I’ve written some code code which runs on the same machine (Windows 10, 64 bit) concurrently, which has many graphics cards installed.
It’s working well and I am able to run a single instance of my code per graphics card device. However after a few hours one of the instances crashes, and brings down all the other instances of the application too.
(it looks like the graphics card driver crashes, it goes to a black screen for a bit and comes back after around 30 seconds)
Has anybody experienced this behaviour? Any tips for debugging?
The test machine is not my development machine, but I am considering installing the compiler and running it from there. I’ve read articles about turning on the windows minidump for such things, but I’m not convinced this will lead to an effective diagnostic.
I’m wondering if I’m experiencing some sort of buffer overflow, writing to bits of GPU memory I have no right changing. i.e. the bit of the code causing the problem may not appear in the minidump, just the end result of the glitch.
Thanks in advance.
Regards Phill.
