I get an error message
PGFIO-F-235/formatted write/internal file/edit descriptor does not match item type.
In source file toto.f90, at line number 22
when running source code:
function writenumber(number) result(charout)
implicit none
integer(KIND=8), intent(in) :: number
character(len=16) :: charout
! Local variables:
character6 :: sm
character9 :: sp
character7 :: szero = ’ 000000’
if (number < 0) then
! Nagative API
if (-number > 1000000_8) then
!| write(sm, FMT=’(I6)’) mod(-number, 1000000_8)
write(sm, FMT=’(I6)’) -number - 1000000_8 * (-number/1000000_8)
write(sp, FMT=’(I9)’) -number/1000000_8
charout = ‘-’ // trim(adjustl(sp)) // szero(1:7-len_trim(adjustl(sm))) // adjustl(sm)
else
write(charout, FMT=’(I7)’) number
endif
elseif (number > 1000000_8) then
write(sm, FMT=’(I6)’) number - 1000000_8 * (number/1000000_8)
write(sp, FMT=’(I6)’) (number/1000000_8)
charout = trim(adjustl(sp)) // szero(1:7-len_trim(adjustl(sm))) // adjustl(sm)
else
write(charout, FMT=’(I6)’) number
endif
end function writenumber
program toto
implicit none
integer(KIND=8) :: number
character16, external :: writenumber
number = 1328 * 10000
write(6, FMT=’(“w=”,A,".")’) writenumber(number)
end program toto
as though writes to string variable and to file descriptor overlap…
I use pgf95 -V
pgf95 10.3-0 64-bit target on x86-64 Linux -tp core2-64
Any help appreciated.
