Our site has a user with a fortran code (included below) that compiles fine with pgf90 (PGI), gfortran (GNU), and ifort (Intel). When executed however, only the version compiled with ifort completes successfully. Here is the error received when running the pgf90 version:
$ pgf90 -r8 cylindrical.f90 -o cylindrical.exe
$ ./cylindrical.exe
allocate arrays
Open grid files…
write grid file…
PGFIO/stdio: No such file or directory
PGFIO-F-/unformatted write/unit=120/error code returned by host stdio - 2.
File name = grid3dg.ggFine unformatted, stream access record = 0
In source file cylindrical.f90, at line number 57
FWIW the version compiled with gfortran segfaults, rather than providing the 4 lines of error messages like the pgf90 version provides.
This can be reproduced on multiple systems using anything from PGI 10.9 to PGI 11.10.
Any clues as to what’s going on would be greatly appreciated. Our site has multiple PGI licenses, but an email sent to trs@pgroup.com has not elicited a response.
Thanks in advance!
-Lee
Here is the code in question:
program hexahedronvol
implicit none
real::r
real::pi=3.141592653589793
integer::i,j,k,L,nxg,nyg,nzg
integer::nx,ny,nz,ni,nj,nk
real::aa,rr,phi,x0,y0
real,allocatable,dimension(:,:,:)::xx
!real,allocatable,dimension(:,:,:)::yy
real,allocatable,dimension(:,:,:)::zz
nx=1280
ny=896
nz=1920
nxg=nx
nyg=ny
nzg=nz
r=1.0
print*,“allocate arrays”
allocate(xx(1:nxg+1,1:1,1:nzg+1)); xx = 0.
!allocate(yy(1:nxg+1,1:1,1:nzg+1)); yy = 0.
allocate(zz(1:nxg+1,1:1,1:nzg+1)); zz = 0.
print*,“Open grid files…”
!—just for bump case
! open(120,file=‘bumpEtrdFF.grd’,form=‘formatted’)
! read(120,) L
! read(120,) nk,ni,nj
! read(120,) (((xx(i,j,k),k=1,nk),i=1,ni),j=1,nj)
! read(120,) (((aa, k=1,nk),i=1,ni),j=1,nj)
! read(120,) (((zz(i,j,k),k=1,nk),i=1,ni),j=1,nj)
! close(120)
print,“write grid file…”
open(120,file=‘grid3dg.ggFine’,form=‘unformatted’,access=‘stream’)
write(120) nx+2,ny+2,nz+2
write(120) (((xx(i,1,k),i=1,nx+2),j=1,ny+2),k=1,nz+2) &
, ((((j-1.)*1.015625e-3,i=1,nx+2),j=1,ny+2),k=1,nz+2) &
, (((zz(i,1,k),i=1,nx+2),j=1,ny+2),k=1,nz+2)
close(120)
