RTX3090 Trinity Not Detected vs RTX3090 Trinity OC Detected
Hello, I am currently experiencing a problem,
I have two RTX3090, a Trinity OC and the other Trinity
both on the last drivers 515, Ubuntu 22.04
one working perfectly the other one send errors
lspci | grep NVIDIA
03:00.0 VGA compatible controller: NVIDIA Corporation GA102 [GeForce RTX 3090] (rev a1)
03:00.1 Audio device: NVIDIA Corporation GA102 High Definition Audio Controller (rev a1)
04:00.0 VGA compatible controller: NVIDIA Corporation GA102 [GeForce RTX 3090] (rev ff)
04:00.1 Audio device: NVIDIA Corporation GA102 High Definition Audio Controller (rev ff)
I looked at the forums but get confused
The gpu is off, fallen off the bus, prbably due to lack of power or overheating.
I don’t think its the reason.
The power, even if I switch them the problem still there.
Overheating, it not always turn on
It works with Xorg drivers
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
nvidia-bug-report.log.gz (321.4 KB)
Like said:
[   11.515007] NVRM: Xid (PCI:0000:0b:00): 79, pid='<unknown>', name=<unknown>, GPU has fallen off the bus.
Please check/swap power connectors, check if it works in another system, if not, it’s broken.
Well I installed Ubuntu again, I put her alone in the system, I plugged the hdmi directly in the GPU. Without the Nvidia driver.
Like always Asus motherboard in the beginning shows that the pci it detected green.
It worked untill the desktop, 5 seconds later black screen.
I can acces only by ssh.
The fan turn all the times non stop.
Can it be because of thermo pad change ? We used 3 mm?
Error when closing nvidia-modeset error:
The problem is Fix, it doesn’t work with 3mm thermopad. Need less. Zotac
Thank you for your help.
