 %
What we measured
  • Power limit. At 400 W: 0 drops in ~5.9 h of load. In September at 550 to 600 W: 5 drops in ~7.1 h of load. On our workload 400 W costs 16 to 18 % in prompt processing and ~11 % in token generation, so we only use it as a stopgap.
  • Clock. Under load at 600 W the SM clock median is 2,790 to 3,022 MHz; at 400 W it is 2,107 to 2,178 MHz. In the drops where we logged the clock (#3, #6, #10) it was 2.6 to 2.95 GHz. #8 happened at only 430 to 500 W, but with the 600 W limit, so high on the boost curve. This fits the GPU Boost clock/voltage hypothesis in this thread better than “too many watts”.
  • AER. Since enabling AER we see occasional correctable errors on the GPU link under heavy load (Replay Timer Timeout at the GPU, BadTLP and BadDLLP at the root port), up to ~3 per hour in the synthetic loop, and one BadTLP 63 s before #8. None of the drops had a fatal or non-fatal error at the moment of the drop. Today’s nvidia-smi pci -gErrCnt after 20 min of uptime: REPLAY 2, L0_TO_RECOVERY 117, everything else 0.
  • Cooling. Case fans at 100 % did not change the T.Limit margin reported by NVML at 600 W (around 0 °C either way). The card’s own fans were at 100 % during #10.
  • Rate. 8 drops between 26 Sep and 11 Oct (some of them during deliberate stress tests), then 27 days without one after the BIOS update to F13e and driver 615.78.08, then #10. Our usage also changed in that period, so we can’t credit the BIOS.
Not tested yet: -lgc 2600,2600 at 600 W (the setting that worked for both AORUS cards in this thread), PCIe Gen4, CPU and RAM at stock settings (no PBO, no XMP).
Questions for NVIDIA (@amrits @abchauhan)
  1. Is Xid 79 + 154 under heavy CUDA load on GB202 tracked under one of the open bugs (6818900, 6819883, 6821987, 6699452)?
  2. Three GIGABYTE AORUS 5090s in this thread now show the same pattern, and two became stable with a clock cap. Is a VBIOS or GSP firmware change being considered for these cards?
I can share the 10 Hz telemetry windows and kernel logs for #7 and #10, and will run nvidia-bug-report.sh after the next event. The analysis was done with the help of an AI assistant, from the system’s own logs.
