Running cuda-checkpoint on SGLang fails on H200, but succeeds on H100
This ticket demonstrates a usage of cuda-checkpoint which fails on H200s, but succeeds on H100s. In this reproduction, we are attempting to run cuda-checkpoint on and SGLang server.
Driver version: 575.57.08
CUDA version: 12.9
Steps to reproduce
Step 1: Build the Dockerfile
FROM lmsysorg/sglang:v0.5.0rc2-cu126
RUN apt-get update && apt-get install -y wget && \
    wget https://github.com/NVIDIA/cuda-checkpoint/raw/refs/heads/main/bin/x86_64_Linux/cuda-checkpoint -O /usr/bin/cuda-checkpoint && \
    chmod +x /usr/bin/cuda-checkpoint
RUN pip install protobuf
Then,
docker build . --tag sglang-server
Step 2: Run the container, and run cuda-checkpoint inside
#!/bin/bash
set -ex
log() {
  echo "[$(date +"%H:%M:%S")]" "$@" >&2
container_id="$(sudo docker run --detach --gpus all \
    --shm-size 32g \
    -p 30000:30000 \
    -v ~/.cache/huggingface:/root/.cache/huggingface \
    --env "HF_TOKEN=$HF_TOKEN" \
    --ipc=host \
    --name=sglang-server \
    sglang-server \
    python3 -m sglang.launch_server \
        --model-path "mistralai/Mistral-7B-Instruct-v0.3" \
        --host 0.0.0.0 --port 30000)"
sleep 3; log "checkpointing internally"
get_state() {
  sudo docker exec $container_id \
    sh -c "ps aux | grep -v grep | grep '^root' | grep -v cuda-checkpoint | awk '{ print \$2 }' | xargs -I{} cuda-checkpoint --get-state --pid {}" || true
toggle_all() {
    sh -c "ps aux | grep -v grep | grep '^root' | grep -v cuda-checkpoint | awk '{ print \$2 }' | xargs -I{} cuda-checkpoint --toggle --pid {}" || true
get_state
toggle_all
get_state
On an H200 machine, cuda-checkpoint fails with OS call failed or operation not supported on this OS when running --get-state and --toggle on certain PIDs spawned by SGLang. On an H100 machine, this command succeeds.
The original ticket can be found here.
Hi dear developer , this is tracked in internal NVBUG ID 5544504 . We can reproduce this on a H200 . We are investigating this and will bring back conclusion here . Thanks for your patience .
