Hi there,
I need some help setting up an RTX3090 under Ubuntu LTS 20.04.1
Linux server01 5.11.0-27-generic #29~20.04.1-Ubuntu SMP Wed Aug 11 15:58:17 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
Initially (with a clean install of Ubuntu 20LTS) the card gets listed with lshw but without a valid name. After running
sudo update-pciids
I can see a proper name:
sudo lshw -C video
*-display
description: VGA compatible controller
product: ASPEED Graphics Family
vendor: ASPEED Technology, Inc.
physical id: 0
bus info: pci@0000:03:00.0
version: 41
width: 32 bits
clock: 33MHz
capabilities: pm msi vga_controller cap_list rom
configuration: driver=ast latency=0
resources: irq:17 memory:9c000000-9cffffff memory:9d000000-9d01ffff ioport:2000(size=128) memory:c0000-dffff
*-display
product: GA102 [GeForce RTX 3090]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:1b:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: iomemory:39ff0-39fef iomemory:39ff0-39fef irq:28 memory:a9000000-a9ffffff memory:39ffe0000000-39ffefffffff memory:39fff0000000-39fff1ffffff ioport:5000(size=128) memory:aa000000-aa07ffff
and with lspci:
lspci -k -v
1b:00.0 VGA compatible controller: NVIDIA Corporation GA102 [GeForce RTX 3090] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Micro-Star International Co., Ltd. [MSI] Device 3887
Flags: bus master, fast devsel, latency 0, IRQ 28, NUMA node 0
Memory at a9000000 (32-bit, non-prefetchable) [size=16M]
Memory at 39ffe0000000 (64-bit, prefetchable) [size=256M]
Memory at 39fff0000000 (64-bit, prefetchable) [size=32M]
I/O ports at 5000 [size=128]
Expansion ROM at aa000000 [virtual] [disabled] [size=512K]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Legacy Endpoint, MSI 00
Capabilities: [b4] Vendor Specific Information: Len=14 <?>
Capabilities: [100] Virtual Channel
Capabilities: [250] Latency Tolerance Reporting
Capabilities: [258] L1 PM Substates
Capabilities: [128] Power Budgeting <?>
Capabilities: [420] Advanced Error Reporting
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] Secondary PCI Express
Capabilities: [bb0] Resizable BAR <?>
Capabilities: [c1c] Physical Layer 16.0 GT/s <?>
Capabilities: [d00] Lane Margining at the Receiver <?>
Capabilities: [e00] Data Link Feature <?>
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
I have driver version 470.52.02 installed:
apt list --installed | grep nvidia
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
libnvidia-cfg1-470/focal-security,now 470.57.02-0ubuntu0.20.04.1 amd64 [installed,automatic]
libnvidia-common-470/focal-security,focal-security,now 470.57.02-0ubuntu0.20.04.1 all [installed,automatic]
libnvidia-compute-470/focal-security,now 470.57.02-0ubuntu0.20.04.1 amd64 [installed,automatic]
libnvidia-compute-470/focal-security,now 470.57.02-0ubuntu0.20.04.1 i386 [installed,automatic]
libnvidia-decode-470/focal-security,now 470.57.02-0ubuntu0.20.04.1 amd64 [installed,automatic]
libnvidia-decode-470/focal-security,now 470.57.02-0ubuntu0.20.04.1 i386 [installed,automatic]
libnvidia-encode-470/focal-security,now 470.57.02-0ubuntu0.20.04.1 amd64 [installed,automatic]
libnvidia-encode-470/focal-security,now 470.57.02-0ubuntu0.20.04.1 i386 [installed,automatic]
libnvidia-extra-470/focal-security,now 470.57.02-0ubuntu0.20.04.1 amd64 [installed,automatic]
libnvidia-fbc1-470/focal-security,now 470.57.02-0ubuntu0.20.04.1 amd64 [installed,automatic]
libnvidia-fbc1-470/focal-security,now 470.57.02-0ubuntu0.20.04.1 i386 [installed,automatic]
libnvidia-gl-470/focal-security,now 470.57.02-0ubuntu0.20.04.1 amd64 [installed,automatic]
libnvidia-gl-470/focal-security,now 470.57.02-0ubuntu0.20.04.1 i386 [installed,automatic]
libnvidia-ifr1-470/focal-security,now 470.57.02-0ubuntu0.20.04.1 amd64 [installed,automatic]
libnvidia-ifr1-470/focal-security,now 470.57.02-0ubuntu0.20.04.1 i386 [installed,automatic]
linux-objects-nvidia-470-5.11.0-25-generic/focal-security,now 5.11.0-25.27~20.04.1+3 amd64 [installed,automatic]
linux-signatures-nvidia-5.11.0-25-generic/focal-security,now 5.11.0-25.27~20.04.1+3 amd64 [installed,automatic]
nvidia-compute-utils-470/focal-security,now 470.57.02-0ubuntu0.20.04.1 amd64 [installed,automatic]
nvidia-dkms-470/focal-security,now 470.57.02-0ubuntu0.20.04.1 amd64 [installed,automatic]
nvidia-driver-470/focal-security,now 470.57.02-0ubuntu0.20.04.1 amd64 [installed]
nvidia-kernel-common-470/focal-security,now 470.57.02-0ubuntu0.20.04.1 amd64 [installed,automatic]
nvidia-kernel-source-470/focal-security,now 470.57.02-0ubuntu0.20.04.1 amd64 [installed,automatic]
nvidia-prime/now 0.8.16~0.20.04.1 all [installed,local]
nvidia-settings/focal-security,now 470.57.01-0ubuntu0.20.04.1 amd64 [installed,automatic]
nvidia-utils-470/focal-security,now 470.57.02-0ubuntu0.20.04.1 amd64 [installed,automatic]
xserver-xorg-video-nvidia-470/focal-security,now 470.57.02-0ubuntu0.20.04.1 amd64 [installed,automatic]
The problem is that nvidia-smi is not showing the graphic card.
nvidia-smi
No devices were found
I tried older drivers like 450 and reinstalled ubuntu (several times already -_-).
I don’t know what else to do anymore.
Attached is the Nvidia bug report. I hope someone can tell me what is wrong here.
nvidia-bug-report.log.gz (303.0 KB)
